Old 09-15-2012, 10:39 AM   #1
NH_boater
Default Boating safety
Not sure if everyone already knows about this but I will be adding it to my safety gear (along with VHF, auto fire ext, jumper batt, portable bilge pump, tools, etc.). Hope this helps.
http://www.stayafloatmarine.com/
NH_boater is offline   Reply With Quote
The Following 2 Users Say Thank You to NH_boater For This Useful Post:
jeffk (09-15-2012), White Rook (09-16-2012)
Old 09-15-2012, 04:44 PM   #2
It's plumbers wax. The same stuff as the ring you put under your toilet. Lot's cheaper at the hardware store and you can break up the donut if you only need ti fix a small leak.
It got a good write-up on "The Hull Truth" forum last year and a member there said they used it to good effect once.
This page was generated in 0.10151 seconds
