Old 10-11-2011, 10:11 AM   #1
Default Winterizing a boat yourself
So I've been winterizing my own boat, 4 or 5 different ones over the last 30 years or so. I pulled mine yesterday. It a 2000 Four Winns 5.7 Gsi DP. I have always used the "pull the four hoses off the thermostat block" method of adding the antifreeze after draining the block. In my case, I manually drain the raw water pump because it is attached to the engine inside, not the typical impeller in the outdrive style. I use 2 gallons of AF using this method.
My question is...who uses a different method such as the portable tank that you fill with 5 gallons of AF and connect to the outdrive with the flushing "ear muffs" and run the engine? Does this work and will it work on systems that have the heat exchanger for the hot water tank in boats with a potable water system?
BT
Old 10-16-2011, 04:01 PM   #2
No one???? Really???
Old 10-16-2011, 07:34 PM   #3
Shreddy
Shreddy's Avatar
Default I do
I do, and I did it today. Pulled the boat out of the water, on/off to clean the hull. Pump the oil out, and change the filter. Add new oil and new filter. Finally, we have a portable 5 gallon tank and run about 3.5 to 4 gallons of antifreeze through the outdrive and when it's just about complete I spray the carbs to fog the motor and let the engine stall. Have never had a problem doing it this way as long as we've done it. This is 1994 Four Winns 220 Horizon. Very easy to do and saves a ton of money at any local establishment.
The Following User Says Thank You to Shreddy For This Useful Post:
Blue Thunder (10-16-2011)
Old 10-16-2011, 08:26 PM   #4
brk-lnt
brk-lnt's Avatar
I just pay to have my boat winterized.
The last one I did "manually" was a twin-screw inboard setup, and used a procedure similar to what you describe. It really wasn't feasible to use a bucket of antifreeze method.
[insert witty phrase here]
Old 10-17-2011, 12:34 AM   #5
jst_4_kiks
jst_4_kiks's Avatar
Pming much needed information for you
The Following User Says Thank You to jst_4_kiks For This Useful Post:
Blue Thunder (10-17-2011)
This page was generated in 0.23281 seconds
