Old 09-12-2011, 05:50 PM   #1
JonLevis
Default Westerbeke Generator
My generator wont stay running...anyone know of any Westerbeke repair guys on/near/willing to service at the Lake?
JonLevis is offline   Reply With Quote
Old 09-13-2011, 09:20 AM   #2
welchislandman
welchislandman's Avatar
looking at their website shows irwin is a possible dealer
here is the links I found;
http://www.westerbeke.com/dealer/searchdealer.aspx
http://www.hansenmarine.com/dealers.html
welchislandman is offline   Reply With Quote
Old 09-13-2011, 09:45 AM   #3
I am assuming it is diesel powered, correct?
Diesels are very simple- They require fuel, air and compression to run and stay running.
Make sure your air cleaner is good (usually you will get more smoke if dirty).
Check to make sure you have a good flow of fuel to the injector pump. (I have found rags and other debris in fuel tanks (they run great with no load).
Other than that, you will need a tech.
Old 09-13-2011, 12:29 PM   #4
NoRegrets
There are several saftey circuits on the Westerbeke that will not let you run it. Low oil pressure, low water, and some have a CO2 sensor that if it is unplugged will not run.
A friend on mine could not keep his running and had to hold his hand over the air intake on the carborator. As soon as he took it off it would die. The carborator was rebuilt, sensors checked, plugs changed, fuel filter changed, air filter changed, and many hours of us standing around it to add our opinions on the issue.
In the end it tured out to be the fuel pump. He did get this advise from a local mechanic and then Irwin scheduled the repair.
NoRegrets is offline   Reply With Quote
The Following User Says Thank You to NoRegrets For This Useful Post:
JonLevis (09-13-2011)
This page was generated in 0.19623 seconds
