Go Back   Winnipesaukee Forum > Winnipesaukee Forums > Diving Winnipesaukee
Old 08-17-2011, 09:02 AM   #1
Aqua-andy
Default Does anyone have the numbers for empty pockets?
I was looking to do another morning dive tomorrow and thought Empty pockets would be cool to see.
Aqua-andy is offline   Reply With Quote
Old 08-17-2011, 09:22 AM   #2
Grant
Grant's Avatar
It's marked with a bottle if you know the general location.
Old 08-17-2011, 09:33 AM   #3
Default check out this thread
Diver 1111 has a sidescan sonar shot of the wreck and has a Lat/Lon on the left side of image.
http://www.winnipesaukee.com/forums/...=empty+pockets
Hope this helps.
Old 08-17-2011, 09:34 AM   #4
Aqua-andy
If no one has the numbers I will try looking for the bottle but my boat is pretty low to the water and I have not had much luck finding bottles.
Old 08-17-2011, 10:03 AM   #5
Grant
Grant's Avatar
That bottle can be tough to find. Senter Cove Guy and I had been on that wreck a number of times without the aid of the bottle, and one time missed it, then later in the boat drove around in circles for a while -- still no bottle. He came back another time on his PWC and found it no problem. Depends on the light and the surface chop (as well as how old & algae-covered the bottle is).
I know he attached a new bottle to something this year -- perhaps it was Empty Pockets...can't remember. At any rate, it turns out that whatever the target was, it already had a bottle attached that no one was seeing. He could shed some more light on that site.
But Diver111's SSS image, linked above, has some numbers on it. Regardless, I think if you're in that general area and look around @ 55 feet, you're likely to hit it. Good luck!
Old 08-17-2011, 08:31 PM   #6
Diver1111
Default Empty Pockets
Sorry I looked no coord. for that. Grant is right it sits at 55'.
Try this-as you look at the island-the NW side-almost to the end-look for 55 feet of water keeping the raft on your left. It's about 60-80 feet south from the raft, and out. If you went much further North you would start to round the N side of the island.
Old 08-17-2011, 08:41 PM   #7
Diver1111
Default The Steel Frame
The steel frame is also around the bend a few hundred feet from Empty Pockets.
Try this for the Frame:
N 43 34.408 W 71 19.491 Map Datum: WGS84
It's about 40 feet long, 25-30 wide and 2 stories high.
Old 08-17-2011, 09:16 PM   #8
Aqua-andy
I dove the frame when we were up on our last vacation. Sad to say most of it is only one story high now. I made sure I did not go under any of the beams because it looks as if the bubbles could cause them to fall. Thank you for all the info you have posted on the wrecks of the lake, it should keep me busy for a while.
Old 08-17-2011, 11:16 PM   #9
Senter Cove Guy
Senter Cove Guy's Avatar
Default Try These Coordinates For Empty Pockets
N 43 34.281 W 71 19.480
There are subsurface markers on the bow and the stern.
It's a 28', twin engine cabin cruiser. There is a dock on the northern tip of Diamond Island. It has several vertical posts. The rightmost post may have a windsock on it. Place that post in the middle of the very leftmost window of the cabin. Drive a straight line towards Diamond Island and look for a small, bright white clorox bottle about 15 feet below the surface. The old dead tree by the rocks on the shore should be nearly between 2 other relatively tall trees further up on the island.
Old 08-18-2011, 09:59 AM   #10
Formula
Default Directions
Turn left at rock that looks like bear,
Then turn right at bear that loks like rock
Formula is offline   Reply With Quote
Old 08-19-2011, 04:25 PM   #11
Aqua-andy
Thanks for the info those numbers put me right on top of the bow marker. I did 35 min on the wreck and still had 1800lbs left over so I ran over to the Lady and did another 30 min on her. I remember when I was a kid you would see cabin cruisers like Empty pockets all over the lake, Now they are all built like plastic toys. I saw a plack on one of the valve covers that said (Trojan Interceptor) was the boat a Trojan and they used a ford Interceptor engine? It had the distributor on the front of the motor so it had to be a Ford or Chrysler block, or something altogether different? All in all I thought it was a cool wreck to see.
Old 08-19-2011, 09:53 PM   #12
Senter Cove Guy
Default There's More To See Near Empty Pockets
If you leave the starboard bow of Empty Pockets and head towards Diamond Island, put yourself in 45 feet of water and swim south. You should see a small fiberglass boat. Keep going until you see a pile of 6-8 inch diameter white pipes. With those pipes on your left, heading south, find what looks like a black pipe in the muck. Follow it southward until you come to a cement and steel structure that we call "the lifeguard chair".
Old 09-24-2012, 09:10 PM   #13
Senter Cove Guy
Default Video Of Empty Pockets +++
This was shot by one of my dive buddies.
http://www.youtube.com/watch?v=InFBNMSOgOw
The Following 5 Users Say Thank You to Senter Cove Guy For This Useful Post:
crowsnest (09-25-2012), Happy Gourmand (09-26-2012), ishoot308 (09-25-2012), Just Sold (09-25-2012), SharkBaitDiving (02-19-2013)
Old 09-25-2012, 12:05 PM   #14
Steveo
Default No fish
Surprised not to see any fish during your dive. You would think it would be a good place for them
This page was generated in 0.76242 seconds
