Old 06-28-2011, 01:42 PM   #1
Mink Islander
Default Engine Starting Problem
My I/O bowrider has an intermittant problem starting. Infrequently, when you turn the ignition, the engine starts to turn over but quickly binds up. Turn the ignition again, it will bind up again but after several tries it will turnover more and more until it ultimately starts normally. Last weekend it took several tries to get the engine to turn over at all and after about 7-10 tries it turned over normally and started up.
What could be causing this? Failing starter motor? Thanks for the help.
This page was generated in 0.19217 seconds
