Any thoughts on repairing a cracked flue liner? Below grade but is cracked? Will morter fix this? I can get my arm into the spot that is cracked.
Thanks again lake friends |
If you use it for burning wood I would seek help before repairing it yourself.
The liner is meant to stand up to a chimney fire. I'm not sure that a liner can be repaired and be safe. I’d have a professional inspect the liner before you do anything. They do make a stainless liner that drops right down your existing chimney replacing the old one. Pricey but it also is very easy to do your own chimney sweep. |
I would first ask the material of current liner,if not metal then a stainless liner would probably be the best choice. I would for insurance reasons if for none other bring in an expert for a look and advice. Can't be to careful and I wouldn't want to find out in the middle of the night woken from a sound sleep there is a problem.
Call the Chimney Restoration Group they do that sort of thing. My husband had them come out to take a look at ours. We ended up tearing our chimney down and putting a new one up.....
[QUOTE=Champ81;145430]Call the Chimney Restoration Group they do that sort of thing. My husband had them come out to take a look at ours. We ended up tearing our chimney down and putting a new one up.....[/QUOTE
It ended up being cheaper to tear down the old block chimney and put up a stainless steal double wall pipe, doing all the work himself including makeing a larger hole in the vaneer inside the house to put in the new pipe thru the wall. In total saved a very big chunk of change... |
Tim is a great guy. He did work on our chimney, and was kind enough to travel all the way to Mass to work on my son's chimney. Very professional.
"Before you criticize someone, walk a mile in his shoes. That way, if he gets angry he'll be a mile away and barefoot!" unknown |
