Old 06-28-2010, 01:55 PM   #1
Electric Blue
Default Double standard for Sail boats ?
I saw something very interesting this weekend on the Lake. Everybody knows, or should know, that Sail boats have the right of way while under sail. While under power, sailboats have to follow the same navigation rules as power boats........but, it seems these sly sailboaters have added a new twist.
I observed at least two sail boats with there sails up, motor running, and operating as if they were under sail. They had no regard for my vessel or any other vessel as they cut across our bows, from my port side. I, as well as a few other vessels, gave way to the sail boats.......thinking they were under sail and had the right of way..... but they did not.
I was wondering if anyone had the same experience ?
Electric Blue is offline   Reply With Quote
Old 06-28-2010, 02:06 PM   #2
Lakegeezer
This topic has been discussed before -and the rule is, if a sailboat has its motor on, sails up or not, it sails under motorboat rules. The reality is, a sailboat may have the motor running to warm it up (ie, in neutral) or to push the boat towards better wind. If the sails are up, they may be in a position where the boat can't maneuver without risking a jibe or just going through the pain of switching the sails to the other side. Common courtesy is to give the sailboat with sails up the right of way. If the pilot is taking advantage of that, they are in the wrong.
-lg
Old 06-28-2010, 02:11 PM   #3
jrc
A sailboater with a small (under 25 hp) engine does not need to take a boater safety test. He might not know he doesn't always have the right of way, in fact many people believe that sailboats always have the right of way. So it might be ignorance not arrogance.
I see it all the time, I don't think it's fixable, don't let it ruin your day.
By the way I cut off a small boat on my starboard side on Saturday. It was obviously my fault, I didn't look where I was going. Scared the hell out of me and most likely the small boat operator, luckily all I got was a dirty look. I've been extra vigilent since, it only takes one mistake.
XCR-700 (06-29-2010)
Old 06-28-2010, 02:26 PM   #4
JRC,
1st I applaud you for honestly admitting a mistake... Unfortunately we are all human, and these things happen. The good news is you looked at what went wrong in the situation, and are now being vigilant in trying to make sure it doesn't happen again.
2nd, Remember we are all human....
now on to sailboats... whether they are under power or not, folks you know what most of them don't handle well they are motoring... so I just follow the general rule that they have the right of way and give them as much room as I can. Technically I know sometimes I have the right of way... but you know what, it really is less stress to just give it to them and not worry about it.
The Following 3 Users Say Thank You to LIforrelaxin For This Useful Post:
ishoot308 (06-28-2010), SteveA (07-01-2010), XCR-700 (06-29-2010)
Old 06-28-2010, 03:42 PM   #5
Pineedles
I wont speak to the ROW but i saw a sailboat coming into center Harbor on Friday with Main and Jib sail hoisted and under power. Winds were from the WNW and direction of boat was NNW. Seems to me gas was being wasted as the sails weren't properly set to catch the 2-5 knots of wind that was available. More of a detriment, than a help it appeared.
Pineedles is online now   Reply With Quote
Old 06-28-2010, 04:23 PM   #6
Zeke
JRC,
I think this can be an appreciated sentiment. The biggest and therefore fastest sailboats on the lake will only make between 7-9 kts under power. (Many can sail faster, but can't break hull speed onto a plane under power) If they are motor sailing, let them have a pass on right of way. I would also comment on the fact that they do handle and maneuver very well under power, so if they should need to give way, they are more than capable.
Zeke is offline   Reply With Quote
Old 06-28-2010, 06:18 PM   #7
NoBozo
I've sailed since 1966 including Solo Offshore. One of the problems power boaters have with sailboats is.... Power Boaters don't know HOW to sail and as such they are often suprised and ticked off when a sailboat suddenly changes direction for no apparent (to them) reason.
Sailboats have to Tack every once in awhile to get the boat Upwind. Power boaters don't know what Upwind IS and when a sailboat tacks (cuts) in front of them they are...............sometimes upset.
The case in this thread..a sailboat with sails up...but may be under power. A sailboat under power IS a Power Boat..sails up or not. If the power boater had a rudimentary knowledge of how sailing works they would be able to see that the sailboat is moving right along but there is NO Wind...the sails are luffing (Flapping). Sailboats do NOT sail with NO Wind...so therefore the sailboat...if moving right along with no wind is under power. Power boat rules apply.
So what is the lesson here..?? Power boaters need to LEARN Something About Sailing to protect themselves against those sailor kooks.... NB
The Following 3 Users Say Thank You to NoBozo For This Useful Post:
ApS (06-28-2010), Winnipesaukee (07-04-2010), XCR-700 (06-29-2010)
Old 06-28-2010, 07:21 PM   #8
Pineedles
Default NoBozo assumptions
"Power Boaters don't know HOW to sail"
I am an experienced seaman on both fresh and salt water, and therefore know how to sail and how to powerboat, as well as how to paddle both canoe and kayak, and row for that matter. Many powerboaters do know how to sail and all or some of the above. Generalizations like the above just stir the pot.
Old 06-28-2010, 07:55 PM   #9
I give the sailboat the right of way unless it is sails down in a NWZ then normal rules apply.
Old 06-28-2010, 08:14 PM   #10
no-engine
I've been boating, mostly sail, all my life and then some (born October). We are not in a court of law. I'm not going to nit pick on the rules. It all comes down to respect for others on water.
no-engine is offline   Reply With Quote
The Following 3 Users Say Thank You to no-engine For This Useful Post:
Jonas Pilot (06-28-2010), LIforrelaxin (06-29-2010), NoRegrets (06-29-2010)
Old 06-29-2010, 07:35 AM   #11
If it is running by motor power, then it's a motorboat.
Some small sailboats use oars for when there's no wind, which seems like a good matchup for a 12 or 14' sailboat which is usually a very lightweight hull. Seems like relying on oars as a backup would encourage appreciation for sails & wind.
In my opinion, one of the better sailing aids are those wind vane directional pointers as opposed to a simple yarn tell-tale. They take a lot of the mystery out of sailing, by defining the wind's driection with an easy-to-read directional pointer.
Old 06-29-2010, 09:08 AM   #12
jrc
since we are on this subject, when I pass a sailboat in open water should I pass on the bow or stern, windward or leeward? In other words where is the best place to have the wake hit you. Obviously the more distance the better.
Old 06-29-2010, 09:14 AM   #13
Sail and power at the same time???? Horrors....where is Al Gore when you need him?
Old 06-29-2010, 09:34 AM   #14
Bizer
Bizer's Avatar
Originally Posted by Electric Blue View Post
... I observed at least two sail boats with there sails up, motor running, and operating as if they were under sail. ...
There's always the likely explanation that the sailboat doesn't know the rules of the road.
Many moons ago, I was traveling across the lake when a larger power boat approached from my left. Sitting in the left seat was a babe in a bikini that the driver wanted to impress. He wasn't slowing down for anything. He even ignored my Rockefeller salute. This put me in a bad position: Should I maintain course-and-speed as required, or should I alter course?
As I learned in the Coast Guard, I prefer to let the other guy have the right of way. It's easier to maneuver around him than to guess whether he's going to maneuver around me.
Old 06-29-2010, 10:55 AM   #15
Misty Blue
Default Incomplete boating course
Here is a case against the eight hour safe boating course.
When the state(s) started to require safe boating certificates to operate on state waters a problem arose. Prior to that if you wanted to take a safe boating course you would go the the USCG auxiliary or the USPS for instruction. Both VERY good courses. They took a minimum of eight two hour classes and often ran for 12 to 14 weeks.
Unlike the eight hour (what I will call the MacBoat-ed) class, this gives the instructors time enough to teach and more importantly the students time to learn safe boating. Giving one of the origional classes I would expect the students to complete 20 to 30 hours of homework in their 8 to 12 weeks. How much homework did the state ask you to do to complete their course.
The weekly subjects would include one 2 hour class on:
Weather, marine engines, navigation, piloting, marlinspike seamanship and...
SAILING. The latter so that the power boater understands the constraints that a sailboat operates under.
The eight hour class may be good enough to keep you out of major trouble but it is not a well rounded education.
The bad news is that most people just want to do the minimum to get the ticket. Lets face it they don't want to spend a lot of Lake time sitting behind a desk and in the winter it is not a priority. The good news is that even if you have your boaters course you can still take the long course from the above instructors. The fact that we have our discussions on the boating forum tells me that you are intrested in expanding your skills. Give it a try. It is very rewarding.
Misty Blue.
Old 06-29-2010, 11:22 AM   #16
XCR-700
XCR-700's Avatar
As a powerboater all my life, I know VERY little about sail boats and have even less use for them. Its just not for me,,,
And I take NO offence at being lumped into a single pot of powerboaters that are ignorant of sail boat operation and I suspect that most of my close friends that are also powerboaters would fall into the same category and are not likely to be offended by being lumped together either,,,
I give sail boats as much room to maneuver as possible as I figure that sails up or down/under power or not they are a different beast than my powerboats and its just not worth having an incident and then trying to figure out who was on the right side of the paper rule. Cut em some slack and don’t give it a second thought and your day will not be interrupted by an unfortunate incident.
I think the positive message from this thread has already been well stated, people are human, accidents happen, and so long as no injuries occurred, don’t let it ruin your day.
Happy Boating!!!
Old 06-29-2010, 02:52 PM   #17
The biggest mystery in sailing, at least for me, is what direction is the wind? It seems to be changing direction quite a bit, like every couple minutes, it can change a little and sometime it changes a lot.
In the sailing world of words, are those yarn string directional aids correctly spelled as tell-tales or tell-tails?Been loose'n sleep think'n about that lately?
Someone in Holderness has a largish 14' sailboat, out by the road with a $5000 for sale sign. It comes with a built-in solar powered battery charger and a built-in electric motor similar to a trolling motor. Something tells me that one could be a tough sell at $5000., but one never knows?
When encountering small sailboats in my motorboat I usually cut in close just to stir em up and make em a little jumpy, plus I figure it adds some excitment to their cruise. As long as you don't slice em into two, what the heck and there's nuth'n more boring than sailing with no wind?
Old 06-29-2010, 03:38 PM   #18
Default Respect
I guess I feel a little different... Most sail boats are only using small kicker motors and here I am with this big inboard or outboard. I feel it's just respectful to always give them the right of way. It's really no big deal and I seem to always get a friendly wave out of the deal.
It's like helping a senior citizen with a grocery bag...you don't have to do it, but you know it's the right thing to do and you feel good about doing it!
Just my feelings on the subject;
Happy boating!
Old 06-29-2010, 03:45 PM   #19
Zeke
Happy boating!
Oh great, now I feel like I'm about to be put in the home
Still appreciate the sentiment though.
Old 06-29-2010, 06:36 PM   #20
Jrc, I would say in most cases try to pass to the stern. Even though a sail boat may look like it is not moving, if the sails are full it is, plus the winds in the lake can be variable in speed and direction. A gust will cause the sail boat to speed up which can screw up your plan pretty quickly. Usually sailboats try to maximize a good tack, in the case of my sailboat I will get pretty close to the shore. So if a sailboat is on a tack pointed toward the shore, you can be sure that it will be tacking soon, turning away from shore. If you pass closely in this case you are almost guaranteed to have to change course to avoid the sail boat. It is better to give the sailboat a wide berth to avoid being surprised.
Generally wakes don't bother sailboats that much because the sail, rudder and centerboard/keel make the boat very stable when underway.
Old 06-29-2010, 08:53 PM   #21
Pineedles
I guess I don't understand all this deference to sailboats. I know exactly where they are going and why they are going that way, (as long as there is a competent captain aboard) and that doesn't take long to figure out. Follow the navigational rules when engaging. That way you won't surprise the sailboat, who probably knows the rules of the water/road.
Old 07-01-2010, 08:46 AM   #22
Exclamation Always Provide the "Courtesy" of Passing Astern—When Practical...
"...I would say in most cases try to pass to the stern. Even though a sail boat may look like it is not moving, if the sails are full it is, plus the winds in the lake can be variable in speed and direction. A gust will cause the sail boat to speed up..."
1) Definitely pass astern of sailboats when allowed any choice in your particular circumstance: Even if it "appears" it is the longer path, it could actually be shorter—as sailboats "don't just stand still"!
...Very often...
2) Since 1972, among other sailboat types, I've sailed four personally-owned catamarans on Lake Winnipesaukee: within that timeframe the number of registered boats on Winnipesaukee has doubled—and they're mostly much-bigger!
Catamarans are "impacted" more severely by the wakes of powerboats, because waves are reflected back-and-forth between the two hulls which, particularly in light winds, brings forward progress to a near-halt. (Sometimes propelling one's catamaran backwards! ).
I've sold each of my catamarans—including two I owned at the same time: neither has returned to Lake Winnipesaukee.
3) The number of Winnipesaukee catamarans doesn't appear to have kept pace with "other" sailboat ownerships—and in my experience—it's powerboat wakes that diminish the sailing speeds that catamarans enjoy so much.
4) There's no sailboat that can "speed-up" like the Olympic-class "machine" they call the Tornado! At 20-feet—with 30-feet of mast—and weighing less than 500 pounds...it'll "squirt-unexpectedly" in the slightest of breezes. Upon its introduction, it was advertised towing a water skier!
With my crew—and while casually discussing the winds on The Broads with another sailing boat—I very nearly demonstrated being "launched" over my Tornado's transom when caught by an unseen gust of wind!
5) So finally, we come to the issue of "sailboats under-power acting as if they were 'just sailing'":
If you've ever tried to "drop" your sails in rough-waters, you'd understand why sailboats (those that are equipped with auxiliary power) must use power to get to a spot where the sails can be "dropped" with getting launched overboard.
Understanding things such as the above examples may be why—in earning the United Kingdom's "Boating Certificate"—one must demonstrate one's proficiencies at sailing an actual sailboat!
Old 07-01-2010, 01:00 PM   #23
[B]
Thank God we boat in NH and not the UK!
Old 07-01-2010, 05:23 PM   #24
rockythedog
Here's another double standard. We were coming back from Wolfeboro last night around 8:00 pm. Had nav lights on, 1/2 hour before sunset, and passed a sailboat with no lights heading towards the broads. Do the same rules apply for nightime navigation?
rockythedog is offline   Reply With Quote
Old 07-01-2010, 06:29 PM   #25
NoBozo
Was it a Sunfish .............or was it a 36' "Yacht". NB
Old 07-01-2010, 06:41 PM   #26
rockythedog
22-26 foot sailboat with main and jib. No light on the mast. Kind of dangerous at dusk.
Old 07-01-2010, 07:54 PM   #27
Rattlesnake Guy
Rattlesnake Guy's Avatar
Default After I think
I think the rule is a half hour "after" sunset. In practice it seems to be effected by the cloud cover quite dramatically. Reminds me of the rule growing up... to be home when the street light comes on. This took into account changes in the length of day, the severity of the weather etc. Never seemed to take in to account the fact that the bases were loaded and Frankie was at bat.
The Following User Says Thank You to Rattlesnake Guy For This Useful Post:
Newbiesaukee (07-19-2010)
Old 07-02-2010, 05:34 AM   #28
Exclamation Cloud Cover -- Early Darkness
"Cloud-cover" is right!
Some kids were retrieving a boat that had gone adrift: I took this photo in the late-afternoon last Summer!
Old 07-02-2010, 12:47 PM   #29
Misty Blue
Default They were probably right Rocky.
A sailboat under sail alone after sunset is required to show Red and Green running lights with a arc of 112.5 deg. forward each and one 135 deg. aft. That's the way that you know that she is a sailboat and is the "stand on vessel" and you are the "give way vessel".
If he starts his motor the vessel becomes a power vessel and he is required to turn on his mast head light to show it. He then must obey the regular nav rules just like a power boater.
For what it is worth, really nadda on the Lake, during the day he should show an inverted cone from the yard arm to show that he is also under engine power. Yo Ho Ho!
Hope this helps.
Misty Blue.
Old 07-02-2010, 01:29 PM   #30
Default Too freekin weird
While I'm reading your post I'm listening to Joe Walsh sing.."bases are loaded and Casey at bat,changes in every way.."
Rattlesnake Guy (07-04-2010)
Old 07-04-2010, 03:00 AM   #31
Winnipesaukee
Winnipesaukee's Avatar
No, I'm going to go with "most powerboaters do not know how to sail."
Sail fast, live slow!
Winnipesaukee is offline   Reply With Quote
Old 07-04-2010, 03:05 AM   #32
Winnipesaukee
Almost insulting! One of those catamarans is currently undergoing a restoration, but WILL be back on Winnipesaukee!
And everything weighs about 360, last I checked.
Old 07-04-2010, 09:01 PM   #33
no-engine
Wouldn't you be unlawful "cutting in close", assuming the distance?
Should a motorboat cut you close to add some excitement to your boating day?
Isn't it boring sitting on an anchored motorboat and rocking to the most minimal wave action? A sailboat is stabilized by the keel and sail as was posted back a bit.
Old 07-06-2010, 09:18 AM   #34
Justenuff
Default Motor Sailing
Many times while I was out on the lake in my 24 footer, the wind would die out, going to the south of Governer's Island for example, or through the channel between Bear and Pine Island. I had to fire up the motor to get through the channel without being a nusiance to the others in the no wake zone.
We also used the motor to add some more speed if we were in a hurry to get back to the mooring.
Wasn't trying to cheat, just sometimes Mother Nature doesn't blow the right way, or at all. I always followed the motor rules when I was under power, even if the sails were up.
Didn't have to worry about the wake, my boat didn't have enough oomph under motor to make one. Under sail though, it would sound like it was sucking in the water on the stern.
Justenuff is offline   Reply With Quote
Old 07-06-2010, 07:45 PM   #35
I think a sailboat captain deliberately tested my boating knowledge this morning. I was headed northwest south of Moose/Ship Islands and a sailboat was crossing from right to left in front of me (he was on a starboard tack), at about a 50 degree angle, relative to my course. With plenty of space to spare, I adjusted my course to starboard to pass about 300 feet behind him. When I got about 600 feet away he made a 130 degree turn to starboard (into the wind, so a tack) which now put him directly ahead of me and on the same heading. I immediately altered course to port and overtook him on his port side about 200-250 feet away. There was no visible legitimate reason for the sudden (and illegal, the sailboat was the stand-on vessel) tack and I think it was simply to see what I'd do. I smiled, waved and continued on my way.
Old 07-06-2010, 09:59 PM   #36
jrc
Dave R, why can't a sailboat tack when they are stand on? Seems like a pretty impractical interpretation of the rules. They are pretty much always stand on, so if there is a boat any where near them they can't tack?
Old 07-06-2010, 10:24 PM   #37
Stand-on and give-way only matters in a collision course, so a sailboat should be able to tack at will unless they are on collision course. Once a collision course is determined, the give-way boat should make obvious and early course corrections (I did) and the stand-on boat should maintain course and speed. Instead, this sailboat put itself on a (what appeared to be deliberate) collision course with miles of open water to play in.
Old 07-07-2010, 07:00 AM   #38
Lakegeezer
While it is possible that a sailboat captain is out "messing with the motorboats", it is more likely they were just sailing. Having the right of way to plod along at 4-7 MPH on any possible course, is part of the lure of sailing. Most sailboats move at no-wake speeds in the best of conditions. The 150' rule never applies, because at no-wake speed, passing inches away from another boat is OK. Sailboat racers are quite good at doing this. Sailboat pilots fly by using the wind, adjusting as it changes and tacking when needed. Often, they tack in one direction just enough to make a marker on the other tack, hoping the judgement of the wind was correct. Other times, they tack because there is a wind shift or lull up ahead to avoid. Most of the time, a sailboat captain can ignore other boats, especially the ones going 4-8 times faster, who have much more control over course. However, there are ways for a sailboat captain to be courteous. They can steer to pass at 150 feet so the other boat doesn't have to slow down. They can tack early to avoid traffic. They can avoid channels except when navigation requires it. But, at the end of the day, the wind is in charge and the rules honor that. And yes, sometimes one too many close passages by captain boneheads may trigger legal revenge against anything with a motor, innocent or not. If a sailboat is messing with you, accept it as payback for the sins of your fossil fuel burning brethren.
-lg
The Following User Says Thank You to Lakegeezer For This Useful Post:
ITD (07-07-2010)
Old 07-07-2010, 08:27 AM   #39
Wink Thank God We Boat in NH...(Somebody Said)...
I don't know what the lake was like where you were, but wind conditions were 12-knots—ideal for sailing—until about 10-AM. Winds suddenly slackened about the time I was supposed to quit for the day to meet an appointment.
At that time, I could see no other boat on The Broads!
Many are unfamiliar with sailboat operation and terminology, so your complaint only makes sense to a few.
(Even then, important details were left out—early/late...winds...sailboat under power...markers...speed...gusts...depth...windsurf er...GPS...et cetera...). "Adjusting your course" suggests the use of GPS—at a time when "there were miles of water to play in").
Unless you are actually on the sailboat you've complained about, there can be several reasons for his actions that would appear "unaccountable": One especially being, don't expect him to be relying on a strict GPS course to ply these waters.
The reasons are many for allowing a sailboat an excess of "elbow-room", especially with "miles of water to play in".
A "starboard tack" suggests the sailboat's skipper quite possibly never detected the direct approach of your boat. (If you could plainly see the skipper, he would have been on a "port tack").
Besides, tacking would be accomplished by a slow-motion turn to pick up "new" wind: If I'm reading you right, his turn of 180° would suggest an exaggerated response to your unanticipated approach. (Or possibly an emergency response to an abrupt change of wind direction).
Nearly always being the privileged vessel means it's possible this skipper was lulled into having a satisfying and carefree cruise: A loud signal would have indicated your intention to pass one way or the other and to give him time—at headway speed, incidentally—to anticipate your speedy approach and—the as-yet-undetermined intent of your actions.
Although I was not present—and you were unarguably "the burdened vessel"—one or two toots of the horn would have been the appropriate alert in this circumstance.
IMHO.
Old 07-07-2010, 10:22 AM   #40
jrc
Out in the open, it's usually pretty easy to go around sailboats. Sometimes a "race" will fill Saunders Bay or the area between Lockes and Welch, so a little more effort is needed. But come on they have big sails and move slow so missing them is never too much effort.
Now get them under power in the tight spots around Glendale, Smith cove or Pig Island and it's different story. Just assume they can't see you, and they will cut you off and live with it. Lifes too short to worry about who gets to the dock first.
Old 07-17-2010, 01:41 PM   #41
Wink Sailors: Birds of a Feather...
"...In my opinion, one of the better sailing aids are those wind vane directional pointers as opposed to a simple yarn tell-tale. They take a lot of the mystery out of sailing, by defining the wind's direction with an easy-to-read directional pointer..."
One of those arrived on a catamaran I'd bought—and was "powered" by a feather! (A "primary" feather, for those who've got to know.
I found that it was not sensitive enough!
In lake sailing, winds are often described as "flukey". (Not so much in ocean environments).
Though it's usually only durable enough for a week or so, my latest setup involves the use of a one-foot length of a mylar strand from a tattered tarp: tied to a breast feather from a duck, it picks up the slightest of zephyrs.
Any bird's feather works well—Loon or Seagull—just check downwind from a few that are preening.
Even when the lake appears to be a "flat calm"...there IS wind out there. (So you can start sailing much earlier in your day).
Old 07-19-2010, 09:04 AM   #42
Sailing looked like a blast yesterday, all day from what I could see.
Old 07-20-2010, 11:26 PM   #43
Winnipesaukee
Dave R: I think a sailboat captain deliberately tested my boating knowledge this morning. I was headed northwest south of Moose/Ship Islands and a sailboat was crossing from right to left in front of me (he was on a starboard tack), at about a 50 degree angle, relative to my course. With plenty of space to spare, I adjusted my course to starboard to pass about 300 feet behind him. When I got about 600 feet away he made a 130 degree turn to starboard (into the wind, so a tack) which now put him directly ahead of me and on the same heading. I immediately altered course to port and overtook him on his port side about 200-250 feet away. There was no visible legitimate reason for the sudden (and illegal, the sailboat was the stand-on vessel) tack and I think it was simply to see what I'd do. I smiled, waved and continued on my way.
That was you? I'm really sorry about that! (only kidding)
I have found this to be the most sensitive. Unfortunately, I can't find tapes anymore!
Old 07-21-2010, 05:39 AM   #44
Cool "Good" Wind—but Gusty!
Sunday, the 18th, "the blast" was only for the largest sailboats!
My waters were shared by two other small sailboats: a Phantom-15 and a Hobie-14. The old guy in the Phantom flipped over right in front of me. (After which, he "called it a day").
The Hobie-guy was a good sport—and continued to sail for at least an hour after a spectacular capsize while nearing The Broads. (While I didn't capsize, none of us had a "dry" sailing day!)
A J-boat and another large(r) sailboat definitely had their hands full!
Old 07-21-2010, 03:00 PM   #45
VtSteve
Default No matter how big the boat
some sailboat is out to get you
http://lyonsimaging.smugmug.com/gall...86606176_GgxD8
Old 07-24-2010, 08:16 PM   #46
Wink ...Or is it Memorex...?
Originally Posted by Winnipesaukee View Post
"...I have found this to be the most sensitive. Unfortunately, I can't find tapes anymore...!
I'll save some "dead" sacrificial tapes for ya.
But how can it be more sensitive than a feather? Audiotape has iron in it!
But speaking of tell-tales, one tell-tale has disappeared from mid-leach of my present sail. (Only the base remains). What was that tell-tale supposed to indicate?
Originally Posted by VtSteve View Post
One boat is very big, but they're both sailboats—and have to observe the same rules when the same space is shared by sailboats.
This 2008 case has been discussed forever: consensus is that the boats share equal blame.
About Wednesday, I'd like to start a thread on some elements in this case. (But not this Maltese-Falcon collision).
Wind can play a huge part when two boats are close enough to interact...but wind is rarely mentioned in this collision.
Old 07-26-2010, 04:03 PM   #47
Lucky1
Don't kayaks, canoes, rowboats etc have the right of way on the lakes in NH??
Lucky1 is offline   Reply With Quote
Old 07-26-2010, 08:44 PM   #48
Sort of, it's not really called "right of way", but human powered craft are stand-on to all other vessels.
Old 07-27-2010, 06:08 AM   #49
VtSteve
From what I had read about the Maltese incident, the smaller craft misjudged the wind when he tacked to get closer to it. The Maltese was on a steady heading, mid channel, and had already been buzzed by onlookers in small craft. My take was that the smaller craft acted like a PWC jumping wakes.
He also fled the scene
Old 07-27-2010, 04:18 PM   #50
Winnipesaukee
The midleach telltale is used to compare to the top and bottom leach in order to determine proper vang tension and twist in your main. Newer sailors can also use them to determine how far out their mainsail should be. If they flow to leeward, the sail is trimmed out too far, and vice-versa. "Make sure the telltales are flowing straight back!"
...Maybe I should try a feather. Hmmm...
Old 07-29-2010, 04:26 AM   #51
Red face Apologies to Cat Stevens...
"...The midleach telltale is used to compare to the top and bottom leach in order to determine proper vang tension and twist in your main..."
Proper vang tension is a big problem for me.
Maybe I should install a vang!
From what I had read about the Maltese incident, the smaller craft misjudged the wind when he tacked to get closer to it. The Maltese was on a steady heading, mid channel, and had already been buzzed by onlookers in small craft. My take was that the smaller craft acted like a PWC jumping wakes. He also fled the scene
1) Because of the immense size size of the Maltese Falcon sailboat—and the many admirers crowding the channel that day, they'd hired a harbor pilot. Although the damage was minimal, the harbor pilot returned to get the bow number of the much-smaller sailboat.
I don't see any sailboat "fleeing the scene".
2) It wasn't exactly "the wind" that the smaller boat misjudged: It was the sudden absense of wind—properly termed the "wind-shadow".
A "wind-shadow" that is large enough, can even affect the weather:
(Yes, I'm being followed by a wind shadow...winnnnd shadow, wind shadow...)
Old 07-30-2010, 10:20 PM   #52
VtSteve
Run Forest, Run !!!
Old 08-10-2010, 09:35 PM   #53
Default Monday
A number of us witness a sailboat coming out of Smith Cove under power. he was traveling about 15 mph and headed straight out to the Broads. A number of us had to stop and or change course. A clear violation of the 150' rule.
I'm beginning to think this is getting a bit much.
Old 08-11-2010, 01:51 AM   #54
Winnipesaukee
You did not witness a sailboat; you witnessed a powerboat.
The Following User Says Thank You to Winnipesaukee For This Useful Post:
ITD (08-11-2010)
Old 08-11-2010, 11:09 AM   #55
John A. Birdsall
Default license
I am now wondering if a person operating a sail boat is required to have a license? Seems to me that anyone operating a boat on the lake should be required to know the rules. Two sailboats could collide with each other, Kayaks could overrun each other.
Like one law, anysailboat over 12' or 13' must be registered. I must admit that I am not a good sailboat operator. I had a new 8' boat and I could only make it goe backwards and downwards. Yup, it went backwards and sank. When I got it ashore, it went back on the truck and I took the thing back!
Old 08-11-2010, 07:17 PM   #56
John, it's like power boats. Over 25HP, or 65feet in length. After those threshholds they need papers too.
This page was generated in 0.21556 seconds
