Old 05-25-2010, 06:49 PM   #1
Default Bow Numbers
Anyone know of a place in the Gilford area that makes custom bow numbers quickly?? I need to get some for this weekend for a new PWC and completely spaced it. I checked Sports and Marine Parafunalia's web site and they don't make them that I can see. Anyplace else around the area??
As always thanks for the help!!
Old 05-25-2010, 06:57 PM   #2
NoRegrets
Rob at Irwin's has a machine and I have also used Gator signs but have not been there this year to see if they are open yet.
NoRegrets is offline   Reply With Quote
Old 05-25-2010, 07:07 PM   #3
Where is Gator Signs?? I know I have seen that name near Gilford just can't remember where...
Thanks!!!
Old 05-25-2010, 08:44 PM   #4
Belmont Resident
Belmont Resident's Avatar
Default gator signs
Right caross from Gilford home center. Coming from wallmart go to 2nd set of lights take right. Take a left behind Dunkin donuts & gas station, go about 100 feet gilford home center on right and gator signs is on left.
He does good work and has great prices especially if your willing to do cash & carry and install it yourself.
Old 05-25-2010, 08:56 PM   #5
Dan, I use Gator as well. An easier landmark to look for is Watermark, they are between Watermark and the airport gas station. They will make them up for you on the spot and install them. On Mother's Day in the blowing wind they came outside, helped me strip the Ohio numbers off the Baha and installed new ones.
Sounds like the Yamaha is hitting the water? I am probably splashing mine too for the first run.
Old 05-25-2010, 09:01 PM   #6
bigRazor
bigRazor's Avatar
Just had our boat name done at Gator Signs on Saturday. Took him about 15 minutes. Would definitely recommend them.
bigRazor is offline   Reply With Quote
Old 05-26-2010, 09:13 AM   #7
welchislandman
welchislandman's Avatar
Dan, gator is the way to go. They are always great when I go there. Right next to dunkin donuts and agway
jeff
welchislandman is offline   Reply With Quote
Old 05-26-2010, 09:18 AM   #8
robmac
robmac's Avatar
I bought a number and letter kit from a pwc dealer for my last two boats,about 20 bucks and simply apply. Also cool design not plain colored numbers and never a problem from MP or CG when in FL.
Old 05-26-2010, 09:27 AM   #9
Sounds like Gator is the place!!
Thanks!!
Old 05-26-2010, 09:30 AM   #10
Codeman;
Yes, finally splashing the Yamaha! I am a little intimidated as I have never really owned one previously, just rented. Been going through the manuals and trying to remember everything the dealer ran me through when I bought it. Hopefully all goes well...
Old 05-26-2010, 11:48 AM   #11
Codeman;
You certainly didnt buy a slow one for your first... You will be quite surprised the first time you pin the throttle. The SHO is a screamer.
Old 05-26-2010, 07:16 PM   #12
Rattlesnake Guy
Rattlesnake Guy's Avatar
Gator is also a member of the forum family and donated a gift certificate to last years forum fest. (which I was lucky enough to win)
Old 05-26-2010, 10:00 PM   #13
Misty Blue
Default Mine is bigger!
Ishoot:
Mark at Gator is a real pro. He and the crew have my BZ.
PS. Ishoot 30-06.
Misty Blue.
Old 05-27-2010, 07:23 AM   #14
Gilligan
Gilligan's Avatar
Arrow Gator
I have used Gator before and also vouch for them.
They were in cramped quarters over at Silver Sands Marina when I first used them then they moved to a small store front building near Patrick's when I needed them again. It sounds like they have moved to a larger place near Agway now.
Officially, Gator Sign Shop‎ 43 Gilford East Drive, Gilford, NH 03249-7549
(603) 293-7344‎
Gilligan is offline   Reply With Quote
Old 05-27-2010, 08:49 AM   #15
jmen24
Originally Posted by Misty Blue View Post
Ishoot:
PS. Ishoot 30-06.
Misty Blue.
I will see your 30-06 casing and neck it down to 7mm, cuts holes at 300yds with 6" of drop, 160 grain factories. What am I?
I also recommend Gator, super turn around. Unless you are looking for something totally custom, give a call on your way up and they should be done when you get there.
Old 05-27-2010, 12:51 PM   #16
Originally Posted by jmen24 View Post
I will see your 30-06 casing and neck it down to 7mm, cuts holes at 300yds with 6" of drop, 170 grain factories. What am I?
7mm express?
Old 05-27-2010, 02:01 PM   #17
jmen24
Originally Posted by Dave R View Post
7mm express?
Close, kind of.
Old 05-27-2010, 03:12 PM   #18
280 Remington sometimes called 7mm/ 06. (The 280 Remington is a tiny bit longer in the shoulder.)
Old 05-27-2010, 03:14 PM   #19
jmen24
280 Remington
You got it.
Dave you were very close and depending on who you ask its the same caliper.
Sorry for the complete thread derailment, but I am glad to see more than one person here shares a similar interest.
This page was generated in 0.10735 seconds
