Old 07-07-2009, 07:48 PM   #1
66WINN
Default Power Steering
Over the past year my steering has become much more difficult and it's more difficult when it is colder. I have a 94 4.3 Mercruser Alpha I. The power steering fluid is full and the belt is tight. Would I need to replace the power steering unit or the rack & pinion? What should I check?
66WINN is offline   Reply With Quote
Old 07-07-2009, 08:53 PM   #2
trfour's Avatar
Post
There is a filter in the power steering pump that needs tho be changed periodicly, per your owners manual. However, if my memory serves me, there is a cable that goes to a slave hydrolic cylinder, that may be in need of replacement. Some cables have a grease fitting and if it hasn't been serviced the cable should be replaced.
I would recommend that you find the problem now, as opposed to finding out after a collision from not being able to steer the boat.
Hope this helps.
Old 07-07-2009, 10:39 PM   #3
NightWing
NightWing's Avatar
Talking
The cables may need lubrication. Who does your layup and spring launch?
In the dead of night they come - Swift - Silent - Savage
Old 07-08-2009, 11:44 AM   #4
jst_4_kiks
jst_4_kiks's Avatar
check/lubricate the steering cable. if it really stiff, just replace it. not worth the time trying to lubricate it then drive and lube some more. start fresh with a new cable in the older boat and it will good as new
This page was generated in 0.28427 seconds
