Old 02-21-2026, 06:20 PM   #1
winterharbor59
Default Water trampoline advice
I’m looking for advice on renting or purchasing a water trampoline , as well as info on types and installation.
We previously had a traditional wooden raft but gave it away as it was too heavy to handle ourselves & expensive to hire install & take out every year.
Now the grandkids are swimmers & we’re wondering if we could handle one of these ourselves once the initial mooring is established.
winterharbor59 is offline   Reply With Quote
Old 02-21-2026, 06:43 PM   #2
Default Easy!
They are certainly a lot easier than handling a fully built raft!
Once you have a mooring installed, just simply blow it up with air and attach to your mooring and you’re ready to go.
The size you get as well as accessories will determine how involved it will be. We had a small 8’ or 10’ diameter trampoline and very simple for one person to handle and install.
You will want a good air inflator for both blowing up and removing air at end of season. You will also need to clean it before storage at the end of the season. Fold and store properly every winter and you should be good for a few years!
Go see BART at Parafunalia in Gilford and he can get you set up with everything you need.
Good Luck!
Old 02-21-2026, 07:00 PM   #3
tbonies
Go big for the grandkids and be a hero. Get the 25 footer from Parafunalia. Easy to self install...
tbonies is offline   Reply With Quote
Old 02-21-2026, 08:17 PM   #4
winni83
See this thread.
https://www.winnipesaukee.com/forums...ad.php?t=30172
Old 02-22-2026, 02:26 PM   #5
FlyingScot
The big ones in my neighborhood have not lasted more than a couple of summers each
Old 02-22-2026, 02:54 PM   #6
Believe Parafunalia installs, removes and stores for a seasonal price. You must purchase from them.
Old 02-22-2026, 03:49 PM   #7
winterh
Years ago I had a big one with a steel frame for the top pad. It was a lot of fun for the kids but a pain to take in and out. I now have a 16 foot all in one where the inflatable section is connected to the jump pad. Much easier. just pull up to shore or dock and lift and drag onto shore and then deflate. Best with 2 people but have done it myself Bought at sports Parafunalia. Leaks now and then but easy to fix. Accessories like the log roll and the blob are well worth it. slide not so much.
Old 02-22-2026, 04:20 PM   #8
winterharbor59
Thanks winni for the link. Winterh, could you clarify the differences between the types you’ve had. And any idea why your experience with repairing leaks differs from that on winni's link?
Old 02-23-2026, 06:48 AM   #9
winterh
The first trampoline I had was purchased over 20 years ago. It was very large. At least 20 ft if I remember right. The circle was inflatable but then there was a round series of metal pipes with the netting connected between them much like a ground based trampoline. That was then laid on top and secured with straps. I think the company stopped making them and now they are all one piece. Much heavier and harder to deal with but I will say the bounce was better. As to leaks I used to just try to listen for the sound but once I discovered the system of spraying a bit of simple green over a highly inflated trampoline (not while in lake) and watching for bubbles it became pretty easy to find them. Repairs are easy with the rubber repair kits once the leak is found. As an interesting side note. I was at a hockey camp with my son in Minnessota over 20 years ago sitting on the beach with another hockey dad watching the kids play on the trampoline the camp had. I mentioned how I lived on a lake and needed to get one. Turned out the guy owned the company. I think it was aquajump or rave or something, i forget exactly. Had a great conversation about how he came up with all the different inflatable product ideas and how they were made. He called the office and gave me a deal and it was waiting for me when I got home.
This page was generated in 0.07328 seconds
