Old 11-20-2006, 03:36 PM   #1
jnaughton
Default Alpha One Drive
For the 2nd time in 2 years the gears have dropped on my 1986 Alpha 1 Drive, first time was not enough gear lube, this time there was plenty of gear lube (32oz according to mercruiser), is there anything else that could cause the gear drop to happen?
jnaughton is offline   Reply With Quote
Old 11-20-2006, 03:39 PM   #2
Define "drop" please.
What engine do you have? I think Merc put Alphas behind 454s for a few years in the 80s. Not such a great idea, it turns out.
Old 11-26-2006, 11:29 PM   #3
jnaughton
They rod with the gears has moved down about 2 inch's, metal shavings, inside the lower unit, it is a 1986 260 mercruiser, alpha 1......
John J. Naughton IV
Old 11-27-2006, 09:36 AM   #4
MJM
Anyone got a diagram, or a link to a site where I can see a visual of these things? I'm getting worried this is something I should be checking and I'm not....
MJM is offline   Reply With Quote
Old 11-27-2006, 09:59 AM   #5
Yikes, that sounds awful. I dunno how much it cost to have fixed, but you may want to price one of these instead: http://www.sterndrive.cc/ They are VERY reasonably priced.
Old 11-27-2006, 10:15 AM   #6
www.dougrussell.com has excellent parts diagrams online.
Old 02-07-2007, 01:56 AM   #7
dlindberg
Alphas are not meant for high HP.
If this is the case you will need to be very careful with it. Easy takes offs, straight as possible and don't let it come out of the water.
dlindberg is offline   Reply With Quote
Old 02-08-2007, 11:16 AM   #8
Dave (or anyone really),
Have you or anyone you know used one of these aftermarket drives? It would be interesting to here about someones experience with them........
Old 02-08-2007, 12:15 PM   #9
Woodsy
A friend of mine put two of them on the back of his old Baja and they worked quite well. He went from two RH rotation Alpha SS drives to a LH/RH rotation setup with the Sterndrive Engineering units. He had no problems with the drives at all...
PM me. I will be working the NHRBA booth at the Boston Boat Show and if the Sterndrive Engineering guys are there I can get you some info...
Woodsy
Old 02-08-2007, 03:17 PM   #10
Have you or anyone you know used on of these aftermarket drives? It would be interesting to here about someones experience with them........
I don't know anyone that's used one. I just know they exist and wanted to be sure jnaughton knew of the option.
I think I'd be tempted to try one if I needed more than $1000 worth of parts and labor on an old drive. $1200 for a complete drive assembly is really cheap. 3 year warranty on the big parts is enough of an incentive to me.
Old 02-08-2007, 03:36 PM   #11
Woodsy
Woodsy, Thanks for the offer to pick up information... At the momment though I don't have a Merc. or for that matter now that I think about it do I know any one that does.... I was just looking to see what kind of feed back on these drives there was... and if you friend is a Forum memeber ask him to post ...... because who knows what I will own in the future.........
Also, I looked quickly at there website and it is pretty informative...........
This page was generated in 0.16196 seconds
