Old 06-26-2025, 12:02 AM   #1
Winilyme
Default Roofing Systems
We'll need to replace our Meredith roof in the near future and I'm investigating options. We have a post and beam cottage - one floor, 1,500 SF. We have cathedral ceilings in about 80% of the space. Current roofing is asphalt - no leaks at this time and I believe it to be between 15 and 20 years old. Roof pitch is minimal (very easy to walk on). The majority of the cottage has interior pine shiplap mounted to the topside of the ceiling beams. On top of that, I assume, there's plywood, tar paper and the asphalt shingles. I don't believe there's insulation of any sort. Rain is certainly noticeable from a noise perspective, but not bothersome except in the heaviest of downpours. Minimizing noise is important to us.
I've been considering a metal roof...but not the standing seam type which I worry would (1) be noisier than what we currently have, (2) more difficult to traverse, (3) more susceptible to damage and (4) maybe not a good solution for one section of our roof that has a super minimal roof pitch. Instead, I'm researching metal roofing shingles. Why you ask? I like the idea of a super long-lasting roofing system and the associated low maintenance requirements. But, as this product seems to be relatively new, I haven't run into any first hand knowledge within my network.
Do any Forum members have experience with this product? Can you speak to positives and negatives? Are manufacturer claims accurate when they state these roofing systems are no noisier than any other roofing products and can in fact be quieter than them (due to the stone coating affixed to the shingles). Can you recommend lakes-region roofing contractors that are experienced with metal roofing shingles? Finally, are composite roofing tiles another viable option?
Any and all feedback is appreciated. Thanks.
Old 06-26-2025, 07:29 AM   #2
smith point boater
Default Roof
We have metal roof shingles and they've been great. They are 8-10 yrs old. We used Total Concepts Roof (603-528-6767). The one thing I advise to consider is snow sliding off the roof. There is no stopping it (Part of our roof has a pretty good pitch and part is mild) so be very concerned about any areas over an entry door or where you traverse a lot.
We had one or 2 issues over the years with caulking drying out around a skylight and TCR has always responded quickly to reset it. No complaints.
smith point boater is offline   Reply With Quote
Old 06-26-2025, 08:06 AM   #3
The house across the street from me had no roof insulation. They had insulated plywood sheathing installed, looked like it was about 3" thick, and metal roof over that.
Old 06-26-2025, 09:25 AM   #4
John Mercier
I don't know if the manufacturers would warranty the composite roof on the minimal pitch.
So always good to check with the manufacturers rep of what composite product you might go with.
If you are adding insulation board, they will help quiet the sound.
Old 06-26-2025, 09:25 AM   #5
pondguy
pondguy's Avatar
I second Total Concepts they did my roof in metal almost 15 years ago great job no problems ask for Ron.
Old 06-26-2025, 10:36 AM   #6
Just curious Winilyme, If you're not experiencing leaks why do you want to replace. Just being proactive or are there obvious signs of roof wear on the current shingles??
Reason I ask is just because your roof is 15 years old you could easily get another 15 years out of it if its currently in good shape. The asphalt roof on my island home is also 15 years old but after inspecting it I found it to be in excellent shape and good for at least another 10 + years...
Old 06-26-2025, 11:28 AM   #7
We went over an existing shingle roof with metal on the island. I did not find it loud at all.
Old 06-26-2025, 03:23 PM   #8
Default Cost factor of metal shingles versus asphalt ?
What is Cost factor of metal shingles versus asphalt ?
TIA !
Old 06-27-2025, 12:09 AM   #9
Winilyme
Firstly, thanks to all for your responses. Here are my thoughts and answers to questions:
Smith Point Boater - Wondering if you've thought about installing roof snow guards above those areas where sliding snow is a problem. In any event, we're not here in the winter (so we're not going to be injured) and our roof pitch is quite minimal (guessing a 3/12 or 4/12 pitch). I just checked out TCR's website and will be reaching out to them to learn more.
Biggd - Do you know - did your neighbors install the insulation to moderate heat gain/loss or was it more to minimize noise? Did they have asphalt before and do you know if they've experienced any increase in noise?
John Mercier - Good advice regarding warranty and I'll be asking TCR about noise control - if it's even necessary. In our case, it only would be if the noise expected would be worse than what we experience with our current asphalt roof.
Pond Guy - I will ask for Ron.
ishoot308 - A very good question. We bought our home ten years ago. The home inspector said the roof was in good condition so I thought no more of it at the time. I now regret not asking when the asphalt roof was last replaced. I believe between 15 and 20 years old since the prior owners built an addition that doubled the size of the home in the mid-2000's or thereabouts. The roof on the whole house seems to have aged exactly the same so I'm guessing the whole house was re-shingled at the time the addition was built. As far as leaks, the only leaks we've had have occurred in the last five years. In one case, it was a simple nail pop and fix. The biggest culprit has been the flashing and sealant around our field stone chimney. Leakage here recurs every other year and I go up with a tube of roofing cement, make a mess of the joints (and myself) while managing to temporarily stop any further leaking. Our asphalt shingles are not architectural; just your basic run of the mill. I've always believed that getting 25 years out of them would be a stretch. So, yes, it's really all about me wanting to be proactive AND I'm attracted to a roofing system that is very low maintenance. Peace of mind I guess.
Codeman671 - Did you install metal shingles or standing seam?
bigdog - My research thus far has me thinking that I'd pay quite a premium for the metal shingle over asphalt. I think it's more about the product versus labor costs. I need to get a better feel for this. I also need to understand better what manufacturers are creating the best product.
Old 06-27-2025, 07:41 AM   #10
smith point boater
The ones they had at the time really weren't sufficient. I could look into it again as there are always product advances. Ron will be able to advise you.
FYI - they put the shingles right over the existing single layer shingles. Very little if any noise problems.
Good luck
Old 06-27-2025, 08:09 AM   #11
It was an old A frame camp that had 2X6 T&G boards and asphalt shingles, no insulation. They stripped off the shingles and installed 3" insulated plywood boards then metal roof on top of that. I'm not sure if they put any additional insulation on the inside ceiling. The house was bought, remodeled, and flipped, now has a new owner. Personally, I would have torn it down and built a traditional style house, but the flipper wanted to turn it over quickly.
I have a metal roof over an existing asphalt roof, purchased it like that. I don't notice much noise, but the snow does slide off pile up high against the house.
The owner offered it to neighbors first before putting it on the market, I regret not buying it. The flipper bought it for $550, did a complete remodel including a new septic system and sold it for 1.3 million all in under 8 months, for an A frame!
Old 06-27-2025, 10:06 AM   #12
We did a standard exposed fastener metal roof, not standing seam or metal shingles. Forever Metal Roof did ours. Being on an island with lots of trees around I wanted the simplicity of being able to remove a damaged panel in the middle should it happen without stripping it all back. Plus, it was a cost savings on a seasonal home that was well over budget as it was. I also knew that I would be gone long before the warranty ever expired. Chances are most people have moved on before the lengthy warranty periods run out on these.
We had a good asphalt roof under it was that less than 10 years old, and it was insulated on the inside. It was not loud at all.
Old 06-27-2025, 06:25 PM   #13
NH.Solar
NH.Solar's Avatar
If you framing is solid and there is only one coarse of shingles in fair shape currently on the roof I would agree with Codeman, install the steel right over the shingles. But to take it one step further I'd suggest running 2/3 purlins 2' apart and in length with the ridgeline and placing 1.5" foam board in between the purlins. I did this on the shell of my entire 24 x 40barn when I built it and then Tyvek'd outside that and even before adding any additional insulation it could be heated easily with a woodstove and stayed cool in the summer as well. My neighbors across the street re-roofed their cottage home a few years back, which had about a 6/12 pitch shingled roof, and at my suggestion did the 2x3 (or 4 if they're cheaper) purlins with 1.5" right over their shingles and are thrilled with it. Less rain noise and with the increas in the R value the home is a lot more temperate.
The key to this on a low pitch roof is how well and sturdily your framing was done and if you aren't well qualified to judge this for yourself be sure to have an engineering study done. We have to do thisby law on every solar roof installation and a basicstudy on a moderate;y sized house usually comes in under a $1,000. Money well spent both for piece of mind ...and probably still less than it might cost to have the old shingles removed and properly deposed of
Peter
NH Solar
Old 06-29-2025, 09:19 AM   #14
sky's
first and foremost you have to have a clear understanding of were the snow is going to land when it slides off your roof. while some people praise there choices to put on a metal roof i have met people that wish they didn't. for example i met a lady that had a metal roof put on and when the snow slides off
it lands in front of her garage doors. when this happens it hardens and your not going to simply shovel that pile. look at your landscaping. if your bushes are going to be receiving the snow then kiss them good bye. railings are another one i've seen entire railing systems destroyed by the snow sliding off. metal roofs like vinyl siding have there place but not always the best choice for resdiential. there are ice rakes that can try and manage the downfall you'll see them on alot of commercial buildings. good luck with your selection. im old fashioned stay with asphalt.
Biggd (06-29-2025)
This page was generated in 0.16380 seconds
