Old 03-02-2025, 07:26 PM   #1
MRJS
Default Are there any lakehouse needs that are currently unmet by local contractors?
For example, do you ever find yourself saying, "I wish there was somebody who can handle (blank)."
MRJS is offline   Reply With Quote
Old 03-02-2025, 08:42 PM   #2
Not unmet, put difficult to schedule. Spray foam insulation and floor leveling
Old 03-03-2025, 10:19 AM   #3
If you need a spray foam guy I have a few recommendations. Foam Fellas in Dover did all of our storage unit ceilings as well as my business partners home and was fast and cheap. Northwoods Spray Foam did our home in Gilford.
Old 03-03-2025, 10:58 AM   #4
FlyingScot
We have been fortunate to have a number of very good tradesmen at our house. But it is very hard to find contractors or others to do small jobs. If a new contractor hangs out a shingle, and then is responsive and professional and does good work, he will be successful pretty quickly
Old 03-03-2025, 11:20 AM   #5
im looking for a price to have the underside of my cottage spray foamed - only 19X22. It is on post and beam so underneath which is about a 3-4 foot craw space area is wide open to get to, such a small job have not had any luck. I wanted to do closed cell, have been hoping a neighbor of mine was going to do something like this in their unit as my job is so small id be paying for a full truck and job so to speak
Old 03-03-2025, 11:49 AM   #6
I would love to find someone to urethane the interior walls of, replace the carpet on, and level the floor of my camp porch.
Old 03-03-2025, 01:24 PM   #7
Check with your insurance on spray foam. Have read articles many are not insuring if you have it due to mold issues in voids
Old 03-03-2025, 02:04 PM   #8
John Mercier
Lakes Region Chamber of Commerce is holding a home show at the Belknap Marketplace (mall) in April.
Maybe some companies/contractors there that might take on some of this?
Old 03-03-2025, 02:27 PM   #9
The good news is I'm the agent lol, but that aside, as long as closed cell spray insulation is applied to dry material there should not be a mold issue, being closed cell, it does not allow air or moisture to pass through so the material is it sprayed onto needs to be dry and free of moisture at time of application, open cell can let air and moisture in if used in open areas after applied
Old 03-03-2025, 03:37 PM   #10
Winilyme
Do you have even the slightest idea what your job would cost? I ask because I've been thinking of doing the same at our post & beam cottage. Sounds very similar to what you're looking at although a little bigger. Main purpose is insulation and moisture barrier. But if this is a break the bank endeavor, I'll probably refrain.
Old 03-03-2025, 03:40 PM   #11
I do not, I made some inquires last year (i should have done it when i rebuilt in 2017) and what I got for answers is that it is a small job, or I would have to charge you for a whole day and they didn't show when said they would. My thoughts are the exact as yours, moisture and insulation for the ealry spring season and fall the floor gets really cold and obviously transfers to everything else, and cost concern was the same
is there a energy group for NH, like MA Saves, that comes out and does an assement of your property and then offers names/discounts through grants for energy saving jobs???
Old 03-03-2025, 04:05 PM   #12
Winilyme
I just check NH Coop's website...under the 'Save Energy' tab. It states:
Energy Efficiency That Pays
Looking to make your home more energy efficient and more comfortable? The Home Energy Performance Program will reduce your energy costs and improve the comfort of your home. This program offers access to participating contractors, who will conduct an energy audit of your home and recommend improvements like air sealing, added insulation, energy-efficient appliances and more. If your home qualifies, the program will pay up to $6,000 of those improvements. Project financing options are also available. Learn more here. Get started…see if your home qualifies by using this home energy calculator. Questions about the Home Energy Performance program? Please contact Jerry Spaulding at [email protected] or (603) 536-8663.
Let me know if you learn anything more and/or if piggybacking another job might result in a better cost outcome for each of us. I'm in Meredith.
Old 03-03-2025, 06:54 PM   #13
I went to the link and entered the information in to see if I qualify. I do not use enough KWH to qualify for grant programs, the funny thing is in checking my KWH somehow I went from 19 in January 2024 to 46 in January 2025, but everything is shut down. Apparently there is no way to argue that, I just got off the phone. They are saying something must be plugged in and using energy. There is nothing plugged in
The Following 2 Users Say Thank You to AC2717 For This Useful Post:
stingray (03-08-2025), WinnisquamZ (03-03-2025)
Old 03-03-2025, 08:09 PM   #14
Someone could have tied into your source
Old 03-03-2025, 08:14 PM   #15
Winilyme
Do you have a bubbler? My January statement doubled YOY due to minimal bubbler operation during last year's warm winter compared to this year.
Old 03-03-2025, 09:02 PM   #16
Lake Fan
The most unmet need I have for contractors is to return phone calls, actually send a quote after looking at a job, and starting and finishing the job on schedule.
Take care of those items, and customers will beat a path to your door.
Lake Fan is offline   Reply With Quote
Old 03-03-2025, 10:45 PM   #17
garysanfran
Sounds like there's enough skill set. Just not enough to fill the needs.
Gary
~~~~_/) ~~~
Old 03-04-2025, 05:47 PM   #18
I do not, they were saying it could be a few phone charger cables plugged in or something small running. Too far for me to care about the few extra dollars it is costing me to check. But I will when I open up in April
Old 03-04-2025, 07:52 PM   #19
We had that happen, our bill was so high they actually told us something was wrong. We could NOT figure it out but finally it was a septic pump. So if you have one, you could check that.
Old 03-05-2025, 10:32 AM   #20
loony
loony's Avatar
Just discovered this link:
https://www.lakesregionbuilders.com/find_a_pro.php
It might help in filling some the unmet needs.
Old 03-05-2025, 01:24 PM   #21
DesertDweller
Could not agree more. We have owned our house for about 12 years now and it's gotten progressively worse. Really surprises me that no one from out of state doesn't take advantage of the opportunities up here.
Old 03-05-2025, 02:04 PM   #22
They are. My eyes and ears are telling me there are many more electricians, plumbers and painters in the area than a few years ago. Framers and finish carpenters not so much. HVAC employees are scarce everywhere.
Work is plentiful, so that return phone call may never come. Got to keep calling. State licensing has a lot to do with the labor shortage. Sununu promised he would address it during his last term and he didn’t.
The Lakes Region isn’t everyone “cup of tea” for many reason. Me, I find it a wonderful place to live.
Old 03-05-2025, 02:33 PM   #23
John Mercier
Are you suggesting we need licensing for framers and finish carpenters?
Sort of confused on the post.
Old 03-05-2025, 04:42 PM   #24
I thought NH broadened licensing reciprocity on a number of occupation last year. Not sure which ones. I always thought some trade groups/professions made licensing difficult to prevent new competition.
Old 03-05-2025, 06:23 PM   #25
The Real BigGuy
I agree with the last.
In MA they decided you needed an LSP (Licensed Site Professional) to clean up hazardous waste sites. Initially you had to pass a test, be a degreed scientist (engineer, geologist, hydrogeologist, etc.) or have x number of years of experience in the field. It took the so called “professionals” a few years but, they eventually eliminated field experience as a substitute for a degree. I always looked at it as them saying, “We can’t have THOSE people as part of OUR group.”
Old 03-05-2025, 07:40 PM   #26
John Mercier
They may have.
But his post was that he is seeing more of the licensed professions in the area, and not enough framers and finish carpenters.
Old 03-05-2025, 08:45 PM   #27
DOGE is going to eliminate the EPA so you will be able to build anything anywhere regardless of hazardous waste.
Old 03-05-2025, 08:51 PM   #28
I just talked to an electrician at dinner tonight and he said things are definitely slowing down. He's been straight out for the past few years now. He said in the past he would give estimates and people would just say "do it". Now he says they are just doing the bare essentials, only what's absolutely needed.
This page was generated in 0.12191 seconds
