Old 08-22-2023, 03:17 PM   #1
Frdxplorer
Frdxplorer's Avatar
Default Dock Install Recommendations
Forgive me, I thought I saw a thread about dock construction recently, but I am having a hard time finding it. Can anybody point me in the right direction? If there was no such thread, does anybody have any recommendations?
Frdxplorer is offline   Reply With Quote
Old 08-23-2023, 07:58 AM   #2
More details are needed to properly recommend.... Like location, style, etc.
Watermark can handle most anything but they are very busy.....
Center Harbor Dock and Pier is also recommendable......However not sure they do permanent docks
Old 08-23-2023, 10:03 AM   #3
Blyblvrd
I love Center Harbor Dock and Pier
Blyblvrd is offline   Reply With Quote
Old 08-23-2023, 12:14 PM   #4
The Real BigGuy
Temporary or permanent dock?
Old 08-23-2023, 01:08 PM   #5
Frdxplorer
Frdxplorer's Avatar
Thanks for the replies so far. Looking at temporary (crank up) dock and possibility of boat lifts. We are in the Wolfeboro area.
Old 08-23-2023, 02:23 PM   #6
watrskir
Default Wolfeboro Dock Company
Wolfeboro Dock Company- 6039980305. Ask for Shawn.
watrskir is offline   Reply With Quote
Old 08-23-2023, 05:52 PM   #7
Arrow You're Gonna Need Three Big Trees...
I'd suggest examining your shorefront for a suitable base.
A neighbor had a big concrete block poured for his crank-up dock, but apparently winter's winds caused the suspended dock to sway enough to break one side of the new base off.
You'll need a big tree to carry the main weight of the dock. Locate the dock between two large trees so sway can be kept to a minimum.
If I ever replace my piling (permanent) dock with a crank-up dock, I'm going to attach the base to a giant boulder which is directly in front of the cottage.
Old 08-24-2023, 10:33 AM   #8
...A neighbor had a big concrete block poured for his crank-up dock, but apparently winter's winds caused the suspended dock to sway enough to break one side of the new base off.
Center Harbor Dock & Pier did our crankup back in 2014. Pulley for the cable is anchored to a large tree up 15 ft or so, with the winch below at shoulder height. The tree is nearly in line with the dock, so that worked well and avoided the need to pour a block. Although we don't get quite the wind the broads side of LI gets, they did provide guy ropes on both sides to keep side winds from working the frame back and forth, an otherwise long lever trying to break the shore attachment. When I crank the thing up late fall each year, I make sure to have those guy lines snug.
Old 08-26-2023, 04:21 PM   #9
Leoskeys
Northeast Dock and Barge in Wolfeboro was great for us, we worked with Sean Sicard.
Leoskeys is offline   Reply With Quote
This page was generated in 0.48774 seconds
