I had the tankless coil on the boiler disabled some years ago in order to install an electric water heater. Reason: at that time oil was expensive and electricity was cheap. Now both are expensive.
The 53-gallon electric water heater is now turned off to save electricity. I'd like to calculate the cost to get hot water from the tankless coil and compare this to other ways of getting hot water. How can I calculate this? My average hot water need: about 5 gallons per day for one shower and washing dishes. About 15 minutes a day. |
The tough to calculate part of this is the boiler stays hot so that you can have your 5 gallons of hot water in a reasonable time. But I would guess that maybe a gallon a day to keep the boiler hot. 5 gallons of hot water is in the noise.
A gallon of OIL a day? What does "in the noise" mean?
This calculator might help: https://www.efficiencymaine.com/at-h...st-comparison/
I entered values for 5 gallons a day, price of oil $5.80 a gallon, and cost of electricity $.1658 per kwH. The result was $74 a year for a tankless coil and $55 a year for the electric water heater. That doesn't seem right. I think both figures are too low, otherwise I would not have turned off the hot water tank. The calculator doesn't include the size of the water tank. In any case, "oil boiler with tankless coil" is the most expensive on the bar chart. |
A ten minute shower uses 25 gallons of water assuming the shower head has a water restriction device built in. I think you are really lowballing your daily use…
#6 | |
For 5 gallons a day, I got $65 for oil and $86 for electric. The thing about using your boiler is that the boiler temperature needs to be kept hot enough to give hot water in a reasonable time. This uses additional oil versus what it would take to just heat the 5 gallons a day. I'm wondering if your link takes this into account. I actually think it may based on my original guess of 1 gallon a day. "In the noise" means that if you could instantly heat 5 gallons of water with oil and not have to keep the boiler hot, it would probably take a gallon of oil a week rather than every day. But in the end these are just estimates and the difference in cost negligible between oil and electric. It would take far too long to break even on the cost of changing over to justify it. I would just turn the electric heater back on and forget about it until the tank fails. |
#7 | |
#8 | |
I reread all the replies in the other thread about saving money on heating water and did some more research. I'm leaning toward putting a timer on the water heater and running it 1 hour a day. I'm thinking this might be the simplest and cheapest solution. The water heater is 4000 watts, or 4kWh per hour = 120 kWh per month x 17 cents per kWh = $20 a month. Thoughts about that idea? An on-demand system installed in the upstairs bathroom makes the most sense in terms of conservation of water and electricity and shortest distance to the shower, but it's the most expensive and least practical solution, involving opening the wall. |
#9 | |
I'd wrap your electric water heater and just keep it on. Given how little water you're using, I just don't see it making much difference turning it on for an hour to bring it up to temp from whatever it falls to the other 23 hours and keeping it at one temp—essentially, like the equation of keeping a house at one temp vs. dropping it and having to catch up later. The only difference is that a well-insulated water heater will lose very little heat. Sent from my SM-G990U1 using Tapatalk |
#10 | |
#11 | |
The benefit of the tank would be that a smaller unit can be easily plumbed into the space as all the connections already exist. Roughly a gallon per day for a tankless *coil* oil boiler to heat water for domestic use is about right. Being a one person household and restricted use... she may get down to about 300 gallons annually with the average efficiency in the boiler. The wood heat... if longer term is going to be used, the electric with either a smaller tank... or a federally-subsidized hybrid would make the better choice. Capital expenditure up front will need time for either of those to see a pay off. |
#12 | |
#13 | |
Most of the energy is used increasing the temperature from the well water to the tank aquastat set level.
So the largest cost will be heating the initial 53 gallons... After that roughly only enough electricity will be used to replace the heat lost to the space around the tank... Except when you use the hot water... then it will have to heat the replacement water. |
