04-24-2021, 05:18 AM | #1 |
Problem with dug well
The dug well at a family property has been invaded by rodents. Plumber discovered several dead ones floating in the well, and suspects there may be more that have sunk to the bottom of the well. Looking for a company that will come fix this problem - drain, clean and sanitize the well, and do whatever else is necessary to bring the well back so the water can be used again.
04-24-2021, 07:27 AM | #2 | |
04-24-2021, 07:38 AM | #3 |
04-24-2021, 11:03 AM | #4 |
Are you on Bear Island ?
04-24-2021, 03:57 PM | #5 |
04-26-2021, 04:16 AM | #6 |
For myself. I purchased a pump years ago. Sump pumb. with a hose.
For cleaning. Depends on what you mean for clean. Climbing in with a ladder and washing with detergent/bleach ? Then you have to figure out how these critters are getting in. If you can't do this yourself and don't have neighbors, friends, or relatives to do this. Then I guess - telephone a well company. There are plenty of well companies around the Lakes Region. Roth Thomas Daniels and many more. There used to be dedicated pump companies. Miller in Meredith was one. But sadly - he passed on. Maybe someone else can chime in with suggestions. |
04-26-2021, 04:35 AM | #7 | |
Suffocation?
The mice should have been able to move freely. Try inserting an 10-foot length of half-inch PVC pipe--capped so it floats.
Could an oxygen-free gas be introduced through natural inflow? Nitrogen from fertilizer? Maybe Carbon monoxide from a high-mounted generator? Carbon dioxide? Not Radon... |
04-26-2021, 05:10 AM | #8 | |
04-26-2021, 05:16 AM | #9 |
Are you using concrete well tiles or is it an old stone well? Is this your primary well or a backup? How deep is it?
04-26-2021, 05:39 AM | #10 |
04-26-2021, 06:19 AM | #11 |
That's pretty deep for a dug well with tiles. Is the top capped with a concrete cap? There's no way any creature could get in properly capped with concrete. If it's not 30 foot you could get a ladder and a pump , pump it down, clean out the well and bleach it. I take it you have a shallow pump with foot valve. If you do and chose not to convert it to submersible ,I'd replace the foot valve while someone is down there. Is it possible to pump out the well with the pump already in the well? You could have a second person on top pulling up a 5 gallon bucket and muck it out until it was clean or use a second small pump.
04-26-2021, 06:51 AM | #12 | |
04-26-2021, 09:31 AM | #13 |
Treatment System
You could consider a treatment system consisting of a series of particle filters and a UV sterilizer. A dug well will always have some level of microbial contamination, even after you address your immediate problem.
Lots of people do this, including us, with very good results. |
04-26-2021, 10:16 AM | #14 |
Very interesting reading about dug wells. I assumed most if not all were no longer in use. With today’s technology and resources why are these types of wells still in use? Not judging anyone, just ignorant of facts. Why not drill?
04-26-2021, 11:08 AM | #15 | |
A dug well is much less expensive then a drilled/artesian well with pump and tank. One probably would not find a dug well on lakefront property. Just go inland a bit. But some older camps may have a dug well or use lake water. |
04-26-2021, 11:25 AM | #16 |
04-26-2021, 11:27 AM | #17 | |
04-26-2021, 11:33 AM | #18 | |
04-26-2021, 11:45 AM | #19 |
Would it be worth putting a legit well in or working with lake water to solve all the problems, or is it cost/situation prohibitive?
04-26-2021, 11:53 AM | #20 |
Until the late 80’s we carried in drinking water and pumped from the lake for all other needs. A well was drilled in 87 if I remember correctly. I would identify safe drinking and bathing water as a priority for any household.
Little Bear (04-26-2021) |
04-26-2021, 11:56 AM | #21 |
Photos of abandoned, old dug wells in nearby towns of Thornton and Sandwich ...... http://www.scenicnh.com/blog/2016/08...ned-dug-wells/ says they were usually 10-15' deep.
There is a roadside spring water discharge pipe on Route 3 in south Plymouth known as Crystal Springs Natural Water where there are many local residents who use it to fill water containers for home water use. I have tasted it and it tastes like the absolute finest, best, most clean and happy water anywhere in the entire world ..... http://www.foursquare.com/v/crystal-...96370407d7f194 ....... plus the price is my type of a price ..... totally free ..... and everyone is always extremely polite and well mannered, there. So, eat your heart out all you artesian well, home owners with problem water ...... the #1 best water around is totally free ..... at the Crystal Spring on Route 3 in south Plymouth, NH. Driving from Lake Winnipesaukee to Plymouth Walmart for a $19.88 pit crew, oil change; get off at Exit-24 in Ashland and take Route 3-north, and you will soon come to it on the left after crossing town line from Bridgewater to Plymouth at the huge Bridgewater, wood to electricity, Power Plant...... is usually a car or two or three parked there ..... all year 'round ...... getting watered. There must be a few hundred locals from nearby who prefer this Crystal Springs side-of-the-road water to what comes out of their kitchen faucet.
... down and out, liv'n that Walmart side of the lake! Last edited by fatlazyless; 04-26-2021 at 02:05 PM. |
04-26-2021, 12:06 PM | #22 | |
The Following User Says Thank You to Little Bear For This Useful Post: | ||
thinkxingu (04-26-2021) |
04-26-2021, 12:26 PM | #23 |
04-26-2021, 01:07 PM | #24 | |
Drilled Well Costs
Both gave a range of $15K to $20K, based on the depth of other wells in the area. |
04-26-2021, 01:27 PM | #25 |
Sure many of you would disagree, but I would think clean water is more important then a boat or car
04-27-2021, 05:04 AM | #26 |
The well drillers drill a hole into the ground maybe with a general idea how deep based on other wells in the area. How deep and how's the water quality is an unknown. Some drilled wells have a problem with small stone particles or bad taste or radon or arsenic.
Water treatment companies like www.culligancentralnh.com will install a treatment facility in your basement or heated garage for your well if you are not pleased with the initial faucet water after the well is first installed. All things considered like the expense and unknown well drilling result cause people to stick with what they got for water, and go to the store for a five gal container of trusted quality water somewhat similar to the Route 3, road side Crystal Spring in south Plymouth ..... bring your plastic container(s). Welcome to New Hampshire ...... water, water, everywhere ..... and not a drop to drink ..... or something like that! The www.mwra.com ..... is not in N.H. ...... live free or die ...... for your water ..... you is on your own water!
05-12-2021, 04:26 AM | #27 | |
Clean Water Isn't Easy...Recalls...
Insert "bottled water recalls" into Google, and you'll find instances everywhere. Even Florida's ample springs have produced a recall in vaunted Publix supermarkets--citing "harmless mold". I've seen it myself, and wondered: https://www.waterworld.com/drinking-...r-from-shelves Coca-Cola produces "Smartwater" at $2 per quart. Made alkaline for the tummy, I drink it with my prescription medications with evening meals. Lake Winnipesaukee water is distilled in this household for drinking. Our gallon home distillers put out a lot of heat for about six hours, so both distillers are on timers, scheduled to take off the morning's chill in the cottage--a double-win. Even after 20 years, our antique Japanese-made distillers are still $75 at Walmart. That "critter" problem is discussed elsewhere on the Internet. Solutions, such as screens and shields are as close as Home Depot. |
