Old 04-20-2021, 09:28 AM   #1
winterh
Default Make Trex great again
I have a trex deck that is a bit beat up and stained from heavy use, construction related work and paint drips. What can be done to make it look better? Can you paint it? I thought of sanding it lightly but I would think I would lose the fake wood grain. Any thoughts?
Old 04-20-2021, 10:15 AM   #2
Never paint it. Power washing should remove most stains
Old 04-20-2021, 10:52 AM   #3
jbolty
I doubt any paint would stick to it long term and I found out the hard way that the top color layer is really thin. Maybe try cleaning with some steel wool
Old 04-20-2021, 11:00 AM   #4
a strong power washers and perhaps a cleaner mixed in should do the trick
Old 04-20-2021, 08:44 PM   #5
TKD
Which Trex ? Transcend, Select, Enhance or does it pre-date those ?
TKD is offline   Reply With Quote
Old 04-20-2021, 08:47 PM   #6
Wink Use Touch-up Paint, and Blast the Rest of it!
I've sawed through some composite wood (like Trex) and found no color layer.
A damaged dock near me also showed no color layer. (Pic below).
If it were me, and since Trex can be slippery anyway, I'd sandblast the whole surface.
The paint drips can be matched to the Trex color and by using a cheap "flux brush", touch them all up by hand. I had a similar "drip" problem with different colored pavers next to the house, and had to mix several different batches .
Old 04-21-2021, 09:08 AM   #7
jbolty
dunno. mine is gray on the inside and tan on the outside. maybe some other brand.
Old 04-21-2021, 09:38 AM   #8
Depends on the manufacturer and level of product you purchase, some are capped or encased, where others are the same material inside and out
Also sometimes reason for why stairs and decks are picture framed in, instead of just the look, which is a nice clean look.
I.C.Isles (04-22-2021)
Old 04-21-2021, 12:19 PM   #9
Power wash it and use some bleach if it's not a dock. But that's exactly why I didn't like the Trex. What you think is stain might be the wood inside which gets moldy.
Old 04-22-2021, 08:29 AM   #10
winterh
I used the term Trex as more of a generic term for the product. Not sure exactly what brand it is but I scrubbed with a deck cleaning product and then pressure washed and it worked pretty well. Some oily type stains still there but much better than before.
Old 04-22-2021, 09:30 AM   #11
Sue Doe-Nym
We used Zep cleaner on the deck and the stains came right up. You might want to contact the manufacturer.
The Following User Says Thank You to Sue Doe-Nym For This Useful Post:
winterh (04-22-2021)
Old 04-24-2021, 05:41 AM   #12
TKD
The best product on the market is https://www.corteclean.com Hands down best results - good luck
The Following User Says Thank You to TKD For This Useful Post:
The Winster (04-24-2021)
Old 04-25-2021, 09:31 PM   #13
Lightbulb Don't like Trex?
This product won't get moldy:
http://www.nexaninc.com/products/dec...rproof-decking
Old 04-26-2021, 09:43 AM   #14
Do you have any experience with this product? I was wondering if it dented if something heavy was dropped on it, and does it have a loud sound when the lake driving rain hits it?
also does it scratch?
Was going through the website, and those three concerns did not seem addressed. I like it in the fact about the lockdry system that I can not get leaves and stuff stuck in the middle and i can store kayaks underneath and they not get soaked and full of water. making room for other things. Then also that no bugs come up from underneath.
I will be doing my deck over in the next few years, hopefully when materials costs slow down and contractors as well
Old 04-26-2021, 04:13 PM   #15
I wonder how they keep it cool so your feet don't get burned.
Old 04-26-2021, 06:57 PM   #16
Smile No idea—I Like My PT Wood...
Originally Posted by AC2717 View Post
Do you have any experience with this product? I was wondering if it dented if something heavy was dropped on it, and does it have a loud sound when the lake driving rain hits it? also does it scratch?
Was going through the website, and those three concerns did not seem addressed. I like it in the fact about the lockdry system that I can not get leaves and stuff stuck in the middle and i can store kayaks underneath and they not get soaked and full of water. making room for other things. Then also that no bugs come up from underneath. I will be doing my deck over in the next few years, hopefully when materials costs slow down and contractors as well
Curious, I was looking through Google for removing scratches from Trex, when that site popped up in the search window.
I suspect they've addressed all those issues by wrapping aluminum around pressure-treated wood.
This page was generated in 0.10559 seconds
