We just had electric and plumbing done in our new/old camp to set up a washer and dryer. The dryer is not on an outside wall. Need to set up venting.
Best choice is to go down through the floor, but I don’t think I want it just dumping directly under the camp. Having all that moisture and heat dumping under the house can’t be good for it. Probably going to have to run it out to the side of the house. What have others done? It has to be pest proof of course. |
| The Following User Says Thank You to codeman671 For This Useful Post: | ||
DotRat (08-22-2020) | ||
My dryer is not on an outside wall. The dryer vent goes to a galvanized vent pipe through the floor and then a section of pipe goes over to the outside wall of our crawl space where it connects to a shuttered vent. 25-30 years, no problems. We clean the vent pipe every once in a while.
| The Following User Says Thank You to upthesaukee For This Useful Post: | ||
Slickcraft (08-18-2020) | ||
Yup, what he said.
My dryer vent is also on an outside wall. Has a flapper to keep cold air / bugs from coming as well as a mesh cap that we clean occasionally...
I would definitely not vent under the floor. Dan
Meredith AK (08-18-2020) | ||
I would follow what upthesaukee suggested, but, I would add the suggestion that the lateral pipe be insulated. When I first put in a dryer vent in the basement the run from the outside wall to the dryer was about 35 feet. I used the aluminum sections of vent pipe, and the heat in the vent pipe condensed and dripped to the floor the full 35 feet. I cured this by wrapping the pipe in insulation.
We are open underneath so condensation off the pipe is fine. Its probably an 8' run to reach the side wall of the house. I need to come up with a fitting to get it through the floor that will keep the pests out, provide a tight seal and allow the hose underneath to connect as well.
My home dryer vents to the side of the house. I would avoid venting underneath at all costs, both for the condensation (I don't think it's ever worth risking mold, rotting, etc.) and continuous deposits of, essentially, timber. Dried dryer lint is absurdly good fire starter.
Bet a toilet flange with a long neck turned upside down would work for the floor if you cannot find anything else. I would use plastic pipe for the outside run.
| The Following User Says Thank You to tummyman For This Useful Post: | ||
mhtranger (08-18-2020) | ||
We have a ventless dryer, avoiding the whole moisture exhaust problem. They start at around $900--a few hundred bucks more than a standard dryer, but you save the expense of installing the vent and it lowers your electric bill. You might check them out at best Buy or elsewhere
One other consideration: condensation inside any horizontal run. My current home essentially has a p-trap in the dryer vent, which has caused me headaches (as it traps water, which traps lint, which blocks flow).
As for the floor pass-through, there are flanges, or boxes, and/or elbows designed for dryer venting, that would be rigid and could be sealed against pests. Story time: we had a squirrel entry through our vent. The end of the pipe wasn't sealed well enough. The squirrel traveled up the pipe, was stopped by the dryer itself, then chewed its way through the flexible pipe getting into the house. |
#11 | |
Sent from my SM-T387V using Winnipesaukee Forum mobile app |
#12 | |
#1. He said it takes 2 to 3 times longer for drying. #2. It adds a lot of moisture to the air in the the house. #3. Ventless only came in small sizes / compact sizes. #4. There is a place where water collects on the unit that must be drained. Number 3 was enough to steer us in a different direction but I was surprised at all the other reasons as well... Do you have one?? If so are the above statements true?? My contractor just about refused to go that route and said we would hate it! Dan
TheTimeTraveler (08-18-2020) | ||
one of my freidns went thru this and his experience was a little different but just to add in some information. His run was pretty long so they added a booster fan. also the run had a 90 bend in an inaccessible place so they added an secondary lint filter. neither was very expensive.
#14 | |
So I'd say pros and cons vs regular, but nothing earth shaking either way. The thing that leads me to ventless in this situation is the OP's venting puzzle. |
| The Following User Says Thank You to FlyingScot For This Useful Post: | ||
ishoot308 (08-18-2020) | ||
Definitely run the vent out to the side. Use solid wall pipe, not flex, as that would tend to collect lint over time. Insulating the pipe is worthwhile, as blowing moist air through a cold pipe will result in condensation and thus lint collection. Out at the wall, think about the type of vent cap you want. Nearly every cap with a flapper on a hinge I ever have used collects lint right at the hinge, keeping the flapper from closing tightly. Cleaning that hinge area regularly would work, but these things tend to be ignored. The type of wall cap I prefer is this one: https://www.hardwarestore.com/lambro...SABEgKwI_D_BwE for $22 at Aubuchon. It has a floating shuttle that rides up on exhaust air, then settles back down for a tight seal. The top is removable for periodic cleaning.
Dick R any freezing or snow accumulation problems on the flap in winter with that type of vent?
#17 | |
Washline! Should be called dryer line. $3()?) for 50'.
| The Following User Says Thank You to Descant For This Useful Post: | ||
Top-Water (08-21-2020) | ||
#20 |
An environmentalist would run a metal pipe within living spaces to recover heat that the dryer would have lost to the outdoors.
But would also have used a clothesline in suitably comfortable weather.
#21 |
#22 | |
