Old 06-08-2020, 04:04 PM   #1
FlyingScot
Default Solar
Originally Posted by brk-lnt View Post
Many energy-saving/cost reduction things like solar, tankless heaters, etc. are more like "one big upfront payment". You pay up front, but then have reduced operating costs over time. If your net goal is the absolute lowest total cost of ownership over time, then these systems rarely pay back, particularly if you consider earning potential of the money used for their up-front purchases.
Disagree, from direct experience. Two years in, my solar panels are out-performing expectations that they will pay for themselves in 6 years. Then I will have almost free juice for another 20 years or so. Annual financial return is >15%. Similarly, my heat pump inverters have less than half the energy cost of my old oil burner and ducts (and I needed to buy new anyway).
Opinions on the forum are great and varied, but you really need to ask a good sales person to show you the numbers and spell out the savings for your own situation. If you trust the guy, go with it.
Old 06-09-2020, 10:16 AM   #2
brk-lnt
brk-lnt's Avatar
I have solar panels as well, in one of the best spots for solar in the US. I anticipate my system will "pay for itself" in 8 years, which means the ~$24K we spent post tax credits will have been recognized in utility bill cost savings.
However... If we invested that $24K and earned an average of 7% (currently earning much higher on other investments, so this seems conservative), and tax the growth at our average 24% tax burden (based on last 3 years of returns), I would have ~$36K in 8 years. So now my panels need to go another 4-5 years to "break even".
After maybe 15 years we will "break even", but it's a downhill slide, as the $24K we put to the panels could theoretically be earning continual interest.
Or, looking at it another way, I could set $24k aside for utility bill pre-payments and draw that account down over time, working against earned interest, and in that case we might realize an actual break-even point closer to 12 years.
This is ignoring the tax credit for solar, which you can argue is an opportunistic thing you should take advantage of, or a factor that causes false calculations.
Either way, a solar system is rarely, if ever, an "investment" in terms of net financial advantage.
Your heat pump example is closer to my initial comment in that if you have a high energy use appliance that needs replacement already, going with a high efficiency version is less of a hit than replacing a perfectly working unit. Still, these systems overall tend to not provide immediate net savings, but you may be able to offset their costs over a decade-ish of time, assuming they last that long and do not require any expensive repairs.
[insert witty phrase here]
Old 06-09-2020, 04:35 PM   #3
NH.Solar
NH.Solar's Avatar
The value of solar can't be looked at as a simple ROI based on net cost/utility savings.
First of all the utility savings is generally expressed as a simple projection of the current rate and as we all know utility costs generally creep up at a rate of ~3-5% per year ...a minor point, but with each rate increase the payback period for a solar installation will actually shorten.
Second, and here is the key for this frugal ol' yankee, the money you spend on a solar system is funds directed toward an asset that belongs to you, while the money spent on a monthly utility bill is purely an expense. It is similar in concept to the difference between paying rent and paying a mortgage for a place to live.
Third, and this is key to some and niente to others, solar power is far cleaner than the primarily fossil fueled power coming from the grid. Only an ostrich can ignore what is happening to our planet right now and with each solar system installation the degradation of our environment is eased. Maybe that sounds like penny wisdom, but dollars are made one cent at a time.
I find my own solar system to be very satisfying because it allows me to be a little looser with my luxury consumptions; I run the AC freely when it is hot knowing that the power for it is being harvested off my roof, I have my hot water heater set a little hotter than normal and take long soaks in the whirlpool without guilt ..and then get out and dry off with a towel off a heated towel rack. Best off all the Duramax hasn't moved much at all for the last six months because in December I bought a Chevy Volt. Maybe I should be a little disappointed in the car though, I did actually have to to put 5 gallons gas in it last month ...and I only drove about 600 miles ;-)
On a corporate level, if solar isn't a good investment, why is this NHEC installation on Moultonboro Neck Road? Its good, but it could have been done better if the installation had used bi-facial modules, but as in many things corporate and government dictated the lowest bid wins. We installed our first bi-facial module array in Meredith three years ago and have installed nothing but in ground mounts ever since. The backside of bi-facial modules pick up about a 20 - 25% boost in energy whenever there is snow on the ground, and in NH that gain simply can't be ignored.
Lastly, during the last year we have enjoyed a huge growth in the fully off-grid installations we have been doing. We are right now working on a full off grid on unpowered Gansy Island, our second this year. In both cases the "camps" have full 200 amp main panels and AC will be used whenever its needed. If there isn't enough power coming either from the solar array or from the battery bank, the inverter will simply start up the generator for assistance. Because they are both (well used) second homes I doubt that either will use more than 5-10 gallons of fuel between ice out and ice in. During the short days of winter and once the ice has set up so the camps can again be used, the generator will come much more into play. But even then it should only have to run for an hour or two a day to fully re-charge the batteries.
We also have two large scale off grid installations already scheduled for this summer for folks that have bought beautiful but well off grid properties and want to build large full featured houses. In both cases we are installing systems for $50-60K that will give then systems that will fully power a 200 amp panel and only need to call on the generator for assistance during the dark months of November through late January. During the rest of the year their power will all be coming from the sun. One installation is in Tilton and the quote the client received from Eversource to just to run power line out to his property was $47K. The other is in Stueben Maine which is just north of Bar Harbor and will be a combination work/vacation job (I've already booked a house for a week in lovely Southeast harbor). The client is from Florida and found NH Solar through this NH Business Review article. The advances in energy storage during the last few years have been astonishing, and this one factor has now made solar the far least expensive way to power a home ...even in New Hampshire and northeast Maine.
Peter
NH Solar
Old 06-09-2020, 06:30 PM   #4
FlyingScot
Not sure of your professional background, but when you say "this is ignoring the tax credit for solar" you raise a red flag that you are not calculating the return correctly. (You've got a couple of other mistake too, but I don't want to pile on.)
Returns on any investment should be calculated on an after-tax basis--the money that ends up in your pocket at the end of the day. When I said my panels were returning >15% per year that was a post-tax return (IRR) that would conform to any business school textbook or the (pretax) numbers that an investment firm such as Fidelity would provide on their investments.
15% is approximately 2X the long term after tax return on the stock market, with much lower risk. Any professional financial analyst would tell you that the solar on my house is a home run, driven by generous government incentives. Though as I concluded before--general online advice can be helpful, but every buyer should have their own specific situation analyzed by the installer.
Old 06-10-2020, 10:55 AM   #5
brk-lnt
brk-lnt's Avatar
Sorry, what I was trying to convey is that the cost to the homeowner is not representative of the actual cost, due to the government incentive. Thus if you want to calculate the "savings" of something like solar, you would really need to go by the actual system cost.
Or, to lay it out a little differently, government incentives do not necessarily scale. If someone pays half your restaurant bill, it might be cheaper than cooking at home, but that does not mean that overall dining out offers savings relative to eating in.
Go ahead, I always welcome informed debate and am happy to learn. Keep in mind I was trying to keep this discussion simple (but accurate) and not try to turn it into an ECON201 course.
To a certain degree, yes. IMO you need to consider broader factors if you are going to promote things like solar as a viable alternative.
I obviously can't debate that without you disclosing your numbers (which I am not asking you to do), but you would agree that your return rate as stated is far above most averages and norms? Or do you think that is the kind of return the average person should anticipate?
The risk part is very debatable, IMO. Tell me about risk at the end of the panel lifespan, after you have real data on panel failures/outages, damage, etc.
A "professional" financial analyst would factor the value of the investment based on the final return, not an early midpoint number. So far though, from what you post, your "investment" in solar is fairing well above average.
Old 06-10-2020, 11:36 AM   #6
FlyingScot
The basic difference is that you appear to be evaluating the societal impact of solar instead of the impact to the homeowner. As Peter from NH Solar points out, the societal impact is much more than financial.
As my post opined, the individual homeowner should be evaluating the impact ONLY to himself when looking at the numbers. In this case, that means giving yourself full credit for the tax incentive. I was more than happy to have the government pay 30% of the cost of my system. To go back to your restaurant comparison--if a restaurant is having a 2 for 1 night, I would not stay home because the savings is artificial or a one-time thing, etc. From a financial perspective, I care only about the size of my bill.
My returns are typical for a system in eastern Massachusetts. I'm confident they are repeatable there, but I do not know the returns for NH or other states. A good local installer should be able to provide these quickly based on the individual homeowner's sunlight, roof, equipment selection, current electricity cost, and state incentives. The risk really is low--there are millions of these installed, with expected repair costs and lifetime performance well understood. I would compare the risk to a corporate bond--even at 5%, you'd be doing quite well in today's environment.
Old 06-10-2020, 01:38 PM   #7
The social impact it what I get stuck on. I don't like the looks of them on any roof and I'm sure I'm not alone. I also have talked to people that say they are a pain to deal with if you have a roof leak. I don't like them but that's JMO!
Old 06-10-2020, 04:28 PM   #8
NH.Solar
NH.Solar's Avatar
Fun stuff and some very intelligent arguments... I always have learned the most valuable information from my clients, or in this case debaters. All of your points are good and individually applied probably valid. Every solar installation is different and has unique challenges. Do you recall me as as saying that we did our first bi-facial solar ground mount in Meredith? That client has an absolutely perfect roof for solar ...but like BiggD she absolutely was against it. So we installed a split bi-facial ground mounted array next to her home and it not only looks good, she also gained some extra winter production over the roof mount. Her 9.4 kW array produces about 12 mWh per year but most importantly a BIG boost in power is there from January til March and most of that is directly consumed by her new air sourced heat pump Hvac system. She is easily saving $2K per winter month over what she had (electric baseboard). I figured Mary's payback at nine years but now that she has the mini-split system I bet it would be closer to five or six. And again,if you install solar the tendency is to be a little freer with your consumption, and it is a little easier to live with the very enjoyable personal gluttony when you know that the power has been cleanly harvested from the abundant power of the sun
Peter
NH Solar
Old 06-10-2020, 07:41 PM   #9
Thumbs up
Originally Posted by NH.Solar View Post
Fun stuff and some very intelligent arguments... I always have learned the most valuable information from my clients, or in this case debaters. All of your points are good and individually applied probably valid. Every solar installation is different and has unique challenges. Do you recall me as as saying that we did our first bi-facial solar ground mount in Meredith? That client has an absolutely perfect roof for solar ...but like BiggD she absolutely was against it. So we installed a split bi-facial ground mounted array next to her home and it not only looks good, she also gained some extra winter production over the roof mount. Her 9.4 kW array produces about 12 mWh per year but most importantly a BIG boost in power is there from January til March and most of that is directly consumed by her new air sourced heat pump Hvac system. She is easily saving $2K per winter month over what she had (electric baseboard). I figured Mary's payback at nine years but now that she has the mini-split system I bet it would be closer to five or six. and again,if you install solar the tendency is to be a little freer with your consumption, and it is a little easier to live with the very enjoyable personal gluttony when you know that the power has been cleanly harvested from the abundant power of the sun
If I had a large property then that's the only way I would want solar, a ground system.
Old 06-10-2020, 08:52 PM   #10
If a new roof is required, can the solar equipment be removed and then reinstalled?
At what cost?
How does re-roofing early to get it done prior to a solar installation figure in to the ROI?
Does rooftop solar equipment increase or decrease the resale value of the home?
Does it diminish the pool of potential buyers?
How fast is the technology advancing?
Will today's installation become obsolete in ten years?
Old 06-10-2020, 09:33 PM   #11
FlyingScot
At what cost?
Removing the system to replace roof, and then reinstalling would be pricey, and really mess up the economics I described before. I think you'd want a roof with a lot of life remaining--hoping NH Solar has the number here.
Also--on the leak risk mentioned above--a good installer will have insurance protecting you from any leaks in your roof due to solar. As I noted before, they've done this many times.
The aesthetics depend on the house and the panels. I have all black panels on a relatively new home, and they look great. From my neighbors' compliments, I would guess they have added to curb appeal and home value.
Tech is advancing slowly but steadily. I don't think my panels will be obsolete in ten years, but since I'll have them paid for in 6 or 7, and printing cash after that, I will not mind if there's a newer-better version, I'm still ahead.
Old 06-11-2020, 08:59 AM   #12
NH.Solar
NH.Solar's Avatar
If the roof is over ten years old we generally advise our clients to consider replacing it before installing an array. There are a lot of variables however that can change this the main two being the pitch and the quality level of the original shingles. The roof may look fine but over time the UV rays of the sun will bake the oils out of shingles and they become brittle. Walking on them while installing an array can cause fractures or breakage and could result in a leak. Often a client can get away with just doing the south plane under the array because that is the one that will have seen the most direct sun. Once the array has been installed the shingles below will never age because they are now shaded from the direct UV rays by the panels. An additional benefit that comes from changing out the shingles before an solar installation is that the cost of re-roofing the plane under the solar array can be added to the cost of the installation and becomes subject to the 26% Federal ITC. Removing and re-installing a solar array would cost thousands of dollars so not doing the job correctly up front is a false economy.
In my experience a properly done solar installation will usually add value to a home in direct proportion to its gross cost and can also increase the homes marketability. If there are two identical homes and house A is listed for 300K and has an average $200/monthly utility bill (~1000kWh/mo), and house B is listed for 320K and has a near to zero monthly utility cost, which do you think will sell first? (...a rhetorical question, it depends on the buyer). Remember too that if you as the seller are able to add the full gross cost to the selling price of the home and sell it, you are already ahead of the game because you will have already pocketed the ITC and PUC rebate. All of the homes we have installed solar on have sold quickly and easily. A leased solar system on the other hand is definitely a detriment to a homes value and marketability. In fact there is nothing good to be said for leased systems and that is why the trend died so quickly.
As FlyingScot pointed out the aesthetics on an installation are a key element. We use all black modules whenever possible because the array then looks more uniform and sleek. An additional benefit is that they shed snow a little better than silver framed modules.
Yes the tech is advancing constantly but I might differ with the term slowly. Every week we are seeing something new coming out, most are relatively minor advancements but every now and again there is something really substantial, especially in regards to home energy storage. So does that mean it is wise to hold off until the next great thing comes along, probably not. As FlyingScot again pointed out a system that meets your needs today will still probably still be fully meeting those same needs 30 or more years from now.
Peter
NH Solar
Old 06-11-2020, 09:04 AM   #13
What about solar shingles? Similar to this... https://www.solarreviews.com/blog/wh...solar-shingles
What’s your thoughts on these?
upthesaukee (06-11-2020)
Old 06-11-2020, 11:24 AM   #14
Why hasn’t someone developed a solar panel support/install bracket that straddles the roof and attaches to each overhang with adjustable supports that sit on a roof instead of going thru it.
Old 06-11-2020, 12:15 PM   #15
NH.Solar
NH.Solar's Avatar
Solar shingles might be wonderful ...someday ...in Arizona, but I wouldn't even consider them in any climate subject to winter conditions. We have never had a single leak on any of our installs and I think that is both because 1) we won't cut corners on an install, and 2) because we design everything for December. As everyone on the lake knows you can't argue with Mother Nature and you can't stop the ice from tearing things up if you don't plan for it.
My favorite roof installation is rail less on a standing seam roof, no penetrations, snow slides right off, the critters can't get under the modules, and they look absolutely fabulous. The photo is one we did in Alexandria a few years ago
Peter
NH Solar
The Following 2 Users Say Thank You to NH.Solar For This Useful Post:
Biggd (06-11-2020), ishoot308 (06-11-2020)
This page was generated in 0.74646 seconds
