09-07-2019, 07:20 AM | #1 |
Jet Ski Advice
Mornin', lake friends!
I've been avoiding buying a jet ski because I'll have to trailer it in and out for each use, but a friend got me on his the other day and now I'm thinking of picking one up. His is a Yamaha 2-stroke around 2005 or something and I might be able to pick it up cheap. I have 3 questions, if you would: 1. The machine seems to smoke a bit and needs a fair amount of throttle before hitting a power band. Is that the nature of those machines or will some tune-up steps remedy that? 2. Do the new(er) machines add features that would be worth investing in a later model? 3. If yes on #2, what might I look for and what should I be expecting to pay? It would be either for me and my wife together or alone, or with my 7 & 9 year-olds, though I'm not sure if we'd be more likely to use it independently or by following/towing our boat out and tooling around while anchored out. Thanks! Sent from my SM-G950U using Winnipesaukee Forum mobile app |
09-07-2019, 10:25 AM | #2 |
2 stroke vs. 4 stroke
We've all said it: "I had so much fun, I bought one for the family."
You add oil to the gas in a 2-stroke, right? By definition, it will burn oil. Does anybody still make/sell a 2 stroke? Riding a chain saw without earplugs is not the same level of fun for me as something a little quieter. Newer is definitely quieter and 4 stroke will have better resale or trade value when the kids want their own. I like the idea of anchoring out and using that as a base for a day of riding, but I bet you'll tow it once and the wife will suggest that "You take the 'toon and I'll bring the PWC myself to save you the trouble." LOL |
09-07-2019, 12:43 PM | #3 | |
Please let us know
09-07-2019, 01:19 PM | #4 | |
I went to DaSilva's today and discovered a few things: I probably want something within the last half decade and 4-stroke. I'm thinking I'll need a swim bar/step to get my suburban dad bod out of the water and that a decent size rear platform would provide a nice place to play off. And it looks like there's almost two levels, technically advanced and basic--both of which have various levels of horsepower. Finally, though I'm partial to Yamaha--I've read that most rental places use them, so I'm guessing they're very reliable--Seadoo may be more cost effective. More thoughts wanted! Sent from my SM-G950U using Winnipesaukee Forum mobile app |
09-07-2019, 06:28 PM | #5 |
All 2 strokes smoke when first started. Smoke should go away when warmed up and in use for the most part. If it smokes a lot constantly, it is getting to much oil, which can be adjusted, or the top end of the motor may be junk. A compression test will tell you whats going on. All 2 strokes have automatic oil injection from the factory, no need to "mix" gas and oil yourself, unless someone has disconnected the injection system themselves and pre-mix the gas, which some people do for a host of reasons, but it's not very common, most people keep them in tact, and just add oil as needed. A 2 stroke has an oil reservoir for oil, and usually will have a dummy light, or a beeping sound for low oil warning should you forget to check it once in a while. I would top it off with every ride just for peace of mind, and keep a spare quart on board at all times. Make sure you either wrap the quart of oil in duct tape, or put it in a heavy duty leak proof plastic bag, (or both!!) because manufacturers have made the plastic bottles so thin and cheap, they break open pretty easy and make a big mess!! I have learned this the hard way!! You will become familiar with how much it goes through after just a few rides. A full reservoir will usually last around 3 to 5 full tanks of gas depending on how it's ridden. 2 strokes are a little bit louder than a 4 stroke, but in no way are they any where near as loud as a chainsaw these days, if ever!! Even ones 15, 20yrs old are not obnoxiously loud, you have to go back a long, long way to be able to compare them to a chainsaw, and if you do hear a loud one, it has been "customized" by the owner most likely, it didn't come that way out of the factory. I would NOT be afraid of a 2 stroke at all if you find the right deal on one. There are pros and cons to both. If you look at a 2 stroke to buy, I would highly recommend doing a compression test. It is simple, quick, and easy, and will give you a good idea on the condition of the top end of the motor, (pistons and rings). If you are not familiar with how to do a compression test, just look it up on youtube and you will find a thousand different videos on how to do it. IMHO, the "order" of quality goes like this: Honda, Yamaha, SeaDoo, Kawasaki, and the rest... Some may disagree, and that is ok with me, just my opinion. Good luck in your search. FWIW, I have a nice Snap On compression gauge set if you want to borrow, let me know. You don't want to use a cheap gauge because (and crazy to buy an expensive one to use it once), readings may be inaccurate, I saw it first hand one time when I was selling a snowmobile. A guy came with his own cheap gauge, and sled had low compression on his gauge. When we put my gauge on it, it was fine, and he bought it!! I KNEW the sled was fine, but he definitely wouldn't of bought it if I didn't have the nice gauge. He trusted mine over his... You don't have to have a "Snap On" gauge, but you definitely want a top brand name.
09-08-2019, 09:14 AM | #6 | |
As for the 2-stroke, the machine I drove seemed to smoke/smell not just at startup but throughout use a bit. Sent from my SM-G950U using Winnipesaukee Forum mobile app |
09-08-2019, 05:57 PM | #7 |
I have had three 2 strokes and a few 4 strokes. If you ride a 4 stroke once, you will not want a two stroke. Quieter, smoother, run cleaner, and just a much more comfortable experience.
I have had Yamaha's for years and I wouldn't have anything else. They consistently run great and the problems are few, if any. I have said it before but there is a reason most rental companies have all Yamaha's in their fleet. That should tell you something. |
09-09-2019, 06:30 AM | #8 |
I would avoid buying a 2 stroke. I have 2 Sea Doo's and I love them.
I have an 09 GTI 130se which is very reliable and will do 55mph. I also have a 13 GTX 260 limited which is insanely fast and fun. If you're a first timer I would stay away from the super charged models. They require more maintenance. If you buy used try to find something with under 100 hours. The new GTI's are great machines! You can get them with a 130HP or 155HP. The 155 model will do 60mph which is plenty fast enough. As far as trailering, they are much easier to get in and out of the water by yourself. Good luck with your search. |
09-09-2019, 06:03 PM | #9 |
I will admit that 4 stroke technology has come a long way in the last few years. They are snappier, and faster than ever before. I still have a need for speed, and older 4 strokes are Dogs, (slow and boring), IMHO. I have always liked the power band of a two stroke, and it's instant throttle response. I also LOVE the smell of two stroke exhaust!! Can't get enough of it!! I guess it all depends on how much money you want to spend, and what type of rider you would be. One other thing to keep in mind is that although two strokes are a higher maintenance machine, they are easier, and cheaper to work on. Good luck in your search, and always remember: Different "STROKES" for different folks!!! lol
09-09-2019, 06:52 PM | #10 |
My 2 cents
Hi all,
Simply, 4 stroke and 2 stroke jetskis are quite different.
I hope that this is helpful Jetskier |
09-10-2019, 06:15 AM | #11 | |
I'm not very big so I can maneuver the GTI around much easier than the GTX. But at 70mph in rough water the GTX is what I want to be on. I personally don't like the smell and the noise of a 2 stroke so I would never buy one, JMO. I'm so glad everything is going 4 stroke. I don't even like being behind a 2 stoke in the water any more. Which such a short season I don't want a machine I have to tinker with during the season. I just want to get on it and go. Last edited by Biggd; 09-10-2019 at 06:46 AM. |
09-10-2019, 05:20 PM | #12 | |
09-10-2019, 06:25 PM | #13 | |
09-10-2019, 06:39 PM | #14 |
Slightly off topin
E10 literally turned the gas lines into gel, but SeaDoo did not use A1 rated marine gas lines on the 1996 GTX. If you have an older model jetski and an additive can prevent this from happening, that is well worth it. I did all the work myself but it probably would have been north of $1,000 to have a shop do it.
Personally, I hate E10, it is just horrible. It is almost impossible to find fuel in Laconia without Ethanol. When we snowmobile in Canada, we fill the sleds there as there is no Ethanol added to their gas. Jetskier |
The Following User Says Thank You to jetskier For This Useful Post: | ||
thinkxingu (09-15-2019) |
03-23-2020, 06:04 AM | #15 |
To follow up here, I will be ordering a '20 GTX 170 but now, as I'm beginning to budget for the summer, I'm starting to think about how I'll acquire the fuel. I'm only a few minutes from Ambrose Cove Marina on the water, which would be the best option, but they're always expensive—$4.09 most of last season.
Given that I can tow the ski a couple miles down the road to the gas station, I'm wondering if I should be planning on doing that—at ~$2.30/gallon I'd be buying my costs in half. I'd want to use an ethanol neutralizer/stabilizer, but that only looks to add ~$.16/gallon which would still be much cheaper. Is there anything else added to "marina" gas that would justify the added cost? Sent from my SM-G950U using Winnipesaukee Forum mobile app |
03-23-2020, 06:11 AM | #16 | |
03-23-2020, 06:55 AM | #17 |
I'm thinking less about the overall price and more about the different, but I forgot about the Road Tax refund—$.22/gallon plus ethanol treatment brings that $4.09 to ~$3.69. Still about $1/gallon or ~$15 more per fill-up.
I guess it'll come down to convenience and if I want to spend half an hour dragging it to the gas station or having fun. Any other ways to fill? Anybody ever use one of these? https://m.northerntool.com/shop/tool...5161_200325161 Sent from my SM-G950U using Winnipesaukee Forum mobile app |
03-23-2020, 06:59 AM | #18 | |
03-23-2020, 07:27 AM | #19 | |
Any idea why AC/MVM are so high?! Sent from my SM-G950U using Winnipesaukee Forum mobile app |
03-23-2020, 07:46 AM | #20 |
Because they can be and still move product. Seems all marinas on that part of the lake are roughly the same except for lanes end.
The Following User Says Thank You to The Real BigGuy For This Useful Post: | ||
thinkxingu (03-23-2020) |
03-23-2020, 07:50 AM | #21 | |
Why, you say?
Our gas prices in Alton gas stations are generally 15-20 cents higher than in communities south and west. Is it worth driving from Alton to Concord to get gas at Sam's, then drive home to save 20 cents per gallon times 8 gallons ($1.60)(35 minutes each way). Probably not. But if we go down to Beaver Meadow GC in Concord, then go to Makris in Concord for lunch, it's easy enough to stop at Sam's for gas. Sooooooo, should you pay the high prices at AC/MVM or pull your watercraft, which you don't like, when you get gas, why not monitor your gas, and enjoy a nice ride enroute to cheaper gas, then combine it with a road less traveled on the way home. Seems like a no brainer Dave
03-23-2020, 08:02 AM | #22 | |
You weren't that worried about gas prices before- you decided to buy a jetski when has was $4.09 per gallon, prices are falling to almost historic lows. Why worry now? |
The Following User Says Thank You to codeman671 For This Useful Post: | ||
03-23-2020, 08:09 AM | #23 |
.... three miles and 30-cents difference!
Yesterday, Sunday-March 22: Rt 93-Exit 25 Holderness has two gas stations, Irving and Citgo, and reg gas was selling for 1.999 and 2.019. Both stations were busy.
About three miles away, close to the Plymouth Walmart on Tenney Mt Hgwy, there's three gas stations; Mobil, Irving, Shell, and all had reg gas selling for about 2.30/gal. All three stations was totally empty of customer cars at their pumps. ....
03-23-2020, 08:14 AM | #24 | |
Weight
I agree with Codeman; save your money. Dave
03-23-2020, 08:53 AM | #25 | |
Since I need to pull the ski after use (I don't have a slip to keep it at), it'll already be ready to roll. When doing the math above and thinking about the extra time spent, however, it doesn't appear to be a worthwhile trade-off. Sent from my SM-G950U using Winnipesaukee Forum mobile app |
03-23-2020, 09:03 AM | #26 |
When I was a yoot I carried my dad's steel 6 gallon jerry cans full of gas.
(Can I still use the term "jerry" or is that no longer allowed?) He parked as close as he could but the carry was often across 100' of granite cobble, down a steep ramp to the floating dock where I got to swing them into the boat. As a result of that and hauling our oversized anchor, each September I would return to school with Popeye arms. Now my back says "lots of smaller cans please". Big gas cans, even with wheels, can knock one out of commission. |
03-23-2020, 09:48 AM | #27 |
If you’re going anywhere on the lake from the Ambrose area don’t you have to pass Lane’s End? Fill outbound and inbound the first time, then every time you head back.
Top-Water (03-23-2020) |
03-23-2020, 10:29 AM | #28 | |
I guess it'll depend on how fuel efficient the new ride is and how much I'd burn getting there and back. Sent from my SM-G950U using Winnipesaukee Forum mobile app |
03-23-2020, 11:36 AM | #29 |
Curious how you avoid going near Lane's End Gas when heading south from the Ambrose Cove area.
The Following User Says Thank You to winni83 For This Useful Post: | ||
03-23-2020, 12:01 PM | #30 | |
03-23-2020, 12:39 PM | #31 |
Got your location, but do you have a secret passage to avoid the Lane's End area? See:
Lane's End.pdf |
03-23-2020, 12:53 PM | #32 |
That image isn't coming up for me, so I'm not sure what it was, but for me to get to Lane's End is a while with all the no-wake zones and channels, etc.
I'd say 80% of our time is spent no further than the north side of Moultonborough Bay—Smith Cove, etc In fact, throughout a whole summer, we don't go to MVM at all, even though that's where we store our boat in the off-season. Sent from my SM-G950U using Winnipesaukee Forum mobile app |
03-23-2020, 01:35 PM | #33 |
Yeah, it opened up in webview, which I always forget about.
As mentioned, we rarely go past Elkins Point and, when we do, it's the straightest line out of MB. Sent from my SM-G950U using Winnipesaukee Forum mobile app |
03-23-2020, 02:47 PM | #34 | |
Given where you are on the lake my guess is your at Arcadia campground, or you going to be storing you ski on the trailer? Jet ski's are light on gas, my suggestion is to tow it to the gas station and fill it up. Or by five gallon tank, and fill it up, sitting on the trailer, where ever you store it. This is how I keep my costs down.... I have 5 cans, I fill them up and then fill the boats up, with a siphon at my dock...
03-23-2020, 03:29 PM | #35 | |
03-23-2020, 04:14 PM | #36 | |
I'm thinking that if I end up using whole tanks, I'll probably just fill up on the water on the way, but if I can get away with 5 gallon jugs here and there, I may try to reduce costs when possible. Sent from my SM-G950U using Winnipesaukee Forum mobile app |
03-23-2020, 04:19 PM | #37 | |
Hillcountry (03-23-2020) |
03-23-2020, 04:22 PM | #38 | |
03-23-2020, 04:33 PM | #39 | |
The Following 2 Users Say Thank You to TiltonBB For This Useful Post: | ||
Longtimelurker (03-23-2020), Top-Water (03-23-2020) |
03-23-2020, 04:45 PM | #40 | |
03-23-2020, 04:52 PM | #41 | |
People still call Skelleys Market "Dads"! |
03-23-2020, 05:13 PM | #42 | |
03-23-2020, 05:36 PM | #43 |
It is called Greene's Corner Market and has been operating under that name for sometime.
03-23-2020, 05:55 PM | #44 |
When we take that corner, all our minds are on camp!
03-23-2020, 05:58 PM | #45 |
Oh, and my NH Boat Show thread was locked (the comments went wayyyy off-topic), but I thought I'd let all y'all know that...
I ORDERED MY NEW JETSKI TODAY!!! I'm hoping to pick it up early to mid-may, which gives me...two months more to ask questions! Sent from my SM-G950U using Winnipesaukee Forum mobile app |
03-23-2020, 06:45 PM | #46 | |
03-23-2020, 06:52 PM | #47 |
Does the trailer have a spare tire on it?
Do you have a lug wrench and a jack? I find that these items go a long way toward preventing flat tires! Recently I bought one of these to carry in place of a hydraulic jack: SeaSense EASY LIFT JACK https://www.amazon.com/dp/B000FZ345S..._DSuEEbYN42NNX |
03-23-2020, 07:25 PM | #48 | |
Any other accessory suggestions? Sent from my SM-G950U using Winnipesaukee Forum mobile app |
03-23-2020, 09:23 PM | #49 | |
03-23-2020, 09:44 PM | #50 |
I bought one of these while in Disney last year (T-Rex restaurant). It's my second favorite shirt.
The Following 2 Users Say Thank You to thinkxingu For This Useful Post: | ||
FlyingScot (03-24-2020), kawishiwi (03-23-2020) |
03-23-2020, 11:49 PM | #51 |
03-24-2020, 07:05 AM | #52 |
We all have plenty of time to waste now.
03-24-2020, 07:17 AM | #53 | |
Incorrect. All novels are books, but not all books are novels. Sent from my iPad using Winnipesaukee Forum mobile app
GG |
03-24-2020, 07:25 AM | #54 | |
Now, gilly, do you have any jetski accessory or usage suggestions for me and my T-Rex arms?! Sent from my SM-G950U using Winnipesaukee Forum mobile app |
04-26-2020, 06:49 AM | #55 |
Hey, forum friends! Picking up the new ski next week and have some final questions I can't seem to find consistent answers for:
1. Does anyone pull their seat to vent gas fumes before launching? 2. How much of a "pre-ride" check should I do before backing down the launch? Do I need to check oil/coolant every time? Start it before launch? 3. Given that it's fresh water and that I'll be driving up a couple hills when done riding, do I still need to run it out of the water for a few seconds? I've read about the Sea-Doo carbon seal issue (that it shouldn't be run out of the water to avoid heat breakdown) and want to make sure I'm doing things right. 4. Any other tips you've found helpful? Thanks! Sent from my SM-G950U using Winnipesaukee Forum mobile app |
04-26-2020, 07:15 AM | #56 | |
Check your drain plug, splash it, jump on, take off and enjoy. They are pretty maintenance free these days. |
04-26-2020, 07:19 AM | #57 |
1. I usually stand up “off the seat” to vent gas...
2. No. Does anyone, anywhere check their oil and coolant every time a vehicle is used? Your manual will tell you to do this but use your common sense and check at intervals to be confident if your levels. Perhaps when you get fuel, check the oil and look at the coolant reservoir... 3. Read your owner’s manual! |
04-26-2020, 07:34 AM | #58 | |
04-26-2020, 07:36 AM | #59 | |
04-26-2020, 08:24 AM | #60 |
You should always start your water craft in your driveway before launching at a ramp, and let it run for a few minutes (ON A GARDEN HOSE, WITH WATER RUNNING THROUGH IT!!) before launching. You know it's running, no dead battery, fuel is "flowing", warmed up a little bit so when you get to the ramp you have no "surprises", and should be an easy start up. Also, I always have the cover off, I have the dock lines all ready, anything, and everything that is going on the vessel is already on it before I get to the ramp so that all you have to do is put it in the water when you get there. I put it in the water, tie it up, then start it up so it warms up while you go park your truck and trailer, so when you get back to it you just go... I get really frustrated having to "wait" for other people in front of me getting their boat ready while in line at the ramp. That is BS!! They just hold everyone else up that is behind them waiting, and God forbid you ask to go in front of them because you are ALL READY to go... So now you sit there waiting for the idiot in front of you getting his vessel ready, while no one else is launching, and the line of people is getting longer and longer... Boat ramp etiquette is horrible. There should be signs posted at all boat ramps so when you are ready to go, and the guy in front of you is not, and the ramp is "open", all you have to do is point to the sign and say to the guy in front of you that "I'm next" because I'm all ready, so that way there he can't "hold" you back, and maybe next time he'll be ready to go when he gets to the ramp, instead of getting ready at the ramp. Common sense to me.
04-26-2020, 09:14 AM | #61 | |
04-26-2020, 09:33 AM | #62 |
Must be the exception
I must be the exception. In the years I owned Upthesaukee Too, I always opened the engine hatch, and stuck my head down inside to do a "sniff test". I also looked at the various reservoirs to visually check the levels. Engine oil, did I check it every time? Nope. Check it often? Yes, probably at least weekly. Check battery switch. Check bilge water level.
I could do all this while my wife got her stuff in order. Turn on the blower, and wait until she truly had stuff put away, and then got ready to handle stern lines. Crank 'er up, and cast off. Enjoy the ride. Dave
I Live Here... I am always UPTHESAUKEE !!!! Last edited by upthesaukee; 04-26-2020 at 01:34 PM. |
VitaBene (04-27-2020) |
04-26-2020, 10:14 AM | #63 | |
Getting ready
The Following 2 Users Say Thank You to Winilyme For This Useful Post: | ||
upthesaukee (04-26-2020), VitaBene (04-27-2020) |
04-26-2020, 10:40 AM | #64 |
I guess I should have stated that you ALWAYS run your engine in your driveway with engine ears, (or some other type of connection for jet drive unit's), with your garden hose so that you are running water through it while it is running. I would never have thought that people would be ignorant enough to run their engine's with no water... You should NEVER run a boat motor without water running through it. It only takes seconds to destroy an impeller that is run dry. I guess I just "assumed" that anybody that owns a water vessel would know this... Kind of like I would just "assume" that nobody needs to be told that you should never inhale, or ingest Lysol, or any other type of disinfectant. Amazing how things get (mis)interpreted. Also, for those of you that don't know, a garden hose connection usually comes out of the foundation of your house for a garden hose to be connected too. If you don't know what a foundation is, (or a garden hose), you may as well just sell your boat, you are beyond help at this point...
The Following User Says Thank You to Cal Coon For This Useful Post: | ||
Top-Water (04-26-2020) |
04-26-2020, 12:35 PM | #66 |
Two man operation
I have to agree with those who say "Don't block the ramp". e always had a driver and somebody in the boat, every thing un hooked, plugs in etc. before getting in line. The driver backed down and the helmsman started up and backed off while the truck was leaving. Elapsed time, less than thirty seconds when the trailer approached the water and as gone. Same thing when getting out, have the winch line extended and accessible, drive/winch on (no power loading) and get out. Under clean drain dry protocols, empty your bilge etc away from the ramp, no dirty or contaminated water back into the lake.
For a fun hour or two, go to a busy ramp and just watch. Some people dawdle, walk back and forth six times trying to remember everything and take way too long on the ramp. Lots of shouting and trying to drive the truck while you're sitting on the boat Others have it down and are less funny to watch, but very instructional. Go again at the end of the day and watch retrievers, too. It's easier to back up when the machine is on the trailer and can be seen. You might consider a couple of sticks at the end of the trailer to make it easier to see. Driveway reflectors like you set out to guide the snowplow are cheap. |
04-26-2020, 12:43 PM | #67 |
Two man operation
thinkxingu (04-26-2020) |
04-26-2020, 02:29 PM | #68 | |
When I use something in salt water I take it back to the house and immediately attach the garden hose and run the motor for about 5 minutes. Then I pressure wash it and the trailer. Any boat that I am taking to a ramp I start it at the house for about 2 seconds just to make sure it is ready to go and the battery is up. As soon as it fires I shut it off. When launching the jet ski I instruct whoever is driving it to start it in reverse. That way, if the nose has come off the front stop,and it often does due to the incline of the ramp, you don't start it and slam it back into the trailer. People forget that from the moment you start it it is always pumping water (until they suck up a dock line) On the jet skis and the pontoon boats that I trailer I loosen the winch strap about a foot before completely backing down the ramp. That way, when I hit the brakes the boat will move back a foot and be in slightly deeper water. The tow vehicle will not have to go as far into the water and doing this also breaks any friction if the boat has been on the trailer for a long time. Sometimes they stick. |
04-26-2020, 02:58 PM | #69 | |
It sounds like my wife and I have some coordination to work out! Sent from my SM-G950U using Winnipesaukee Forum mobile app |
04-26-2020, 06:34 PM | #70 | |
04-27-2020, 10:14 AM | #71 | |
Getting ready for winter! |
