Old 03-02-2020, 09:24 PM   #1
map
Default Need electrician
Need someone to install a ceiling fan. Any recommendations? The Weirs area.
Old 03-02-2020, 10:26 PM   #2
SteveO123
I used NuWave in Laconia (at the light across from Shaws) for a generator wiring job last fall. Very happy with their service and response.
I’ve also used Hutchins and had good results too.
The Following User Says Thank You to SteveO123 For This Useful Post:
map (03-03-2020)
Old 03-03-2020, 12:14 AM   #3
Woody38
We have used RDH electric in Laconia. Robert is great. On time, accurate work and keeps the work area clean. They clean up after they finish. I believe the carpet was more clean after they finished than when they started. Reasonable priced.
603-393-8658
_____________________________________
The Following User Says Thank You to Woody38 For This Useful Post:
map (03-03-2020)
Old 03-03-2020, 08:32 AM   #4
smith point boater
Default Electrician
2nd Hutchins. Prompt, reliable, always excellent work and neat
smith point boater is offline   Reply With Quote
The Following User Says Thank You to smith point boater For This Useful Post:
map (03-03-2020)
Old 03-03-2020, 09:37 AM   #5
I had Hutchins do a few additional receptacles and a generator hook up.
They were on time, did good work and at a reasonable price.
I would use them again.
map (03-03-2020)
This page was generated in 0.29155 seconds
