12-31-2019, 01:49 PM | #1 |
What should I expect from snow plowing?
I (homeowner) don't understand how a driveway is supposed to be plowed. When the plow truck drives back and forth over my driveway several times, it leaves a hard crust of ice that I then have to chip and scrape away, one painful square inch at a time. Is this normal? After the storm a couple of weeks ago it took me 3 hours with the ice breaker to remove the ice caused by the plow. It would have taken me ONE hour to shovel the whole driveway myself because it was 4" of light snow.
My fear is that if I just leave the ice caused by the plow, it will get worse with each storm and build up over the winter. Of course the other issue is damage to the lawn. QUESTION: What exactly should I expect from plowing? In my experience snowblowing is a lot neater but I can't find anyone with a snowblower. Not strong enough/young enough to handle a snowblower myself. |
12-31-2019, 02:20 PM | #2 |
I deal with the same. I place a bit of salt and sand down before it snows. Assists with its removal
12-31-2019, 02:45 PM | #3 | |
You are going to get a much cleaner scrap with a shovel of even a snow blower but if you're blaming the snow plow driver then he will probably drop you like a hot potato. My guy up in NH plows my driveway and when there is ice build up he sands and salts. It does seems that there is more of an Ice problem in NH. I think it's because the temps drop more quickly up there. |
Music Man (01-03-2020) |
12-31-2019, 03:33 PM | #4 |
Snow plowing
We keep a bucket of sand by the garage so we can spread it around the walkway and up to the door of the house where we walk. We have a very long driveway and when it gets really bad the plow puts down sand or whatever he uses. Of course this is an extra charge.
12-31-2019, 03:45 PM | #5 | |
Some factors that would contribute to a layer of snow being left behind are: 1. Your driveway being driven on before the plow comes. This packs the snow and a plow will ride up over the packed down areas. 2. The plow guy has his plow “shoes” (if he uses them) too low, causing a layer that doesn’t get scraped. 3. The plow’s cutting edge is worn making it harder for him to scrape down to pavement. (If your drive is paved) if it’s gravel, he may not want to push your gravel off the driveway. 4. Late plowing (after snow/slush/rain) etc has rendered the snow to be like concrete. (Difficult to plow in any case) 5. Ill fitting or attached plow. (Sometimes a plow will not make full contact when at full angle) Plowing commercially is a difficult job to say the least as Mother Nature throws conditions at us that are beyond our control. In a perfect situation, the driveway should be fully scraped...that's what I would strive for but in some cases, could not achieve. Last edited by Hillcountry; 01-01-2020 at 01:18 PM. |
12-31-2019, 04:29 PM | #6 |
I have a gravel driveway here in southern NH so it is desirable to get a little ice freeze up so that for second and subsequent storms, there is a hard surface and the plow doesn't dig up the gravel. This is better for both of us. We did the original layout so there would be room to stack snow, and minimal exposure to lawn. When it rains and freezes, or melts and refreezes, we sand, at least enough to walk to the mailbox. The town puts a supply of sand/salt mix, same as they use on the roads, outside the town barn for citizens to use as needed. When it has been really bad, I pay my plow driver to do sanding. Only a few times in 42 years. I did the calculations for 10-12 storms a year and plowing is about the same $$ as blowing. Rolling over in bed while I hear my neighbors blowing? Priceless. I've never owned a snowblower. I hand shovel steps and walk. I know guys who plow and also provide shoveling services. Last I heard, they were paying shovelers $20/hour.
12-31-2019, 04:40 PM | #7 |
I have done commercial snow removals at shopping centers and LaGuardia and JFK Airports.
Hillcountry’s advice is spot on!! If your contractor does leave a thin coat on your driveway then use sand/salt on the driveway this will provide traction and when it warms up or you continue to drive over it the snow and ice will melt. Sent from my iPhone using Winnipesaukee Forum mobile app |
12-31-2019, 05:05 PM | #8 |
You got to remember these small time plow drivers that plow individual driveways are making rounds. If they have 30 driveways, by the time that get back for a second or third pass it's already frozen. It's not the same as plowing an airport or a shopping mall. That equipment is there non stop until the storm stops, plowing, sanding, and salting continuously.
That's why sanding and salting in NH is a must. My town road is not paved. It is already a solid 4" block of ice. The town puts down sand almost daily. They don't use any salt as I'm too close to Lake Waukewan and it's the town water supply. |
12-31-2019, 07:30 PM | #9 |
I should have expressed myself more clearly. The plow truck tires pack down the snow so hard that it turns to something akin to ice that can't be removed with a shovel. Eventually it does turn to ice. The hard/snow ice is only where the tires pass. I think we've all experienced this even with driving our own vehicles over snow in our driveways. Pressure and weight harden snow. Best example: snow shoveled from a roof turns to something close to concrete. I've had to take an AX to that snow many a time. Another example: snow falling on a glacier turns to ice as it compacts.
There is ice in my driveway right now from where the mailman drove his truck on it yesterday. So yes, the plow truck does cause the ice. Of course, this only causes a problem if the snow isn't plowed down to the asphalt. Last edited by SailinAway; 01-02-2020 at 08:11 AM. |
12-31-2019, 07:40 PM | #10 | |
12-31-2019, 07:49 PM | #11 |
As Hillcountry mentioned skid shoes too low will keep the plow blade up off the surface. If the plow person does many driveways some are probably gravel. In those cases skid shoes are almost mandatory early on when the ground is not hard frozen. Otherwise gravel as well as snow will get plowed. Putting the skid shoes back up for each paved driveway would mean getting out and manually adjusting the shoes. Not likely to happen.
When I had a gravel driveway and plowed it myself, the first several times each year an inch of so of snow was left which packed down to a hard icy surface. Once that happened I would raise the skid shoes unless a thaw came. If I had plowed many driveways I would have left the shoes down a bit all winter so that the plow was up a bit. That would also help avoiding plowing up lawns as snow is pushed to the side. |
01-01-2020, 03:29 PM | #12 | |
This issue really becomes a big problem when the plow approaches the garage doors, has to lift the plow blade up, drop it at the garage door and then pull the snow backwards in order to clear it away from that location. Doing this multiple times during every storm does cause a big problem during December, January, and February as the sun is low in the sky, and the daylight is somewhat limited. Come March and April the days are a bit warmer, and the sun is higher in the sky (which allows more "natural" melting). The problem is most severe in driveways which are shaded by buildings or trees and do not get that much needed sunlight. |
The Following User Says Thank You to TheTimeTraveler For This Useful Post: | ||
Biggd (01-02-2020) |
01-01-2020, 04:18 PM | #13 |
01-01-2020, 06:00 PM | #14 | |
01-01-2020, 07:10 PM | #15 |
All I ever got out of a plowed driveway was a bunch of excavated gravel and a day or more of work in the spring to put it all back. We've had a 450 foot long gravel driveway for 23 years and had it plowed for the first few years we lived here. We got so frustrated with the end result that we gave up on the plow and started shoveling it. Yes, my wife and I shoveled a 450 foot long driveway for nearly ten years. Understand that we winter on the CT shoreline where we don't get nearly the snow that NH does. Still, the few storms that dropped 8 or more inches would take us a full day to shovel. I don't recommend it.
A few too many sore backs, ten years of aging and laughing neighbors made me think again. Never thought a snowblower would work for a gravel driveway but I did some research. Ended up buying a Honda track mounted snowblower and that turned out to be the perfect solution. The tracks easily keep the auger off the ground (no muscle needed) such that almost no gravel is thrown and it takes me about 30 minutes to whip away that 8 inches of snow. Love, love, love, love, love my snowblower and, no, I don't sell them for a living. Did I mention that I love my snowblower? |
The Following User Says Thank You to Winilyme For This Useful Post: | ||
01-01-2020, 08:40 PM | #16 | |
More often than not the tractor handles the storm but that Honda is my back up when things get tough. Love it! |
01-01-2020, 10:27 PM | #17 |
Not a misquote
01-01-2020, 10:38 PM | #18 |
How old are you?
Note the OP mentioned he was too old to play with a snowblower. I'm looking forward a few years to when all you snow blower guys start posting here looking for somebody to plow. Or, "where can I rent near Tampa?" and "Who will watch my house while I'm gone?"
01-02-2020, 07:43 AM | #19 | |
If you expect a perfect clean every time from a plow driver be prepared to pay an enormous amount of money. I drove by an big house in Weston Ma. a few weeks ago during a storm. There were 10 workers there, 8 with shovels and 2 with snow blowers. I'll bet that clean up at least was $1000! |
01-02-2020, 08:09 AM | #20 |
Update
I had the driveway plowed by someone else yesterday. This was after the very difficult last storm with several hours of sleet and freezing rain. This guy did a 100% better job than the previous guy. He plowed down to the pavement and there was almost no work left for me to do with the shovel. He got within 5 feet of the garage and pulled that snow back---even in that area he got it clean down to the asphalt!
So the comments above by Hillcountry are correct, and it is possible to do a good job even in adverse conditions and even when the snow has to be pulled back. ***Thanks for educating me about the art of snowplowing! As an aside I'd like to say that there are a lot of low-income senior citizens living alone who can't afford anything near what most charge for plowing. There is a need in the Lakes Region for home and property maintenance services for this population. I've been shoveling by hand for years. I'm well past the age for doing that. |
The Following 2 Users Say Thank You to SailinAway For This Useful Post: | ||
Biggd (01-02-2020), Hillcountry (01-02-2020) |
01-02-2020, 08:29 AM | #21 | |
01-02-2020, 09:02 AM | #22 | |
Regarding plowing, my buddy plows our driveway in MA for free, so I can’t complain about the job he does, he’d tell me to get lost if I did. I always fire up the snowblower after he is done to tidy up. Even the best plow guy usually leaves a little bit of cleanup to be done, unless they have shovelers with them. I actually enjoy snowblowing so the clean up is fun, and I feel like the beer after tastes just a little better. Sent from my iPhone using Tapatalk |
01-02-2020, 09:30 AM | #23 | |
The Following User Says Thank You to Hillcountry For This Useful Post: | ||
01-02-2020, 10:28 AM | #24 | |
As for our winters in CT, six months in Tampa sure sounds good to me though I think us guys in New England are supposed to stick to the east coast of Florida. Mid-Westerners to the west coast or so I'm told. |
01-02-2020, 10:54 AM | #25 | |
Snowplowing
It’s unusually warm today, 82°, and I’ll be swimming in my pool later on. I love reading about everybody plowing their driveways. |
01-02-2020, 12:28 PM | #26 | |
I've heard mixed reviews on them. Probably great for the home owner but I don't think I would buy one if I had a lot of drive ways to do. |
01-02-2020, 02:44 PM | #27 |
Ouch. Is there a 'thanks, I think' button?
01-02-2020, 03:15 PM | #28 | |
I had a hose blow once and brought it to my mechanic ( who was a Fisher dealer) after he saw my SnoWay he became a dealer for them shortly after. I guess he was impressed with the SnoWay. Good to hear other manufacturers are adding down pressure to their lines |
The Following 2 Users Say Thank You to Hillcountry For This Useful Post: | ||
01-02-2020, 04:59 PM | #29 |
Plowing Contractor referral ?
On a side discussion....
I'm looking for Plowing Contractor referrals ? I usually snow blow my own driveway, but recently had to hire an private plowing contractor, while I was out of State last week, to clear the last large dump of snow we received recently. Only reason I hired a plowing contractor was because someone was house-sitting for me, and 'she' needed to get in and out of driveway each day. If she wasn't staying at the house, I would have just waited until I returned to State, and took care of it myself. Anyway, the plow contractor I hired did a horrendous job plowing, and I would NEVER hire again. Contractor was a referral from a friend, go figure ! So looking for a few 'good' referrals from Forum and average pricing they charge. I do realize that plow contractors have to take care of their regular customers first, no worries there...... Thanks for your responses, much appreciated ! |
01-02-2020, 06:38 PM | #30 | |
Shane’s landscape and Excavation... (603) 528-4000 Gilford Lawn and Landscape.... (603) 293-5867 Dan
01-02-2020, 07:34 PM | #31 |
Snow or hurricane?
I will suffer with snow and complaining about plowing snow any day vs experiencing hurricane destruction and paying for damages high insurance rates won't cover.
We have a snow blower for each our driveway AND for our wrap around deck. |
01-03-2020, 12:36 AM | #32 |
Snow or hurricane
In the five years I’ve lived in Florida now, we have had only one real scare of a hurricane and that was in 2017 with Hurricane Irma. It looked like we were going to get hit really hard and everybody had to put their hurricane shutters up in preparation. I will admit it was pretty scary not knowing what would happen.
But the hurricane changed course and we escaped without any damage. Insurance is not expensive, my regular homeowners as well as additional flood insurance( which is necessary because of a lot of hurricane damage is caused from water) combined is around $1300 a year. Plus, the building codes in Florida have really improved over the last 25years or so. They learned a lot from hurricane Andrew in 1992. Any new home built since 2005 is required to come with hurricane shutters as well for extra protection. This same hurricane hit the Caribbean really hard. My sister, who is a full-time resident in Moultonborough, had devastating destruction to her home on the island of Anguilla. She had no insurance because the cost there is so prohibitive - $20,000 a year approximately. There is also a huge deductible as well. She took the chance and went for about 10 years before her house was hit with about $300,000 in damage which she had to pay herself. Things in Florida are pretty good. 😎 |
01-03-2020, 02:09 AM | #33 |
Plan B
I spent some time today researching snowblowers. I didn't realize that some Toro single-stage machines can handle quite a bit of snow. I'm looking at the Toro Power Clear 518 ZR: https://www.homedepot.com/p/Toro-Pow...8472/205380014
You'll probably say it's too small for a 20' x 60' driveway and New Hampshire snow, but I here's what I'm thinking:
The next size up, the Toro Power Clear 721, is a more effective machine but it weighs 84 lbs. https://www.homedepot.com/p/Toro-Pow...8472/205380014 My concern about a two-stage machine is not just the weight while using it, but the impossibility of getting it home and taking it anywhere for service since I have a compact hatchback. Your thoughts? And a question: I need some paths around my house (like to the electric meter and oil fill pipe). Would this machine tear up the lawn? |
01-03-2020, 05:21 AM | #34 | |
The first snow on grass can be delicate, but once it's frozen/packed a bit it's fine. Light snow is easy to throw, it's the wet, heavy stuff that makes a machine worth its salt--it may be worth the size/design for those times. Transportation isn't a huge issue--wherever you buy probably offers delivery and many small engine shops will pick up/deliver machines. If not, I'm sure you've got a friend who can help out. In 35 years of working with snowblowers (20 at home with Dad, 15 on my own), we've only had to have service that required transport three or four times. Treat every ounce of gas you buy and cycle leftover gas through your vehicle every few months, and you'll get years of service. Good luck. Sent from my SM-G950U using Winnipesaukee Forum mobile app |
01-03-2020, 07:03 AM | #35 | |
Thanks, Loub52 |
01-03-2020, 08:01 AM | #36 |
01-03-2020, 10:21 AM | #37 | |
01-03-2020, 11:04 AM | #38 |
Plan C
Before you laugh at this option, know that it won an award from Time Magazine in 2006 for best new invention.
https://www.youtube.com/watch?v=0IW1Bq7qvBI |
01-03-2020, 02:15 PM | #39 | |
Depending on the weight of the snow, it will throw it as little as around 10-15 feet, but for dryer stuff, up to maybe 30 feet. The wheels on the unit are like those of a smaller lawnmower but are super sturdy - no issues with them to date. There’s no throttle to manage (single rpm) and it cleans down to the surface (deck or pavement). It takes only about a half quart of oil, so you need to be diligent about replacing the oil at the end of each season, and you’ll need to swap the snow throwing paddles each season...all of the maintenance takes maybe an hour and a half. My version has the electric start (about a $50 premium), though I’ve never used it as it always starts on the first or second try using the pull cord. |
01-03-2020, 06:47 PM | #40 |
Single stage snowblowers with the paddle style auger work best on a smooth asphalt driveway as opposed to an unpaved dirt/gravel driveway. On an unpaved driveway the two slides on both sides of the auger will catch and get stopped on a dirt driveway.
For a higher powered, self-propelled single stage machine that's still relatively light at 125-lbs, check out the Toro Snowmaster 724 or 824. For a very good smaller two stage that's good on a dirt driveway, check out the Troy Bilt 824 two stage, weighs 185-lbs, and costs about $600. If you buy it at Heath's Hardware, they can deliver it for no extra charge. I've had one for about eight years and the Troy Bilt 824 at 185-lbs is relatively light for a two stage plus it has the power to move the heavy stuff close to the road. After eight years it still runs good on the original two belts and friction plate. All I've had to change are some snapped off shear pins from hitting a rock.
01-03-2020, 09:44 PM | #41 | |
I suggest you buy your snow blower from a reputable local company who services what they sell (including pickup and delivery). Granted, you will pay more than at Home Depot or Lowe's, but if it is service which is important to you then give your business to a well proven shop which services what they sell. Best of luck! . |
01-04-2020, 07:12 AM | #42 |
Sno Jo 21' for nine bucks!
Sno-Jo 21' super secret sale ....... now going on .....for just NINE DOLLARS, a 21' aluminum roof rake with a large plastic puller scoop, at my favorite store in Plymouth ...... seems like it should sell for $35 ..... is very good quality .....with about eight left unsold ...... and selling for just nine dollars ....
...... a super secret sale ...... so super secret that me-thinks it may just be a pricing error ...... or something? Having recently broke the old roof rake into two pieces by using it like a hammer to pound on some roof ice, I was pleasantly surprised to luck onto this super, secret sale at said un-named store!
01-04-2020, 08:57 AM | #43 |
Lowes delivery.
3 years ago or so, I bought a Troy-built 3 stage snowblower. If I was to go home and come back to the store to bring it home from the Gilford Lowes, I would have to shovel out my utility trailer from about 2 ft of snow and ice. Not wanting to work that hard, I asked about delivery.
Next day I had my new snowblower. As it was unloaded from the truck via the hydraulic lift, they asked where I would like it. I opened my garage door and they wheeled it right into place in the garage. I can't remember the cost, but I do remember my wife saying "just do it, it's worth it ". If you're worried about getting a heavier unit home, think delivery. If you're a veteran, think Lowes, 10% off (does not apply to delivery charges and protection plans). Dave
01-05-2020, 07:58 AM | #44 |
Lowe's-Gilford charges seventy five dollars for local delivery of a snowblower that costs less than one thousand dollars.
To avoid the $75-delivery ..... just go big and buy a super powerful Ariens 28" efi for about $1500 ..... weighing something like 275-lbs ..... and become the local KING of SNOW! ... Seems that a lot of snowblower buyers are not impressed with the all black plastic discharge chute on low end machines like the $600 Troy Bilt 24". But, by rubbing about one dollars worth of Vaseline on the insides of the black plastic, it makes it extra slippery and keeps it from clogging with wet, heavy snow ..... and makes it a very happy machine. These super-duper snowblowers with their fancy-dancy discharge chutes controlled by an ergonomic pistol grip handle have too much technology .... the very simple black plastic chutes work very good because they are very simple.
01-05-2020, 10:30 AM | #45 | |
Thank you!
Really looking forward to testing it! Thank you! |
01-05-2020, 10:32 AM | #46 | |
01-05-2020, 04:43 PM | #47 | |
Thanks, Loub52 |
01-05-2020, 06:27 PM | #48 |
01-05-2020, 06:30 PM | #49 |
Cool manual snowblower
01-05-2020, 09:08 PM | #50 |
Change
Do you know how to turn a dishwasher into a snow remover?
Give her a shovel. Seriously, the older I get, you, the OP, mentioned age, the happier I am to have a good plow driver, and to not have a snowblower. My oil fill was moved many years ago to be close to the walk. I don't think Eversource sends a meter reader out; it's done remotely. |
01-09-2020, 09:16 AM | #51 |
As already mentioned in an above post, the Plymouth Walmart has a few SnowJoe 21' roof rakes selling for 75% off at $9.00, and it is a good quality aluminum handle with a plastic scoop. Not as sturdy as the all aluminum scoops but should last a long time with reasonable care. Another use for a 21' long roof rake is to use it for trimming tree branches while standing on the ground. Check out the Corona razor tooth 21" hand pruning saw for $42.29. It cuts on the pull stroke which works pretty good screwed/attached to a 21' long handle. Trimming pine tree branches is very easy fast work, while trimming oak trees take a lot more effort. Is not a bad idea to wear a helmet and safety goggles. You can actually trim through a 6" diameter oak limb with this set-up in about 30-minutes ...... and you will believe it when you actually do it!
01-17-2020, 04:10 PM | #52 |
Used my new Toro Power Clear 721E for the first time yesterday in about 8" of heavy, weight snow.
Positives: It handled the mess at the bottom of the driveway left by the town plow pretty well, as long as I moved slowly and only did about 10" wide at a time (still better than shoveling). Throws heavy snow about 20 feet. Wasn't too hard to push up my 15-degree driveway. Negatives: There are quite a few. Really loud! Temperamental engine: not happy if gas is left in it for a week. It took several minutes to get it running smoothly. I've ordered some Sea Foam; maybe that will help. Leaves about 1/4" of packed snow behind---I think this was due to the density of the snow. I had to go over everything twice. Exhaust smell is pretty strong. A full tank of gas only lasted about 30 minutes. Wherever I let the machine rest in the driveway there were gas spots. A real design flaw of this machine is the number of steps required to get to the spark plug---you have to dismantle the chute, top shroud, and back. Yearly maintenance seems pretty complicated, compared to a lawnmower. I'll see how this machine does in fluffier snow next time. Thanks again to Loub52 for recommending this. |
01-17-2020, 04:20 PM | #53 |
thank you.
After an extended conversation, it's great to get good, detailed feedback.
Thanks. |
11-05-2021, 02:54 PM | #54 |
As you can see from my last post above, I didn't get along with the Toro PowerClear 721E very well. Hence it's for sale for $300. See my ad at https://www.winnipesaukee.com/forums...do=ad&id=12133
Bear in mind that I have no mechanical abilities so take my views of this machine with a grain of salt. |
11-06-2021, 08:02 PM | #55 |
Belletetes Lumber in Ashland has, as of one week ago, a 24" Husqvarna snowblower for $799, which must be last year's price. For a 24" snowblower, Husqvarna is made in Sweden and is sturdy, strong and powerful and much more rugged than a Troy-Bilt or a Craftsman 24".
It looks like the prices for new snowblowers have taken a big price boost with much higher prices than last year ..... something like a $150 to $200-price increase. Worlds greatest snowblower repair guy is Lakeport Power Equipment, 143 Mechanic St in Laconia; open Tuesday to Friday, 8-5, and Saturday, 8-12.
... down and out, liv'n that Walmart side of the lake! Last edited by fatlazyless; 11-07-2021 at 09:25 AM. |
11-06-2021, 10:13 PM | #56 | |
Snow plows always made quite the mess in our driveway too. But we were not always here and didn’t have much choice. That track snowplow sounds great. If we ever stay up here full time that will be high on my to check into. |
11-07-2021, 03:36 AM | #57 |
Aubuchon Hdwe in Meredith now has about three or four different Honda snowblowers inside their store right now, which are a new item as they formerly carried snowblowers with much lower prices in previous years. So it looks like Aubuchon-Meredith has switched from $500-$1000 snowblowers to selling $2000-$3000 Honda snowblowers.
For some price like $200-$400 you can get a used Ariens snowblower on Craigslist-NH and then take it to Lakeport Power Equipment in Laconia for a 'go-over' and get yourself a very capable strong working Ariens for a much lower price. Ariens is the King of Snow and will last for years and years with a little love. If it's left outside, it should have a good cover that can be found on Ebay. Talk'n about the Meredith Aubuchon and their new line-up of super expensive Honda snowblowers. Well .... the Aubuchon employees are all very polite and have no problem with you trying out the high quality controls on a Honda while you stand there and think about doing your driveway. Just think, your waterfront mcmansion that was worth three million dollars one year ago is now worth 4.5-million dollars so's maybe you really can justify getting a Honda snowblower!
... down and out, liv'n that Walmart side of the lake! Last edited by fatlazyless; 11-07-2021 at 09:17 AM. |
11-07-2021, 10:30 AM | #58 |
I haven't found any brand that doesn't have issues, or for that matter any brand that will not survive a long time when properly maintained.
The Craftsman ran forever, but the ergonomics were terrible. The Cub Cadet LCT motor broke the carb spring - I replaced it with a spring from a ball point pen and got another carb from Belmont Hardware to replace it (kept the first for a back-up). The Ariens with the AX (LCT built) had a control rod issue when the transmission was placed in reverse it would overshoot. Simply adjusted and pinned the rod with a cotter. It then shattered the drive gear for the electric starter - I have that in my shop to replace - but after removing the busted pieces it has worked fine with the pull starter. |
