Hi guys, I have a 1974 Sea Ray 20 ft inboard outboard. New to the Boating world and found what I thought was a honey of a boat for a good price. it has a 305 GM MerCruiser electronic fuel injection. I've been out four times on Winnipesaukee and all four times have had a problem and three out of the four I had to be towed back. The marina that's close by to me is in Dover New Hampshire had gone through the boat initially telling me everything works perfectly. The updated Driveline has approximately 340 hours on it. The first time I brought it out on the lake it Road perfectly 4 hours until the fourth or fifth hour while I was on my way back it's stalled and could not start again so i figured I ran out of gas.... The second time I went out on another day, hours on the lake it had the same ending and it stalled way out in Gilford and could not start. I was towed again by seatow. Brought it to the marina and after they did several tests including a compression check, fuel pressure check, fuel sample check, they ended up putting in new plugs, cap and rotor, and i had them replace the coil just to be sure....$700 later I thought It was all good and went out for my third time. I always leave from Alton Bay and I was in the Meredith area when it decided to do it all over again and spit and sputter and stall with no ability to start up. I was towed once again back to Alton. Brought it back to the marina and they said they had a fuel pump code on their diagnostic computer and found that the fuel pressure while in the marina was jumping up and down sporadically so they put a brand new fuel pump and solenoid in. $970 later I go out for my fourth trip, and again leaving Alton Bay and driving to Weirs Beach everything was great then driving back to Alton going anywhere's from 10 miles an hour to 40 miles an hour it was running perfectly until a half a mile before the boat ramp and then started to hesitate, lost power and wanted to stall but didn't quite stall so I limped it back to the trailer and it is now back at the marina. Of course the mechanic is scratching his head not knowing where to go from here and I am so frustrated I've spent so much money on obviously a problem that continues to be undiagnosed. I'm running out of money and quite frankly hate owning a boat at this point because I haven't had even one good run with it. Of course I'm In Too Deep to be able to sell it so I have to get to the bottom of it somehow. Can somebody please suggest some things so I don't go crazy! Thank you all for your suggestions.
now today on the 1st, the news from my marina is that mercury was called and the tech told them whats going on and they told the marina to put in a boost pump kit because the marina said they found the system vapor locked..... im not an expert on this whole thing but i did remove the gas tank cap when its acted up before and nothing changed, the tech said thats not what hes talking about when he says it was vapor locked......ugh Last edited by LaFuga; 07-02-2019 at 05:28 PM. Reason: new info |
Personally my mind would be going to an electrical gremlin with a wire harness somewhere. works under load and then after a while (wire heating up) it starts to give you problems. Other issues could be corroded fuel tank through crap and/or water in the line and then into engine
Capt. of the "No Worries" |
| The Following User Says Thank You to AC2717 For This Useful Post: | ||
LaFuga (07-01-2019) | ||
I had a problem with the fuel supply tube coming out of my gas tank. The original manufacturer had put a filter screen over the intake end of the tube. Over the years sediment accumulated in the tank and would slosh around, block the intake and cause a stall. Then the sediment would settle down, the tube would open again and the cycle would start all over. Had my mechanic remove the filter screen, clean the tank and no more problem.
To me, it sounds like fuel...Please let us know the outcome.
Gary ~~~~_/) ~~~ ~~~~~~~~ |
| The Following User Says Thank You to garysanfran For This Useful Post: | ||
Sounds like a blocked fuel tank vent to me. Try opening the fuel cap when the engine stalls, If there's rush of air into the tank and the engine starts running normally again, fix the fuel tank vent problem. Might be as simple as an insect next in the vent.h
| The Following User Says Thank You to Dave R For This Useful Post: | ||
If you, or he marina, do nothing, will it start 'tomorrow' after being shut down and fully cooled? Does the boat have gauges or just warning lights? i.e. how does the temperature gauge read over time?
#6 | |
#7 | |
Temp stays at 150-160 all the time, but yes, it will start back up later on
Sounds like those guys in Dover will fix it this time for another $900... you could have put on all those parts for a lot less and still got the same results!
| The Following User Says Thank You to swnoel For This Useful Post: | ||
I'm feeling the same except there's no way I'm paying them another penny... Seeing I just bought the boat, it's nice to know I've got all these parts replaced now, but the next attempt has gotta be on them... I've been very patient and respectful so there should be no argument they need to make this right by no more charges
#11 | |
I'd give them another chance with the understanding that you are paying for no more unneeded parts and labor. Did you hopefully pay for the previous repairs with a CCD? |
I would strongly demand they get in the boat so they experience what you've been dealing with! testing out of water with a pair of ears does not mimic a loaded situation as on the water.I agree taking off the fuel cap when she dies is a great idea.
MY 2003 Doral with Mercruiser had same symptoms, After extensive troubleshooting at marina, issue turned out to be a rubber washer on high pressure fuel pump.
#14 | |
I'm in deep so I need to keep with them till its figured out without paying for another bill. Going to someone new and paying all over again isn't in the budget this year |
Yea, I've takn off the fuel cap and no change.. And believe it or not, they took the boat out for them selfs after the fuel pump replacement and it didn't act up for them! Don't think they stayed in it long enough tho
So I just got the word from the tech that it was vapor locked. He said after talking to mercury, they told him to install a boost pump kit for the problem. Anyone think that's the problem?? God knows how much they will ask me to pay this time....
#17 | |
Hope this helps. |
I think I read in one post that the boat had been out of the water for two years; and I haven't read where it came from - private sale individual, used boat from a marina, other. What I am driving at is that the previous owner may be a source of either similar problems (and what was the solution) or a record of previous maintenance either by an owner or marina.
I wish you all the good luck in the world, my friend. |
#19 |
You typed “1974” and say it has EFI.
Is that a typo? Was it repowered? I cannot imagine it being a 1974 with EFI. If 1974 is correct, as stated above, pull the tank pick up, it is very nasty! |
#20 | |
#21 |
not a typo, the people who bought it from the original owners who moved away to florida says the first people redid the boat a couple years ago and removed the original driveline and put all new in, including updating the engine from a 6cyl to a 305 fuel injected mercruiser. and, says that the fuel tank was replaced all at the same time... i looked at the tank under the bow and it does look new... the marina says that the driveline also looks new. they put new guages in it also and i was told, and it does say on the gauges that its got 340 hours on it.. my marina told me yesterday that they now found it vapor locked and mercury told them to install a boost pump kit. they say they have checked all wires and vent line and this is what they say will finally fix it....im of course very skeptical ...so we will see....i just feel i shouldnt have to pay any more seeing the first diag was the cap and rotor, second diag was a new fuel pump...now this "pump kit"... idk....super aggravated
#22 |
I have spoken to Mercury many times via telephone.
They are quite generous with their time and expertise. I am not saying that the marina is wrong or lying but you may wish to get some additional confirmation on your own. Be advised that there can be variance in the knowledge and experience level of the tech you reach on any particular day. If you call Mercury, have the model and serial number of the engine handy. Here is their number: (920) 929-5040 |
| The Following User Says Thank You to 8gv For This Useful Post: | ||
LaFuga (07-02-2019) | ||
#23 |
The parts that have been put in so far may not have been needed but they will benefit you.
I suggest that you negotiate for free labor for the boost pump if you choose to have it installed. |
#24 |
Wherever he is!
Hinchman (10-11-2019) | ||
#25 | |
#26 |
Hey guys, so after my last post a few days ago, the marina said they found my stalling problem to be caused by the system being vapor locked. I mentioned all the different attempts by the marina to figure out why it would stall on my last post. So one of your comments was to call mercury myself so I just did. They felt confident the marina was doing the right things and that the last decision was to put a boost pump kit into the system which would stop the system from vapor locking... Which the tech at the marina said he found after 3 attempts to fix my problem. Apparently vapor lock won't show up always so after it did this last time, I'm crossing my fingers this will finally be my cure and I'll be able to enjoy my boat once and for all! I'll let you all know how it runs after the kit is installed. Happy fourth!
#27 |
What is the fuel vacuum on the fuel line going to the engine? If you have vapor lock as they say, the vacuum should be high. Substitute a good know portable fuel tank and hose going to the engine and drive it. If you have a restricted fuel tank lick-up, anti siphon valve, or supply line, opening the fuel cap will have no affect on it. Vacuum should not exceed 2.5 inches of vacuum. A boost pump will not fix a restriction in the fuel supply.
