Hello,
We have island property on Winnie in Moultonboro and are thinking about moving to a metal roof. A couple of questions: Do you have a metal roof? Are you satisfied? Can you share the Pro's & Cons? Can you recommend and refer a contractor who does this work? Thank you and as always, appreciate the insight of this forum. Eillac Last edited by eillac@dow; 06-24-2019 at 10:37 AM. Reason: added location |
#2 | |
2) I am satisfied 3) Pros and Cons a) Pro's are more energy efficient, last twice as long, no snow build up. It does not make any nose when it rains as other may say b) Con's are you cannot use gutters as the snow slides off and will pull them down, need to strategically layout the roof lines so snow falls off where you want it to instead of in front of a door or on your flower beds |
| The Following 2 Users Say Thank You to joey2665 For This Useful Post: | ||
eillac@dow (06-24-2019), gravy boat (06-25-2019) | ||
#3 | |
And thank you for the info! |
| The Following User Says Thank You to joey2665 For This Useful Post: | ||
eillac@dow (06-24-2019) | ||
Make sure there is sufficient pitch, particularly if there will be seams. We bought a house last year with a new metal roof and had to replace with rubber because it was leaking, particularly when snow would melt and seep under it. The rain was also fairly loud on it. It was somewhat soothing when it was a steady light rain but a bit alarming in heavy torrential rain! I may have been more sensitive to it though since any precipitation meant checking for leaks
| The Following User Says Thank You to kauriel For This Useful Post: | ||
eillac@dow (06-25-2019) | ||
#6 | |
As far as leaks when snow melts, I have none but metal roofs require a good amount of snow and ice shield Sent from my iPhone using Winnipesaukee Forum mobile app |
We got a metal roof a few years ago and we are very happy with it.
It is extremely durable (expected lifetime is 50 to 100 years), it is screwed on, fire and hail and wind resistant, it weighs far less than a asphalt roof so the combined weight of roof and snow is less of a concern. You may be able to get a homeowners insurance reduction with a metal roof. Peace of mind; I don't think I will have to worry about the roof for the rest of my life. It is NOT noisy when it rains (nor when it snows ).We got a higher end type, DECRA (check out the website pictures). The steel is heavier and is covered in an epoxy, stone dust material. It is beautiful and looks like regular shingles (shake and tile style anso available). People look at it and cannot believe it is a metal roof. It does NOT dump snow like the standing seam metal roofs. We chose it because we did not want it to. THE DECRA IS PRICEY. The standing seam metal roofs are cheaper (and come in more colors) but are still more than a asphalt roof. We got it from Drew's Affordable Steel Roofing out of Laconia (they have a website). They did a great job for a fair price. They, however, are VERY busy and it can take 3 or more months to get them out to do the job. They may quote you 3 months out and not get there until the 4th month. If you don't have the patience to wait for quality work, you will be frustrated. We had developed a leak when we first contacted them and we had them place a tarp over the roof until they could get the job done. It was a little added expense but we were well pleased with the result. A friend also had them do their roof and was pleased with the outcome. They got the Wakefield Bridge shingles. |
| The Following User Says Thank You to jeffk For This Useful Post: | ||
No issues with my metal roof. Didn’t hear rain but when the acorns were falling that’s a different story.
| The Following User Says Thank You to SAB1 For This Useful Post: | ||
eillac@dow (07-01-2019) | ||
I have two different types of steel roof. The one on my business is standard metal panels that are screwed down. 35 years old and will probably go another 50 but there is one problem. Expansion and contraction will cause some of the screws to loosen and need to be tightened occasionally which is not an easy job.
At my home I have a standing seam steel roof. Snow slides off better and no visible screws.....totally maintenance free. I think the prices are comparable but standing seam is a much better option. |
| The Following 2 Users Say Thank You to SAMIAM For This Useful Post: | ||
eillac@dow (07-01-2019), Hillcountry (06-26-2019) | ||
#10 | |
| The Following User Says Thank You to Hillcountry For This Useful Post: | ||
#11 | |
| The Following 2 Users Say Thank You to Hillcountry For This Useful Post: | ||
Biggd (06-26-2019), eillac@dow (07-01-2019) | ||
I forgot one negative associated with my metal roof. Woodpeckers. I had a mentally challenged woodpecker on the roof in the morning that seems to have decided that rapping on a metal roof was like a rooster's call. What a racket. At first I couldn't figure out what the noise was. It sounded mechanical but I couldn't associate it with anything that I have in the house. I finally figured out that it was "outside" and went out to check. The little twerp was sitting on the end of the house banging away. He kept it up for days, for over an hour, and I assume he finally bent his beak and gave it up. He had been at it over a week last year. He came back this year but only once or twice and not for so long. His beak probably still aches from last year.
We just had a metal roof installed on our new camp and porch. As others have stated, there's no "ping" from the rain. In fact, last night's thunderstorm was the most powerful so far, and the roof was quieter than our old shingle one--my guess is the barrier used between the metal and plywood, which is essential because of the expansion/contraction, dampens quite a bit.
I'm not too sure about the insulation part yet, but yesterday it certainly felt cooler on the porch and inside, even though we had some trees taken down and are now more exposed to the sun throughout the day. There's definitely a benefit to snow sliding off--the most we observed was an inch or two--but as others have noted, it can pile up hard. Because of the compression when it falls, we had snow behind our camp a few weeks after everything else had melted. Overall, I'm glad we went metal--barring any extraordinary circumstances, we should be good-to-go for 30 years+. Sent from my Moto G (5S) Plus using Tapatalk |
A helpful thread. Two questions - can anyone recommend outfits that do Island work? And, does anyone have any idea if the tariffs have impacted the cost of a metal roof - and if so, by how much?
If you are going to stripping the roof down to the original sheathing before installing your new metal roof (recommended), consider using 2x4s laid flat and crossways 2' apart on your rafters and then placing 1.5 inch foam board between the purlins. It is a relatively cheap upgrade that will make a huge energy and noise difference
| The Following 2 Users Say Thank You to NH.Solar For This Useful Post: | ||
ApS (06-29-2019), Hillcountry (06-29-2019) | ||
#17 |
Just Asking, I simply don't know.
How do these metal roofs deal with lightning strikes. Any one have any experience/s or know of any issues. |
#18 | |
I'd think it would provide a little more insulation and less noise from rail. |
#19 | |
The old shingles do not provide a flat level surface for installation. Sent from my iPhone using Winnipesaukee Forum mobile app |
#20 |
Thanks everyone for your input. I appreciate all the comments...lots to think about....metal is probably the route we will take...at some point.
Again....reco's of contractors that do this work....please feel free to share the good and the bad! Happy 4th of July Everyone. Eillac |
#21 |
I also have a metal roof.
Satisfied. The roof is noisy in the rain, but we are installed directly onto the plywood sheathing with no insulation in our camp. We actually enjoy the sound when it rains. Rain/Snow come directly off and in our case pine needles as well which is one of the reasons we got one. Metal roofs (when installed correctly) prevent the build up of moss and pine needles. Provided the proper amount of insulation you probably will never hear the rain. We installed our roof ourselves, so it was very cost effective and comparable to installing asphalt shingles. We used Everlast roofing which comes in 20 or so different colors and three different styles. They are a relatively local company as they have offices in Bridgton, Maine. It is actually not that hard to install yourself (unless you live on an island like we do). The roof has a 35 year warranty and is easily recyclable at the end of its life, unlike asphalt shingles. It also requires much less prep time to install than asphalt and weighs on your roof less. Very sturdy. Hope this helps. |
