Old 09-30-2018, 08:35 AM   #1
rsmlp
Default plumber in moultonboro
Forum members, I need a recommendation for a plumber who services moultonboro that isn't flat out busy. My normal guy can't get here he's so busy.
Not an emergency as our situation is manageable but tis is def time sensitive.
thank you
Old 09-30-2018, 12:44 PM   #2
DesertDweller
We have always used Minute Man Plumbing and have been very happy. Good people to work with and very reliable. They are based in Meredith.
Old 09-30-2018, 06:33 PM   #3
WINNOCTURN
WINNOCTURN's Avatar
Thumbs up Excel Mechanical Services
Bob Polman
(603) 253-6939
Very Reliable
Shows UP!!!!!
Old 09-30-2018, 07:01 PM   #4
pjard
I used Rowell's last week for the first time. Absolutely fantastic service!!!
Old 10-01-2018, 08:50 AM   #5
Not to Worry
Default Pass on Minute Man
Without going into detail I would pass in MM Plumbing. Very, very, very, very expensive. I personally felt ripped off.
Old 10-01-2018, 10:31 AM   #6
carott88
Try Joe Boxer @ 603-630-5393. Haven't found any bargains out there, but this guy does good work.
Sent from my SM-G920V using Winnipesaukee Forum mobile app
carott88 is offline   Reply With Quote
Old 10-01-2018, 10:52 AM   #7
Happydog
Default Smitty's
I have used Smitty's Plumbing (Greg Smith) a few times and have found him to be excellent and fair priced.
Happydog is offline   Reply With Quote
Old 10-01-2018, 12:02 PM   #8
phoenix
phoenix's Avatar
go with Smitty . He is reliable, honest and reasonable
Old 10-02-2018, 07:33 AM   #9
rsmlp
Greg has proved to be a very valuable consultant on this issue which as it turns out was more a drainage septic problem than plumbing.
Greg has def earned my plumbing jobs going forward.
Old 10-02-2018, 11:01 AM   #10
Gatto Nero
Gatto Nero's Avatar
Agreed. We've used Greg for 20 years or so.
Old 10-06-2018, 02:39 PM   #11
joec
I can highly recommend Smitty's Plumbing.
I opened my house in the spring a few years ago and left a ball valve closed and the excess water in the pipe drained back and froze. When I turned on the water I had a gusher.
I called Greg for the first time and he came out and fixed the valve in an hour from the time I called.
This year my hot water tank gave up and he was able to get that replaced the next day by
The early afternoon.
I have worked with Smitty's several times over the years and he has always been fast, fair and quality work. I wont go to anyone else for plumbing work.
I have either built or been involved with building several houses and been jerked around by All types of contractors at times. It's a welcome change to work with someone that respects their customers like Smittys.
joec is offline   Reply With Quote
This page was generated in 0.09583 seconds
