Old 06-21-2018, 09:21 AM   #1
twasz
Default UV Filter system
Can anyone recommend a company (with reasonable prices!) that will service a UV water filtration system on Lake Waukewan? I believe we may need a new lamp and most likely some maintenance. The company that installed it is no longer in business.
twasz is offline   Reply With Quote
Old 06-21-2018, 10:14 AM   #2
Try Gilford Well.
Otherwise there really isn't much to them. You can order parts online and replace a bulb easily yourself.
The Following 2 Users Say Thank You to codeman671 For This Useful Post:
LIforrelaxin (06-21-2018), twasz (06-23-2018)
Old 06-21-2018, 10:23 AM   #3
I'll second Gilford Well....
Old 06-21-2018, 10:38 AM   #4
As someone already said there isn't much to them, so if you handy there is that option.
However if you need someone to look at it. Likely any plumber, well company etc. can help you out. The problem really becomes finding someone that will work with what you have, and not try to get you to replace what you have with what they generally work with.
twasz (06-23-2018)
Old 06-21-2018, 11:58 AM   #5
Formula260SS
Formula260SS's Avatar
If your handy with a torch and can solder a copper pipe just do it yourself. Just google UV System and get one rated for the flow you need. I would recommend over sizing a bit and getting one with a monitor. They come with pretty clear instructions.
If it seems like too much just call any plumbing or pump company - they all can put them in.
The Following User Says Thank You to Formula260SS For This Useful Post:
twasz (06-23-2018)
Old 06-21-2018, 12:13 PM   #6
Formula260SS
Sorry just re-read the post your looking for a lamp. Same thing google it, instructions are clear
twasz (06-23-2018)
Old 06-21-2018, 01:00 PM   #7
Yes, your plumber can do it.
This page was generated in 0.07288 seconds
