I personally would never have a non composite deck again and my guess is that it would be a very good selling point for a house. Never need to stain, treat, or otherwise and continues to look great. My deck is gray in color with white railings and I think it looks really nice. Sure it scuffs and what not but nothing to get too excited about. Trex is the original and many would say the best. There are cheaper alternatives. One thing to note is that depending on what brand/type of composite decking you go with, make sure your existing joists are not too far apart to properly support the composite lumber. I think Trex comes in different qualities like you mentioned and some of them are designed to span longer joist spacing distances.
#2 | |
When we re-built our cabin at the lake, one of my priorities was to design everything outside to be as maintenance free as possible. Was it more expensive? Somewhat. But worth it. 5 years later, outside looks as good as when it was built, and we've yet to do anything to it. Most people don't even know it's not wood until they ask. |
Used composite up the lake house...it gets dumped on every time the metal roof lets go...LOL ..One year the roof had ice, it slid, it broke through the deck...that was an unusually hard winter...looks great...it's 10 years old... cleans up beautifully...use deck wash on it..no issues...wish I had it at my city house..$$$$$$$$$$$
When we built our house 4 years ago we used Azek for the decks. Very pleased with the way they look. We do use a snow shovel with a plastic blade on the decks.
On our new house, built 2010-11, we used Fiberon imitation IPE composite decking. It still looks new, and it's a good match to the house siding. It has a fairly tough shell over the core material and seems to stand up well to abuse, including snow shoveling with a plastic shovel. I suspect PT would suffer more abuse over time than the composite does, being a wood product. Plus, the PT would tend to present potential splinters to bare feet over time, whereas the composite will not. Long-term maintenance tilts in favor of composite. Bear in mind that labor to install either type of decking likely will be more than the material itself, so a lesser uptick for better material won't be as big a deal.
If you do go composite, as others have noted, make sure the joist spacing is close enough for the material, particularly if the decking is attached at 45 degrees, which may call for 12" OC joist spacing. Also, if composite decking is used, and it has grooves on the edges for the use of hidden fasteners, then lateral bracing of the framing will be required, since the use of those fasteners does not provide racking resistance. |
Thanks for all of the good replies and I suspect some more yet to come.
Right now we are sticking with the composite plan, likely a light grey color. That is the color of the stain we have on the old PT decking and have been happy with that color. The bid that we have is the Trex Transcend line, will talk to the contractor about other options. The size of the deck does lead to pretty high material costs. The 25 year old PT decking would have been in much better shape if the original owner had sealed or stained it. Rather it went 10 years untouched except for mother nature resulting in lots of surface cracks and splinters. As an aside I must have messed up on my advanced search prior to posting. Got zero past results meaning that I must have accidentally clicked on the wrong forum on the sidebar. |
Our house in Massachusetts is 25 years old with the original pine decking. The original owner had the house built and the contractor did the usual by cutting corners. The deck is stained and had minimal care by the owner. Interesting that we painted the house two years ago and I assumed the deck was included. When they finished I was told they would stain the deck for $800.
My fault, but this is the first time I had a house painted and they did not do the deck. This deck is sort of beat up but presentable. I got out the sander and did some sanding on the worst spots and lightly elsewhere. My real issue is that stain today is not oil. Didn't soak in so good and did not shed water like the oil. I am applying a second coat. If I were to replace this deck I would use mahogany or teak. AND proper maintainance |
What Ishoot said. Two of my friends are quality builders and will use nothing but azek. To manyissues with trex that they have to go back and fix.
SteveO123 (02-24-2017) |
We just replaced our Douglas Fir deck with Azek. We bought it at Winnipesaukee Lumber- they were great to deal with.
Our joists were already 12"OC. We did picture frame ours to cover the edges. |
The Following User Says Thank You to VitaBene For This Useful Post: | ||
tis (02-23-2017) |
Recommend the Camo Hidden Fastener System for whatever decking material you use. We did our deck last year with Azek from Winni Lumber and secured it with the Camo system...came out great. Easy to use and practically invisible.
The Following 2 Users Say Thank You to Busy Livin' For This Useful Post: | ||
Slickcraft (02-24-2017), tis (02-23-2017) |
When I had put new siding on my house I used Azek for all the trim, facia and crown molding on my windows. Love that stuff. Azek came more recommended than Trex. FWIW
Just an fyi. I have seen on both materials what appears like mold spots. It does come off with scrubbing.
SIKSUKR |
#12 | |
Couldn't agree with Easy Livin' any more. The Camo deck system is wayyy cheaper than hidden fasteners and goes in much faster. I built a 1350 sq. ft. full wrap around farmers porch on our last house using Camo and Evergrain decking by Tamko. The decking worked great and the system to put it in worked great. I cannot stress enough, as others have, that the joist spacing is absolutely critical depending on the product. I currently have mahogany at our house and I would replace it (if it wasn't so expensive) with composite.
Probably the oldest and preferred by top builders and architects.
Let's make this simple..Use Azek. Can't be beat. Our deck now 4 years old and looks great!
The Following User Says Thank You to Diver Vince For This Useful Post: | ||
ishoot308 (03-24-2017) |
#16 | |
We've got a PT dock that's 37 years old.
![]() After casual and intermittent treatments with Thompson's Sealer, it's only recently that some deterioration has appeared. I'm dabbing the trouble spots with an epoxy w/filler, rather than taking the trouble to replace a few boards. Quote:
Is it ![]() ![]() |
#17 |
We are having our lakefront deck redone, and are planning on Azek. We have dozens of samples in hand. Looks to be three options/levels of Azek - Vintage(most expensive), Arbor, and Harvest(least expensive). Does anyone have experience with this type of decking when wet? Any specific opinions on the three options?. The most expensive seems to have the best “grain” and traction. We may also use the same to redo our docks decking. Obviouslly Azek comes well recommended by this forum, but is it much more slippery than pressure treated, and anyone have personal experience with the three levels and the look, feel.
#18 | |
I am not positive but believe their more expensive Vintage line of decking is also a fire rated product. Depending on your use and budget the fire rating may be well worth the difference in price. Darker colors will absorb heat more than lighter colors and will also show more fade. Fading will stop after one season in the sun. Edited to add: just found this on line. Impressive! https://azek.com/docs/default-docume...index_v8-final Dan
#19 | |
