Would someone please explain the advantage of a duoprop outdrive? I've had a single prop and now a Duoprop, and while they are very different boat designs I'm hard pressed to detect any difference in the handling characteristics.
Don't have any real world experience but dual props are supposed to have better slow speed maneuvering and better acceleration.
Supposedly, duoprops on motorboats came from duoprops used on torpedos shot from submarines, if one believes the Volvo duoprop advertising from 1988?
| The Following User Says Thank You to fatlazyless For This Useful Post: | ||
GodSmile (07-06-2016) | ||
Counter rotating props offset the directional torque you get from a single prop spinning in one direction. The boat is thus better balanced. More acceleration, power, with two props taking a bigger bite of water.
| The Following User Says Thank You to Descant For This Useful Post: | ||
Good to know, the only thing I'd question is backing is straighter... I still can't control the boat the way I'd like when backing....
My experience is that most deep vee's back straight, AFTER the hull assumes an angular attitude. (Crab angle) Or you can reset the angle every few yards as you would do with a single engine inboard. This is usually a function of the hull design as much as it is the propeller. Go out in the bay, throw a cushion overboard for a fixed point and try backing various distances with various throttle positions. You will find a stable position for your boat. Next week, people will say "How does he do that? What a great helmsman" (Actually, nobody around here says "helmsman" but the Navy folks will say "Bravo Zulu"). The key, in part, is throttle. That's why you practice in the bay. Being too tentative with the throttle can give poor control, just as much as too much. Unique to each boat.
Quicker acceleration, better reversing, less top speed. I gladly sacrificed 5 mph for the ability to come out of the hole with 12 on board. But there are others that prefer the speed.
I have a duoprop on my cruiser and in addition to what's already been mentioned it helps keep the boat straight at slow/no wake speeds and provides better control in reverse. The downside: Replacement cost, so be extra careful out there!
#11 | |
BT
I have experience with 3,4,5 blade props as well as duo counter rotating props (usually 6 blades) Generally speaking the more blades applied the better the torque but you sacrifice top end. Counter rotating props balance the torque thus gives you better maneuvering.
How the boat maneuver is another matter. Lots of practice and paying attention to boat drift, wind, current as well as throttle response. the more blades you have the better the throttle response. So the duoprop gives a much better response. Big reason why heavy boats have duo props or 4 blades. Most bass boats respond well with 5 blades. Tournament fishing requires hole shots and great maneuvering. The boats do not require duoprops because they are light weight. If you have the need for speed a 3 blade is the way to go. I know of no performance boats with duoprop set up.
I pulled a duo prop unit from the lake last year after someone went on the wrong side of the markers. They are still attached to the drive unit. Props are a little damaged but a marina said they are fixable. If anyone is interested in spares and want to take a look and make an offer......I just want it out of my basement now. Just PM me it is a merc Bravo 22p. I can give other identifying numbers that are also on it
GTO
In the last year I have replaced both of my stern drive boats. The two previous ones had Mercruiser Alpha drives. The two new (to me anyway) ones have Mercruiser Bravo III drives with their counter rotating "duo" props.
My findings: Time to plane is much quicker. For me this makes the two prop syatem worth the cost. Being able to plane the boat nearly instantly means less bow rise and less time making a big wallowing wake. Top speed? I don't know because that's not how I like to run my boats. Backing down into a slip is "different". After years of experience with the Alpha drives my technique relied on either using or countering the wheel effect. The Bravo drives don't seem to have any of this. |
