This is my situation, Had renovation done to my home, Plan on Tv mounted above new fireplace, electrician ran power and cable wire up to come out behind TV, mason came in and did a great job with stone face, Problem is electrician did not run a HDMi cable up there he ran cable box wire, My thought was to mount cable box on wall behind TV, this would not only get me a short shot of HDMI to tv, but also keep box out of site. Spoke to Metrocast, the person on phone wasn't sure that would work, said box is large 6inch x 8inch by 1 inch. I did not think that was that big, has anyone had a situation like this, Any thoughts??
Can you pull a HDMI cable through using a fish wire?
Your TV should be capable of using cable cards which would only require the cable wire already there. The alternative is to pull the cable plug.
#4 | |
The cable box sits flat against the back of the TV, and catches the IR signals fine, but most boxes also allow you to add an external IR receiver in case they are hidden and can't "see" the IR signal. You could also do these: https://www.amazon.com/single-75ohm-.../dp/B00HWIWEMU but they're a bit pricey.
[insert witty phrase here] |
#5 | |
Does the lakes region not offer cable cards? Why are y'all still using boxes?! The single only reason I can see to use a box is for DVR capability, but with so much streaming capability those are almost useless.
Do a google search for wireless HDMI and variations on the search words. There are many products, none of which I have experience with.
#8 | |
Moderator
https://www.yahoo.com/tech/dept-of-d...464415197.html |
#9 | |
In the reasonably near future, set-top-boxes will have gone the way of the CD, VCR, and other obsolete electronic devices.
http://www.pcmag.com/news/345376/cab...t-top-box-plan http://money.cnn.com/2016/04/21/tech...app/index.html |
"everything is wireless"
That's what all my peers keep telling me. Yet when they build a new house or remodel a home when all is completed they always ask me to "help run a wire". Something missed in this "wireless" world. I have attended the NAHB LINK multiple times. And also the EHX (electronic house) trade show multiple times. Wires are still required and needed. I advise all to run an flexible conduit or Smurf tube LINK to an empty covered receptacle box from TV area to receiver area for future proofing electronics/TV's. Yes much is wireless now. But nothing beats a hard wired component. I have wireless and Bluetooth on much of my electronic components but still use wires for most. |
I am pretty much off cable tv.
Using a laptop, I 'stream' contents from NPTV, Netflix, YouTube et al to my smart tv. The TV is essentially a flat screen monitor. This will be the future. I sense the revenue from cable will be gone and the cable companies will become IPs. To assure revenue to the stockholders I predict enormous hikes in IP subscriptions. I guess we will never win!
If you still want to you should be able to pull an hdmi cable through using the existing coax. I've done that a few times.
SIKSUKR |
Direct TV uses a very small box for the secondary locations.
Wireless Genie Mini (Model C41W) Dimensions Height: 1.02 in, Width: 5.91 in, Depth, 3.66 in
La vita è buona su Isola Gatto Nero |
Presuming "wired v. wireless"; 5.G (wireless) and G.fast (wired) in about 3-5 years, 2017 fun begins.
"ISP/cable" box to TV is issue, not from the street; FTTH or coax or Sat from outside of house. In house, co-ax or fiber to box, wired from street, probably coax or fiber , to house.; box HDMI to TV HDMI for best viewing. You don't need HDMI from the street, nor does it exist! Roku box, etc., for streaming v. "cable"; "broadband" v. "cable" (cut the cord). That presumes 5.G and/or G.Fast don't make this thread obsolete except for ... ISP box to TV in a few years! Electrical and ISP run to ISP/cable "box" is all that is needed. HDMI from "box" to TV shouldn't be a problem! Make it shielded! |
If you have a newer DirecTV-Ready TV with the built-in tuner, you only need an ethernet cable running to the TV from the main DirecTV Genie receiver anywhere in the house. I have that setup on my Sony 4K TV and watch 4K movies through DirecTV as well as Amazon, Netflix, and UltraFlix.
#17 | |
The tuning standards have also changed in some cable systems, so older TV's with CableCard slots may not work on modern systems anyway. CableCard also wouldn't give you access to some features like on-demand, depending on the system. Overall CableCard is mostly dying out.
Most newer TV's are "smart" TV and are internet ready. Just hook-up the internet line right to the TV (coax connector). In essence, a built-in streaming box. The presumption is internet availability.
#19 |
This won't work for viewing anything related to a cabletv subscription.
#20 | |
Streaming and what is becoming available via the internet, e.g. Roku box with HBO-GO, Showtime, Netflix, Amazon Prime, etc. is challenging "cable", notwithstanding the same cable companies being the ISP's providing the internet access. |
