Old 05-05-2016, 09:36 PM   #1
Seadrive
Default Boat Launch
I am looking to launch a 35" boat from a hydraulic trailer. Closest launch to Meredith Bay. Meredith docks launch has a limit of 30'. Needs to be cement as boat is 16000 lbs + whatever the trailer weighs
Any help is appreciated
Seadrive is offline   Reply With Quote
Old 05-06-2016, 06:23 AM   #2
Default Call Miles Marine
The Glendale ramp will work but I believe you have to be a Gilford resident or business, or the boat has to belong to a Gilford resident to use it.
The Meredith ramp is poorly designed and the angle of the turn around for the boat and trailer makes it difficult to navigate. Any large combination of boat and towing vehicle needs to pull out across the road to back in successfully.
The ramp at Shep Brown's in Meredith will work.
Call Miles Marine in Gilford. 603-527-1887. They launch large boats, some over 50 feet in length, from hydraulic trailers every day. The do the majority of the large boat transports for most all of the marinas on Winnipesaukee and also move all of the NH Marine Patrol's larger boats. I am sure they can tell you where you can and cannot launch.
PS. A 35 inch boat is not that big!
gator8 (05-06-2016), Seadrive (05-11-2016)
Old 05-06-2016, 07:03 AM   #3
radioman
Default Boat launch
Shep Browns will work well.
The Following User Says Thank You to radioman For This Useful Post:
Old 05-06-2016, 08:33 AM   #4
Miles Marine often launches large boats at Fay's. It is tricky to back in but can be done. I'm sure that they coordinate with Fay's ahead of time.
Old 05-06-2016, 09:40 AM   #5
P-3 Guy
P-3 Guy's Avatar
Default Shep Brown's
Another plug for Shep Brown's on Meredith Neck. Have launched there with a large hydraulic semi truck-trailer, so I know the ramp can accommodate a big rig.
P-3 Guy is offline   Reply With Quote
The Following User Says Thank You to P-3 Guy For This Useful Post:
Old 05-09-2016, 03:38 PM   #6
Ok, I'll be the first wiseguy. A 35" boat should be no problem even by hand.
Old 05-09-2016, 05:36 PM   #7
Lakeboater
Default 2nd
Nope, TiltonBB beat you to it!
Old 05-10-2016, 09:33 PM   #8
Default Can't resist
How does one report stealing a thread?
Old 05-11-2016, 07:21 AM   #9
Seadrive
Default Thanks
35" oops LOL, it really is 35' thanks for the replies.
Old 05-11-2016, 08:32 AM   #10
Meredith Marina?
Old 05-14-2016, 06:08 AM   #11
Default Huh?
Talk about stealing a thread.................WOW!
The post this referred to has now been moved.
Old 05-14-2016, 07:17 AM   #12
FLL's post was clearly meant for the rowboat thread, which he has fixed.
This page was generated in 0.13057 seconds
