Thank you everyone for this forum i think its great! With that being said. I'm just about to pull the trigger on a new pontoon Bennington 18' Pontoon boat and plan on using it on Winni.Could you please give me advise on GSP units what do i need? Do i need a chart plotter? What should i be looking for ect.
thank you |
#2 | |
Good luck! Sent from my XT1528 using Tapatalk |
#3 | |
Why do I suggest a map? Not only will it aid in navigation, but as you begin boating on Winni it will help you chart your adventures.... While GPS units can be used, some of which are coming with markers already in them.... the best way to learn the lake is by using a map.....and asking questions....
Excellent previous advice! Make certain that whatever unit you select, will be compatible with the Bizer Chip. Winni is not forgiving, make certain that you study and are comfortable with the Spar Navigation System. (See page 15 of the NH Boaters Guide available at all marinas and from NH Lakes Assoc, Concord NH ) And yes, go for the Chart Plotter.
An 18' pontoon boat will be rough ride if you travel through the broads. I have a 24' pontoon and it handle chop very well.
Simple GPS or more advanced chartplotter is a matter of personal choice, but in my mind a chart is an absolute must.
I believe most Garmin units require a chip for Lake Winni at an additional cost of maybe $125. When I use my 700 series Garmin chartplotter on the lake it shows me almost nothing except waypoints. I am mostly an ocean boater. I'm hoping some folks with GPS/chartplotters can add to the discussion about chips needed. I still keep my chart handy after 50 years of navigating and enjoying the lake. Peter |
#7 | |
#8 | |
just saw garmin 73dv with lake vu on bass pro shop site for $424.00. has winni on it.
I bought bad elf for my iPad which makes it locate off satellite $99 navionics app
$49 double sided tape to attach to my console. $4 Works awesome |
I would tell you to save your money on the GPS unless you just like to spend money.
Get yourself a nice laminated chart and use it. It won't take you long to know your way around. Just my opinion. Safe boating
I sell the Raymarine Dragonfly 5M with C-Map Essentials bundle. So easy to use you don't need a manual. It's a 2 wire install, out the door for well under $500. I don't like the Garmin software at all, it's too busy, too focused on fishing with all the contouring. The C-Map software is based on the Bizer chart and is the superior choice for simplicity and accuracy.
#13 | |
HOWEVER, no matter how well you know the lake (and I feel quite confident) a GPS is an absolute awesome "addition" when boating at night. .
| The Following 3 Users Say Thank You to Phantom For This Useful Post: | ||
Having a GPS is a great way to cross reference where you are on the Bizer, and the Bizer is invaluable. One last thing, get a GPS you can see...e.g, whether you use eye glasses, contacts or not, its great to be able to effortlessly glance down for your position if your attention gets diverted.
Thanks, Loub52 |
| The Following User Says Thank You to Loub52 For This Useful Post: | ||
DRH (03-03-2016) | ||
#15 | |
on a big lake like this with many hazards and unexpected dangers for a new boater, I recommend BOTH a GPS with chip and a map/compass.
I started with a GPS with no chip and a Bizer map. The GPS gave me my general location and the map let me see the detail I needed to navigate. This meant I would often stop at planned points and pull out the map to confirm where I was and where I was headed. It also meant careful planning before i left the dock. Now with the GPS with chip (Navionics is GREAT). I rely heavily on that as it give the detail of the map but is easily read at a glance though I seldom have to look as I have become more familiar. Don't get used to staring at the GPS though...your eyes should be on the water but slowing down for a quick look is fine. HOWEVER, I still carry my map and compass because like all electronics...anything can happen and leave you blind without a map. The Bizer also has lots of other information that Navionics does not like places to get gas, food etc. |
#17 | |
Rattletrap --
Sounds like your new to boating on Winni .... Welcome ! From your first post, you are getting a 18' Pontoon - so no major concern (as you will have a shallow draft) - but in your last post you mention the boat is coming equipped with a Depth Finder. Please be aware that the LAST piece of electronics of any value on a boat on Winni is a depth finder. We are a glacial lake.... rocks "Pop Up" out of nowhere and are in the most unexpected areas. Thus the markers. By the time your Depth Finder alarm goes off you've already experienced the THUD of hitting that rock and are now back to 10-30 ft of water. This is true along shorelines as well. You didn't mention it directly, but I don't want you to think that a depth finder will have ANY value --- other than amusement that you are in 180' (or whatever) of water or to watch how rapidly you go from 100' depth to 25' and back again i.e. the rocks Again -- Welcome & safe boating .
#19 |
I have to say that I would by far prefer a GPS to a map if I had to pick. The GPS includes the chart and tells you where you are on it. Of course constant visual and depth confirmation are used to cross-check the GPS whenever I go out. Navigating this lake at night without GPS is very difficult. Heck, navigating this lake in daytime can be difficult, and we won't even talk about fog (if you're an islander, you'll encounter this). I do have paper charts in both boats and my cell phone also has the Navionics app (which is excellent, and I sometimes hand off to a passenger when night navigating to back me up). As for my background, I was a trained U.S. Navy navigator, and navigated across the ocean using a sextant and LORAN. Give me a modern GPS any day!
#20 |
I don't mean to quibble but I always thought you used "maps" on a highway and "charts" on the water.
![]() Peter |
#21 |
#22 |
I've got a few year old Garmin chart plotter/depth/gps that I should probably sell. But I think it's on my boat, so I can't get to it until unrwap time.
It was new on a boat I sold a few years ago, and I used it as a 'spare', but one doesn't really need a backup chart plotter on Winni. My back up is my paper chart.
Don't listen to me, obviously I don't understand what I'm talking about! Let's help each other save time and money: WinniGas.com Get a backup/duplicate RF DESS Key for your SeaDoo, CanAm or SkiDoo RideKey.app |
#23 |
I always have a GPS on my boat and a Bizer Chart. I use the Bizer chip in my GPS so my GPS screen and the Bizer chart are showing me the same thing.
I like and use Garmin GPS units however since Jan 2015 Garmin has changed their units so they do not accept 3rd party chips like Navionics or Bizer. In my opinion, the Garmin Lakeview Chart is OK for fishing but not for navigation on Winni. Take a look at The other units but be sure they will work with the Bizer chip. |
| The Following User Says Thank You to townsde For This Useful Post: | ||
motionxxusxx (06-02-2016) | ||
#24 |
I was reading some reviews as i don't know much about these. Do all units allow you to put in a way point and then give you the basic safe route to that point regardless of what obstacles are in the way?
Captain of the "Day Tripper II" .......There are a lot better people a lot worse off!! |
#25 |
I do not know of any that do that. You have to create your own routes.
Sent from my XT1254 using Tapatalk |
#26 |
The Navionics boating app for smartphones or tablets allows you to do that with an in-app purchase option. Out of curiosity, I tried it on a route from Moultonborough Bay to Meredith and it did a pretty good job.
#27 |
My Garmin will do that. It uses the "suggested safe passage" routes.
#28 |
I'm mainly on salt water, where I have a mounted chart plotter and I keep an older Garmin Colorado running for backup. It's also nice for passengers to look at without cramming the helm. I always have paper charts on board. I've had nav systems go down together, and its pretty nice to pull that chart out when needed. it usually happens as you approach a shoal or at speed
![]() I think the same goes for the lake. Always have a paper chart on board. I'm learning the lake, and have found that the navionics app with my Iphone is pretty nice. it covers the U.S. and I was happy to see the lake included. A good way to learn is keep the gps running and compare landmarks to the chart as you go. |
#29 |
What model do you have?
#30 |
