Old 10-13-2015, 05:08 PM   #12
Default Notes on Prop selection
1. Don't assume your boat will come with the right prop....
2. Talk with the dealer about your planned usage...
3. Find others with the same boat and engine and see what they have found
Now as for the advice thats been given here..... listen to ishoot, Dan has had many Pontoons......
Once you load the boat up, all the WOT specs etc. go out the window... Fully loaded you should expect to be at the lower end of the WOT spec.... moderately load you should be up towards the higher end of the Spec.....
This page was generated in 0.39430 seconds
