Old 07-24-2015, 05:17 PM   #1
Dave M
Default Septic System
My nephew is buying an older house. He is having the house inspected.
He would like to have septic system checked out. Are there any suggestions
from the forum on this. Do the persons who pump out septic systems a person to contact.
Thanks Dave M
Old 07-24-2015, 08:13 PM   #2
winnipiseogee
My brother had his septic very expensively fail a year after he bought his house so what you are thinking is exceptionally smart.
Unfortunately I'm not sure what they can find out without digging it all up. My understanding is that its very hard to see just how filled up the septic is.
Anyway I highly recommend Lamprey Septic. They are awesome.
Old 07-24-2015, 08:31 PM   #3
Our septic inspection did two major things: it told us the condition of the leaching field and septic tank/components. Essentially, we were told that with regular maintenance (pumping every couple years) and being careful with what we put into it (no oils, greases, paints, bleaches, etc.) that we still had lots of life in it. The system was installed in 1967.
Old 07-24-2015, 09:15 PM   #4
TheProfessor
Concord DES has a copy of all septic systems since the 1980's or thereabouts.
Get a copy and take to a septic designer. Find out who constructed/installed septic system and speak with them.
There have been various designs of septic systems. From a 55 gallon drum to a 1200 gallon concrete double/triple chamber.
Any part of the system can fail. I view too many newer systems where the homeowner lets trees grow on top of the leach field.
Trees near the tank. Trees near the lines going from house to tank and such.
If this is a pump system find out when pump was changed.
A lot of variables involved.
Old 07-25-2015, 08:18 AM   #5
I second Lamprey's......they can track the history of the system and tell you exactly what condition it's in. Best of all they are completely trustworthy.
We use them commercially and for our home as well. They'll never let you down day, night or weekend in an emergency.
SAMIAM is online now   Reply With Quote
Sue Doe-Nym (07-25-2015)
Old 07-25-2015, 08:19 AM   #6
Dave M
Default who
thinkxingu, who did your inspection.
Thanks Dave M
Old 07-25-2015, 09:24 AM   #7
www.alslaconiasepticnh.com was super-duper, and would use them again.....in other words....thought the price was fair ....believe it was $200 to pump out a 1000-gal tank.
Just in case you were wondering where does this yucky messy septic pump-out go from here ..... believe it goes to the Meredith Water & Sewer Dept, where the septic truck unloads it into the town sewer system, but could be I am incorrect, and it gets trucked someplace else? Where does it all go?
Old 07-25-2015, 09:56 AM   #8
Joebon
Joebon's Avatar
JB & Sons tested for us when we bought our house.
Joebon is offline   Reply With Quote
Old 07-25-2015, 04:30 PM   #9
songkrai
Lamprey tells me he has to truck to Tilton. That's why he had to purchase a large tanker truck.
Old 07-25-2015, 10:25 PM   #10
This was for our home in Merrimack, NH. Where is the house you're asking for?
Thanks Dave M
Old 07-26-2015, 06:59 AM   #11
When the tank is inspected, it needs to be drained first. The inside is what gets inspected.
If you ever feel a need to have the outside of a tank inspected, after you own the house, you might as well have a new one ready to install at the same time. The digging is going to cost a lot and if the tank is bad you can't leave it exposed until a new one is delivered.
Old 07-28-2015, 12:49 PM   #12
DesertDweller
We used Lamprey as well. We got lucky in that the previous owner must have gotten it pumped out prior to us buying it. When they did the inspection and pulled the lid off of the tank he put his probe in and there was virtually no solids. Was also helpful in that we marked off everything so that future pump outs/inspections would be easier.
Old 07-28-2015, 04:21 PM   #13
Originally Posted by DesertDweller View Post
... Was also helpful in that we marked off everything so that future pump outs/inspections would be easier.
I measured from two permanent features to where my access is. You should try that and right it down or make a diagram to keep with your documents. Mine is 15feet from nearest driveway corner and 12.5 from the next nearest corner.
Another technique is to bury a brick over the access, flush with the ground level. Sometimes though, these get moved by people (kids) who don't know what the brick is for.
upthesaukee (08-08-2015)
Old 08-08-2015, 03:31 PM   #14
dmjr
dmjr's Avatar
Thumbs up
I use Lampreys at my home which he has taken care of for the past 25 years.
DMJR
Moultonborough, NH
Old 08-08-2015, 03:57 PM   #15
I have my septic tank measured and drawn, as well as our well, and the drawings are on the wall of our mudroom, behind the door.
I live here... I am always Upthesaukee.
Old 10-09-2015, 12:27 PM   #16
correira99
I had Lamprey inspect the system for a house I bough 5 years ago and they said all was fine.
Unbeknownst to them, I had to have it replaced as roots were growing in, pipes were crushed and lines were blocked.
I have done my research so please realize without getting a camera down in there, digging stuff up and getting in there, the inspection won't be able to tell the entire story 100%
correira99 is offline   Reply With Quote
This page was generated in 0.09828 seconds
