Old 02-28-2015, 09:00 AM   #1
Default Frozen Home Advice Request
My friend called me late last night with a cold house. The propane furnace had quit due to snow obstructing the exhaust vent. The house was 32*.
A tech from the propane supplier got the furnace running again in less than an hour. Now the task of thawing and assessment has begun.
So far he has found three cracked toilets. We suspect that his refrigerator (water/ice disp.), dishwasher and washing machine could be damaged.
A larger concern is the pipes in the walls. They are pex.
He has the furnace heating up the house and the water is turned off at the supply. Towels are in place around the toilets to catch the water as they thaw.
He intends to call his insurance co. this morning.
My questions:
Does he just need a plumber or is this more of a Serv Pro type of job?
Can someone recommend a plumber for him?
Is pex better or worse than copper in this situation?
Why did he not buy a cold house alarm when I told him about the one I had installed in my house?
Old 02-28-2015, 09:08 AM   #2
www.spearsbrothers.com in Belmont is a good place for buying toilets. They have all sorts of recycled building items that came out of demolished buildings.
...just furgetabout Lowe's of Home Depot, and go to Spears!
Can recall going to Spears .... and they had these medium brite green bathroom ...toilets and sinks....in hospital green....big sturdy green porcelain American Standard toilets that came out of some hospital in Hanover, NH.... for short money....u-know!
Old 02-28-2015, 09:45 AM   #3
Happy Gourmand
Happy Gourmand's Avatar
The PEX piping SHOULD be fine. I would remove the toilets while they are still frozen if it's not too late. More of a plumber issue unless there was any flooding from the busted toilets.
Old 02-28-2015, 10:09 AM   #4
So far he removed the frozen toilet tanks and wrapped towels around the bases.
Old 02-28-2015, 10:22 AM   #5
pjard
I would remove the bases of the toilets as well...usually two bolts....remove all doubt. I would call Penco in Gilford...they are great! 603-293-7157
Old 02-28-2015, 04:54 PM   #6
MOXIE
Default Frozen House
Pex is a lot more forgiving than copper. What can happen if pex is frozen is that it can blow the fitting away from the tubing. When thawing out a house, it is safer to thaw it very slowly. All the appliances listed could be damaged, but the hot water heater was not mentioned. also, if on a well, the expansion tank could be damaged.
Before turning the water back on, the entire system should be pressurized with a compressor to check for damage.
MOXIE
MOXIE is offline   Reply With Quote
Old 02-28-2015, 06:04 PM   #7
A plumber has been contacted. He intends to use air pressure to check for leaks.
The water heater was on and thus not frozen.
This all started with snow over the vent.
For those who see their houses infrequently in the winter, get someone to clear out the vent area!!!
Thanks for the responses!
Old 03-01-2015, 08:25 PM   #8
TriDad
TriDad's Avatar
My questions:
Which cold house alarm do you use ?
TriDad is offline   Reply With Quote
Old 03-01-2015, 09:18 PM   #9
secondcurve
I use the below freeze alarm and it works great. It saved me twice this year. The biggest issue is if you your phone is via cable it will become disabled when the cable goes out. Land lines work best since they tend to become disabled less frequently than cable phone lines.
Control Products Intermediate FreezeAlarm Custom Temperature and Power Outage Alarm FA-I-CCA with voice message to up to 3 phone numbers / Quick Status Check
by Control Products
Old 03-02-2015, 01:04 AM   #10
This one:
http://www.amazon.com/Skylink-TS-101.../dp/B00106K2KG
Old 03-02-2015, 01:08 AM   #11
So the final (he hopes) carnage report includes:
Three toilets
Refridgerator water filter
Sprayer hose for sink
I hope that's it!
Old 03-02-2015, 07:20 AM   #12
secondcurve
Talk about terrible reviews! I'd stick with the Control Products freeze alarm I use. Simple, cheap and lots of great reviews.
Old 03-02-2015, 07:22 AM   #13
secondcurve
Three toilets
I hope that's it!
It sounds like he was lucky. If the problem happened a day or two earlier he'd likely have a very big claim on his hands.
Old 03-02-2015, 07:59 AM   #14
Neko
I also use Freeze alarm in both of my homes.
Neko is offline   Reply With Quote
Old 03-02-2015, 09:16 AM   #15
Had I read the reviews prior to purchase I would have bought a different one.
It seems to work ok so far.
secondcurve (03-02-2015)
Old 03-02-2015, 12:11 PM   #16
Default Dates on the reviews...
Five reviews, and I think they were from 2009-2011. Perhaps they got their act together over the last 4 years or so.
Old 03-02-2015, 01:39 PM   #17
Jersey Ed
I have been using the above mentioned "intermediate freeze alarm". for several years now. I first learned of it a number of years ago while lurking THIS VERY FORUM and couldn't be happier with the product. I use it in my second home in upstate New York which I keep heated all year long. Several points that have not been mentioned yet about the alarm:: you set the "alarm" conditions as you want them. Set the temp that you want to set-off the alarm [hi or low temp] Amount of time the power to the house has been off before the alarm is triggered and the condition of the back-up battery. You can call the unit as many times a day as you want to and you can change any of your settings from any other phone, you do not have to be at the unit location to make changes.
Jersey Ed is offline   Reply With Quote
The Following User Says Thank You to Jersey Ed For This Useful Post:
Old 03-03-2015, 06:52 AM   #18
Tell them don't throw anything away until they call their insurance agent. This job is likely to total way above the deductible if they have the coverage.
Old 03-03-2015, 02:48 PM   #19
At the moment I think he's planning on eating the expense. Between the plumber and the toilets he should be above the deductible now. To me the real danger in eating it comes from finding out later that there is a leak in a wall. Tearing up the house to get it and the possibility of mold abatement could get costly.
Old 03-07-2015, 01:26 PM   #20
Default ... $12.49 water leak alarm
For about 12.49 (9v battery not included) the Lowe's in Gilford sells a small water leak detector that's about the size of two packs of cigarettes, powered by a 9v battery and makes a 105-db alarm that sounds for three days or so. It has two metal contacts on the bottom which are designed to be placed onto a carpet.
Located in the back of the Lowe's in Gilford in the water pump area....seems like a good item...
Old 03-07-2015, 04:39 PM   #21
Ya but, once it starts ringing, isn't it a bit late to drain the swamp?
Old 03-08-2015, 08:39 AM   #22
Ya but, ... ?
These are good if you have someone who checks your house. Not all leaks are geysers and may not be noticeable to somebody rushing through the house in the rubber shoes.
Old 03-08-2015, 09:00 AM   #23
That's a good point. I was thinking in terms of catching the house before it freezes. The product FLL suggests would alert me to other types of leaks that could go unnoticed.
Thanks FLL!
Old 03-08-2015, 06:35 PM   #24
Default Back in the 70's and early 80's...
My folks had a light bulb fixture plugged into a wall socket. The bulb in the fixture was bright red. The fixture had a temperature sensor in it that caused the lamp to come on if temp went below 40 degrees (I think). It hung in the front window. All the neighbors on the street had their phone number and knew where the hidden key was kept.
If the light went on, they could go inside, make sure the furnace was ok, check the outside tank for oil, and if the heater could not be reset or restarted, they would call Dad and let him know.
Only happened once or twice, I know once because the oil tank ran dry. Never any damage thanks to good neighbors watching out for neighbors. they can sure help that damage like OP spoke of does not happen,.
Old 03-10-2015, 03:19 PM   #25
I have one of these in my ski house in Franconia.
upthesaukee (03-10-2015)
Old 03-10-2015, 07:45 PM   #26
TheProfessor
There are two internet based temperature sensors out there.
Will send you an email to you computer/pad and text message to your smart phone.
Not cheap. And you do need wifi internet on.
Do read the reviews on each.
Old 03-10-2015, 08:46 PM   #27
My new neighbors have one of those red-light thingies. For some reason it was on for a few days even though they, and many of their friends, were present. It must have been more serious than I thought because about 11 last night, the police came and evacuated them all in of those vans the Sherriff's department has.
This page was generated in 0.16176 seconds
