I have a Wifi only IPad and I want to use it as a chart plotter with the Bizer Winni map. So, I have been researching how to do it and a friend suggested I get a Garmin Glo. Apparently this will allow me to use the IPad as a chart plotter.
I am wondering if anyone here has any experience with it? It seems like a great solution. http://www.amazon.com/Garmin-Portabl.../dp/B00AYAZENY
"The true meaning of life is to plant trees, under whose shade you do not expect to sit." Nelson Henderson (1865-1943) |
Moderator
I don't know how well it works but I also found this gadget to add GPS to an iPad:
http://www.amazon.com/Bad-Elf-GPS-Li.../dp/B00G2BX616 |
| The Following User Says Thank You to webmaster For This Useful Post: | ||
Airedale1 (01-21-2015) | ||
Thanks Don, I will check that one out as well.
I have the Dualxgps150A and use it with the IPAD and IPHONE for Navigation, it works great. Many chart options for the IPAD that are very reasonably priced. For me this makes more sense than spending $100's for a marine Nave system for the lake if you already have an IPAD.
http://www.amazon.com/Dual-Electroni...=dual+xgps+150 |
| The Following User Says Thank You to Puffin For This Useful Post: | ||
Airedale1 (01-23-2015) | ||
I also use the Dual 150 with the ipad and the LakeWini app. Both work great, especially valuable when visibility is reduced, ie. night time.
lilysdad, I was just browsing through the forum and noticed that you are fairly new to posting on the forum and glad you have joined us. Have fun and enjoy the Winni Forum while making many new friends.
If your familiar with the lake and are just looking for something to keep in check the Navionics App on my galaxy phone works very well. The screen is hard to see in the day but at night it is really slick. I've got most routes I run programmed in as "Tracks" and lite it up when visibility is not ideal at night. Each time I've used it it's been spot on in terms of accuracy and all the bouys are on it. I do have it on my tablet but haven't tried it as the phone works fine for me.
http://www.thehulltruth.com/dockside...-app-ipad.html
I posted the same question on "The Hull Truth," and the Bad Elf line got more specific references than anything else. I really like the BlueTooth version that will interface with up to 5 devices so if your passengers keep asking "Are we there yet?" you can tell them to use their own devices to look it up. ![]() On thing to consider though, is what are you using it for? If it's for driving in areas serviced by your cell provider it will be cheaper in the long run to pay the extra $10 a month since their maps are updated more often than some GPS tools. You especially need to be aware of this if the unit you are looking at does not have update capability or has been on the market so long that product support may be about to end. Good luck! |
Don't most tablets have a built in GPS?
If so, why buy an external GPS, just use the internal GPS that is built into the Tablet / phone? Or is this an area where Apple is lacking (I don't have an ipad so I'm not sure)?
Don't listen to me, obviously I don't understand what I'm talking about! Let's help each other save time and money: WinniGas.com Get a backup/duplicate RF DESS Key for your SeaDoo, CanAm or SkiDoo RideKey.app |
Ipads only have GPS if you have WiFi access. If it is a cell phone model then it can be its on hot-spot and the mapping, and GPS apps will work, or so I have been told.
Are you confusing having the ability to download map data vs having a GPS receiver?
The GPS will only provide your lat/long position. It shouldn't need WiFi or Cell access for that. But if you try to display something like a google map, then you will need internet access of some sort (via WiFi or cell signal) to be able to download the map data itself. However, if you purchase map data such as the Bizer or Navionics app, then you will have the map already on your system, and you won't need WiFi or a cell signal to use it. In this case the GPS provides your current position, direction of travel, speed, etc. So unless I'm wrong, an external GPS device will only be an extra cost item that you may not need. Of course, I don't own an i-anything, so I could be wrong, but if they force you to have a WiFi or Cell signal to use the GPS, I just found another reason not to like an I-anything.
Don't listen to me, obviously I don't understand what I'm talking about! Let's help each other save time and money: WinniGas.com Get a backup/duplicate RF DESS Key for your SeaDoo, CanAm or SkiDoo RideKey.app Last edited by Rich; 02-03-2015 at 10:23 AM. |
#12 | |
Thanks for clarifying this. I wasn't aware that Apple doesn't include a GPS in the WiFi only Ipads. It's too bad and someone limiting.
So my statements are meaningless to a WiFi only ipad.
