Old 03-14-2014, 07:53 PM   #1
Ricajote
Default Fix-It Man/Wood Stove Repair
I have a beast of an old wood stove that needs some attention (remove shell, sandblast all, repaint plus minor repair to door, and reassemble) or replacement. I am old enough to think that repairing things is the first way to go. Someone with right tools, taps for screws that break off, sandblast, and a sprayer can probably do it all in 12+/- hours.
Any suggestions appreciated.
Ricajote is offline   Reply With Quote
Old 03-14-2014, 08:26 PM   #2
RLW
RLW's Avatar
Smile
Ricajote, I just noticed that you are fairly new to posting on the forum and glad you have joined us. Have fun and enjoy the Winni Forum while making many new friends.
I am sure you will find someone and/or many that will be able to help you out.
Ricajote (03-16-2014)
Old 03-14-2014, 08:30 PM   #3
Rusty
Could you post some pictures of the "beast" ?
Old 03-14-2014, 08:52 PM   #4
Lakeboater
Instead of repainting maybe just a good wire brushing and then some stove black to make it look new again.
Old 03-16-2014, 09:52 AM   #5
Ricajote
Default A Picture of the Beast
Here is a picture of the stove. It has a sleeve around it attached with rivets and screws (a number of the latter I suspect will break off and need to be tapped out) which needs to be removed so the box can be cleaned and painted. Paint the sleeve, rep[air the door and reassemble. If I was any good at spray painting and had a sand blaster and some taps could probably do it my self but... I am not, and do not so can't.
Thanks for any suggestions
Old 03-16-2014, 11:50 AM   #6
Rusty
Thanks for posting the picture of your "beast" of a stove.
I can see why you are attached to it and want it repaired.
I just did a quick google and this guy might be able to help you.
http://www.grahamthestoveman.com/woo...tion-services/
Graham the Stoveman
PO Box 130
Bartlett, NH 03812
email: [email protected]
Phone: 603-662-8103
The Following User Says Thank You to Rusty For This Useful Post:
Old 03-16-2014, 03:42 PM   #7
Default I have no real first hand knowledge of them...
...but I have heard 2nd and 3rd hand that they are good to deal with, and are closer than Bartlett NH.
Just another option:
http://www.woodmansforgefireplace.com/
Old 03-16-2014, 08:53 PM   #8
Exclamation Test it first...
I've been the owner of three wood stoves: one is marked with the date of its casting—1873. My newest cast iron wood stove weighs 600 pounds. (!)
One well-used cast iron wood stove from the 1970s unexpectedly burned through the backside. So, first I'd check on your stove to see if it's worth the effort and expense of a repair.
I agree: even with spray paint especially designed for this job, repainting is probably not a good idea. As soon as the stove reaches certain high temperatures, you could get weeks of "burning-paint odors".
(Ask me how I know).
This page was generated in 0.15311 seconds
