Old 01-20-2014, 01:15 AM   #1
IslandRadio
IslandRadio's Avatar
Default Power out on Rattlesnake Island
Looks as if the power is out on Rattlesnake Island.
Both the IslandRadio webcam (http://www.rattlesnakeisland.net/cam.htm) and Snake Eyes are both stuck on Saturday at about 1:14 in the afternoon.
Anyone else affected by this?
IslandRadio is offline   Reply With Quote
Old 01-20-2014, 09:50 AM   #2
Island Girl's Avatar
Default Did you call the power company
It could be a land issue.
....... Make Lemonade
Old 01-20-2014, 09:57 AM   #3
Webbsatwinni
Webbsatwinni's Avatar
I looked on the co op map and it doesn't appear that there are any reported issues, I think that indicates island issues.
http://www.nhec.com/oms.php
Webbsatwinni is offline   Reply With Quote
Old 01-20-2014, 10:18 AM   #4
Default You have to report it
Unless someone calls... It won't show up on the map. So give them a call.
Old 01-20-2014, 11:53 AM   #5
IslandRadio
I called it in. The Co-op thinks there's power on the Island, but I reported the outage nevertheless.
Old 01-20-2014, 11:54 AM   #6
Default How about DSL outage
Try calling Fairpoint. Sorry I am at work and cannot call anyone right now... if you folks could do it we would all be grateful.
Old 01-20-2014, 12:00 PM   #7
Default IM me your phone number
Steve please give me a number I can call... we are troubleshooting with Power co.
Old 01-20-2014, 12:04 PM   #8
IslandRadio
Fairpoint is probably functional, unless the lines are REALLY down. I don't think they can test anything unless there's something working at the other end (in this case, the Island end).
The co-op appears to be acknowledging the outage. It's not on the map yet, but they are now reporting 2 customers who are out in Alton. There was only 1 before I finally made the report this morning.
Old 01-20-2014, 12:11 PM   #9
Default Your power line
Do you know from where your power is feed. The trunk, the north feed and the south feed? This is really important to know.
Old 01-20-2014, 12:44 PM   #10
IslandRadio
I sent you a P.M. with my phone number
The power comes from the peninsula (the "thumb") at so-called Alligator Point. Then it splits. I *think* we're on the north split (as opposed to before the split) that ultimately goes up and around to your place as well.
Old 01-20-2014, 01:40 PM   #11
Webbsatwinni
You made the board!
Alton 2 4315 0.05%
Old 01-20-2014, 08:56 PM   #12
As you probably know the Coop has furnished installing "smart meters" and has been working on the data network infrastructure: http://www.nhec.com/pdf/AMI_faqs.pdf
When done they should be able to detect low density outages as they occur which will be good for the islands. I did not see any info as to when that should be.
Old 01-20-2014, 09:42 PM   #13
Rattlesnake Gal's Avatar
Arrow Rattlesnake Power
We are on a different feed from the northern end of the island, but have no way to know if power is up. Sorry!
Old 01-21-2014, 02:38 PM   #14
IslandRadio
Originally Posted by Webbsatwinni View Post
You made the board!
Alton 2 4315 0.05%
Yeah, but no "dot" on the map showing the location, like they usually do
Old 01-22-2014, 07:38 AM   #15
rgilfert
rgilfert's Avatar
Default Related Question.....
We had an aquatherm bubbler installed last fall to protect our new dock on the island. Obviously it doesn't work when there is a power outage on the island, so my question is...if the water freezes around my dock during an outage and then days later the power comes back on does the bubbler do anything (i.e. will it cause the ice to melt or will it stay frozen for the rest of the winter irrespective of whether the power is on)?
Old 01-22-2014, 09:32 AM   #16
Webbsatwinni
It will chew through the ice, it may take a bit to do but it does. We have been up in the winter and found our bubbler not working, fixed the power issue and it cleared up.
The issue is if the power isnt fixed by spring, but then my sledding trips are gone so that won't happen!
The Following User Says Thank You to Webbsatwinni For This Useful Post:
rgilfert (01-22-2014)
Old 01-24-2014, 08:41 AM   #17
Webbsatwinni
We are down to one, did someone get power back?
District Township
Township # Out # Served % Out
Alton 1 4313 0.02%
Total 1 79672 0%
Old 01-24-2014, 09:04 AM   #18
dowshill
Hi, we are on of the four that don't have electricity and are thinking of having it installed. I was wondering how having the loops connected would affect the power supply/outages on the island. All four have been talking about it w/ some more willing than others but I think if the ball got rolling all would probably do it. I am concerned about being the last one on a long string if we are the only ones who do it. Des anyone have any insight on this?
dowshill is offline   Reply With Quote
Old 01-26-2014, 07:43 PM   #19
Moon Light Bay
Location: Tucked in the armpit of the appendage facing south/east
Default Ice too Rattlesnake
Any one know how the ice is from Minge Cove to the snake?
Can one walk out?
Thx
Moon Light Bay is offline   Reply With Quote
Old 01-26-2014, 08:34 PM   #20
Nauti Crew
The power is still out on Rattlesnake. The ice from Rattlesnake landing to the Broads side of the island is 9-12 inches of solid black ice. My husband snowmobiled out there and spent the weekend. He measured the ice every couple of hundred yards on the way out. He said that he saw a lot of snowmobiles on the Broads in front of the island. He also said that there is still open water between Diamond and Welch.
Nauti Crew is offline   Reply With Quote
Old 01-26-2014, 08:48 PM   #21
Default Power out to part of Bear Island.
There are power outages in several areas. I had no power on Bear Island when I got out there on Saturday. I called NH Electric Coop, spoke to somebody there, they were unaware power was out. They told me they will not send anyone out until the ice is at least 12" thick and safe enough for their crews. He estimated that maybe by next weekend they may be able to get out there and restore power, it all hinges on how safe they feel the ice is.
Far as the power being out on Bear Island, my guess is that this is a partial outage because last night the light at the postoffice was on, taking a sled ride around the island there was somebody home down on the south part with their place lit up. Not sure if they like I were on generator power or what. So just be aware that part of the island is in the dark so if you're headed out there be prepared.
Beautiful weekend though other than that.
Old 01-26-2014, 10:58 PM   #22
IslandRadio
Right! The Co-op told me the same thing - won't go out until the ice is more than a foot thick. Could be another week - we'll see.
Old 01-27-2014, 10:00 AM   #23
I was a bit surprised that they were unaware of the power being out since I know they have been around replacing all the meters with "smart" ones which not only allow them to read them remotely but also see if they stop responding (IE no power) but apparently they are not 100% done with that so unless they get called they don't know.
I can understand their reluctance to send out a crew over the ice if it's not safe. Hopefully they will make the rounds soon. Ice is plenty thick around Bear Island anyways.
Old 01-27-2014, 07:22 PM   #24
Default Don't believe everything you hear
The folks on the phone do not always have current info. I had DSL to my camp for sometime and the FairPoint folks on the phone were telling people there was no DSL to the island.
The power company is the same. Have no fear, fellow islanders are working with the local guys to get power as soon as possible. I hope my webcam will suddenly appear again soon!
IG
Old 01-29-2014, 11:23 AM   #25
rgilfert
rgilfert's Avatar
Default Status Update - Rattlesnake Island Power Outage
I received the following response to an inquiry that I made this morning regarding restoring the power on Rattlesnake Island:
" I did check with our control center about this outage. The crews were working there yesterday. There is a very large beech tree that has fallen, lines are down and poles are broken. Our crews cannot handle the tree themselves and are going back tomorrow with a tree company to handle the complicated removal of the tree. Once the tree is taken care of, they will need to replace the poles and then put up the lines. They are hoping to get power on by the end of the week but it may go until the beginning of next week depending on how long the tree work and setting of new poles takes.
Thank you for your patience while we work to restore power safely."
The Following 3 Users Say Thank You to rgilfert For This Useful Post:
IslandRadio (01-30-2014), Nauti Crew (01-29-2014), Webbsatwinni (01-29-2014)
Old 01-30-2014, 06:15 PM   #26
Webbsatwinni
And we have power!
rgilfert (01-30-2014)
Old 01-30-2014, 06:18 PM   #27
Webbsatwinni
Current pic
Old 01-30-2014, 06:26 PM   #28
Default ... and Snake Eyes is back
I really missed my view! It looks pretty solid out there....
IG
The Following User Says Thank You to Island Girl For This Useful Post:
trfour (01-31-2014)
This page was generated in 0.12514 seconds
