Old 01-20-2014, 10:32 AM   #1
IslandRadio
IslandRadio's Avatar
Default It depends on where you live...
Mostly, what you need will depend on where you live. I don't just mean in what town, but how high above average terrain you are.
Most DTV content is delivered over UHF, although I believe NHPTV (ch. 11) and *possibly* channel 9 are using their old VHF allocations. Check this to be sure.
But, the fact remains that the #1 factor, all other things being equal (distance, etc), is your height above (or below) physical obstructions such as hills and mountains. So, are you high up and/or are you shielded in certain directions by hills or mountains?
An outdoor antenna mounted as high as possible is always superior to anything else. A rotator is really almost required.
Use a mast-mounted preamp, located right at the antenna itself. Use coax cable to bring the signal from the preamp to your in-home distribution system (if you have more than 1 TV receiver).
We do NOT have cable or any other paid TV delivery services here. Everything is off the air. The house is located about 45 miles West-North-West of Boston, so definitely in a "fringe" area. But, we're on a hilltop and that makes all the difference.
IslandRadio is offline   Reply With Quote
This page was generated in 0.43522 seconds
