04-02-2013, 11:12 AM | #1 |
Tub/Shower regrouting
Any suggestions for someone that can regrout a tub/shower area in Moultonborough? Thanks...
04-03-2013, 05:58 AM | #2 |
Knock, knock, hello...Anybody? Need to get it done this spring.
04-03-2013, 06:25 AM | #3 |
Pretty easy to DIY
With simple tools, knock out all the grouts, make sure the tiles are dry and clean and regrout. I use silicon grout, it last a long time.
04-04-2013, 05:55 AM | #4 |
Thanks but would attempt it myself if that was the plan...Will try the old trusty phone book or google.
04-04-2013, 08:46 AM | #5 |
What about Home Depot? We purchased our hot water heater from them and an independent company installed it. They did a great job.
We are looking for someone to re-tile our stall shower here in NY and plan to call HD and get a quote from one of the contractors they use. Good luck in your search |
04-04-2013, 09:20 AM | #6 |
Couldn't a painter or tile guy do that?
04-05-2013, 05:14 AM | #7 |
None I know of
Honestly this is the first time I've seen someone looking. Painter won't tackle it because it requires special tools to remove the old grout.
I would check with places that sell and install tile, local hardware stores etc. It really is not that hard to do provided you have a means to remove the grout. And your not looking to remove it all just the top surface and any loose material. I have done my own tile work and have the tools to do all of this but no desire to do it for money, I'll stick to what I do best, painting.
"better to have a short life that is full of what you like doing, then a long life spent in a miserable way.." |
04-05-2013, 06:50 AM | #8 |
Lowes in Gilford
There is a guy in the tools dept that installs tiles on the side. I can't recall his name, a little guy wearing a cap. You can ask him as he can vouch for his work by giving you names of past customers.
04-05-2013, 04:38 PM | #9 | |
I needed colonial trim and 5" baseboard for a job I'm doing. Boulia Gorrell was a lot cheaper on both items as well as advantec.
04-05-2013, 05:43 PM | #10 |
I have seen quotes from both Lowe's and HD and they are almost always higher on all but 2x4s. All the larger framing lumber is and always has been higher.
04-08-2013, 01:52 PM | #11 |
Bath Fitters
dpg,
Had the same issue years ago. Found that Bath Fitters could do the job as inexpensively as having it regrouted. Check them or a similar service out. Hope this helps, Bill |
04-09-2013, 05:57 AM | #12 |
Thanks and yes have looked at bath fitters probably going with re-grout for now. Yup it's a tile guy that does it and have read Tiling threads here and made a couple calls recently. For the most part I try to stay away from the in-house installers at places like HD but I suppose you can get good and bad everywhere.
