Go Back   Winnipesaukee Forum > Lake Issues > General Issues
Old 10-20-2012, 12:41 PM   #101
NoBozo
Default The Engineers Report
Our Town Owned 1.5 MW Turbine has been inactive since June 16 with a broken gearbox. The engineers report just came back yesterday. Lots of metal shavings in the oil. Gears and bearings chewed up.
The engineers are calling our turbine an orphan. It seems 3 out of the 5 of this turbine (AAER Canada..now defunct) installed in the U.S. has failed the gearbox at around 3 years. Ours is just over that. The warranty was for two years.
SO: AFTER we spend $800K to fix it, the report says.. AND... IF the new gearbox...same model as the last, lasts 10 years, with all routine expences and income considered....the turbine will run a deficit of ($400K) per year. We still owe $2.4M on the current loan.
I used to like this machine. Let the buyer beware. NB
NoBozo is offline
Old 10-21-2012, 06:19 PM   #102
Rusty
IMHO this orphan windmill should be scrapped before Portsmouth, RI goes bankrupt.
Here is the breakdown for the gearbox replacement cost, recurring additional costs (annual), annual revenue estimate, and operating cost:
Rusty is offline
Old 10-21-2012, 06:45 PM   #103
NoBozo
RUSTY: I considered linking to the town website but knowing Don's aversion to OFF Lakes Region stuff I didn't link.
Here's what I posted on our local "Portsmouth Patch". Google "Patch".
"I just read the entire report as well. I Voted against the turbine. When I watched it being built I became a BIG supporter. Looking at the Balance Sheet in this report, one can only conclude THIS turbine is an albatross. This report makes the decision easy. I am really saddened to say this, but I think it's time to take the machinery down and put the remaining tower to some other use.
BTW: Fairhaven, MA just put up Two turbines just like ours this past spring."
NB
NoBozo is offline
Old 10-21-2012, 07:00 PM   #104
Rusty
NoBozo,
I think it's educational for the Lakes Region folks to know what problems other communities are having with windmills.
The more we learn about it, the more it will help us make a decision if a Lakes Region town wants to put up one similar to the RI one.
I hope Don allows you/us to keep the forum up to date with the Portsmouth, RI turbine problem.
Rusty is offline
Old 10-22-2012, 03:05 PM   #105
Default You don't even need RI info
Google prior wind farms project in NH. All are failure and millions of dollars are lost. If I find the feds bankrolled this wind farm and the farm eventually failed, I would make sure there will be no more money pits in our hills.
BroadHopper is offline
Old 10-22-2012, 05:46 PM   #106
Wind is a great idea, solar is a great idea, as are other forms of newer energy. However, they are not perfected and if and until they are, we shouldn't be throwing money at them. With all the things that we can do, it seems we could use these or some other kind of energy. We are so cold in NH, it makes it harder than warmer climates to make alternative energy work.
Now wasn't that a brilliant statement? Nothing nobody doesn't know but just had to vent I guess.
tis is offline
The Following 2 Users Say Thank You to tis For This Useful Post:
NoBozo (10-22-2012), Rusty (10-22-2012)
Old 10-22-2012, 06:50 PM   #107
Rusty
Having worked in the mechanical engineering field most of my life I have a tendency to enjoy reading technical documents like the "Gear Box Failure" of the Portsmouth, RI wind turbine. http://www.portsmouthri.com/document...ne_Gearbox.pdf
I would love to be in Germany when they Perform the forensic teardown of failed gearbox to narrow down root cause of failure.
The only ones that have failed in NH are buried at the foot of Crotched Mountain (and they were a big failure) so I guess no one will be writing anymore reports about them.
The other wind farms in NH haven't been running long enough to have failures (to my knowledge anyway) so we'll just have to wait and see.
Rusty is offline
Old 10-30-2012, 03:03 PM   #108
Default Ride up 93
I took a ride up 93 to see a friend of mine off Tenney Mountain Highway. As soon as I crest wind sock hill past Ashland, I saw the windmills clear as day. WOW! It travels from one hill to the next, to the next! What a way to greet the tourists to the White Mountains!
As I was traveling the Tenney Mountain Highway, it is obvious of the Paul Bunyan size utility poles and wires. I can imagine a semi snapping one of those poles and the thousands of volts traveling through the wet ground. Its like a nightmare!
Old 11-05-2012, 08:04 PM   #109
NoBozo
Probably only Rusty would be interested in this Video of the Portsmouth Town meeting where the consulting engineer presents his case..A replication of the report that Rusty linked to... BUT More detailed... This will be tedious...but informative to those with an engineering background. Be prepared to spend over an hour. NB
PS: I have had the opportunity to read an "unpublished" paper report...WELL beyond the report on the Portsmouth Website that Rusty linked to. I am impressed with the consulting engineer from Seattle.
http://www.theportsmouthrecord.com/T...3.12.Flash.htm
NoBozo is offline
Rusty (11-05-2012)
Old 11-06-2012, 10:05 PM   #110
Rusty
Thanks NoBozo.
Everyone in the video seemed to be very calm considering the severity of the gear box problem/s.
Portsmouth, RI thought they bought a Cadillac and it turned out they got a Zastava Koral.
Rusty is offline
Old 11-07-2012, 01:33 PM   #111
NoBozo
Default Politics Matter
We have had an almost clean sweep of the 7 member town council....from Republican to Democrat. A previous Democrat town council voted to build the turbine. The 2 Democrats that were the minority on yesterdays council now have plenty of like minded company in todays council. They have been steadfast in their desire to repair the turbine for reasons one can only guess.
SO: I predict the turbine will be repaired...No Matter how much it costs every year to run. Dam the (Deficits) .....Full Speed Ahead. YUP
After all, it's GREEN and "the right thing to do". NB
NoBozo is offline
Old 11-08-2012, 04:09 PM   #112
Just noticed about an hour ago, that two of the more prominently placed windmills were turning round & round; they look pretty good too, something about their movement makes them a lot better looking than in a stationary position. Start em up.......that wind is blowing good......let's go make some electro-magnetic energy.......baby!
Two dancing bananas represent two out of the 24-total wind turbines turning, maybe five miles away up top the mountain ridgelines in Groton, as seen while driving down Rt 25-Tenney Mt Hgwy, westbound in Plymouth, while driving to the Wal-mart! One can get a pretty good, up-closer look from the Wal-mart parking lot.
Round and round and round they go; cranking out electro-magnetic energy, paying out $22,000+/year, for each wind turbine, in local property taxes to the Town of Groton www.grotonnh.org, click on GROTON WIND, plus supposedly making a profit too; pretty danged amazing!
http://en.wikipedia.org/wiki/Etymology_of_electricity
Attention: On Monday at 8:40-am, there will be a 20-question, multiple guess quiz on the etymology of electricity.
fatlazyless is offline
Old 11-08-2012, 05:54 PM   #113
Rusty
:b anana::ban ana::banan a:
Round and round and round they go; cranking out electro-magnetic energy, paying out $22,000/year plus in prop taxes to Groton, plus supposedly making a profit too; pretty danged amazing!
The Groton payment in lieu of tax agreement states that once the turbines are licensed and operating, each of the 24 turbines will net the town $22,000 a year. The PILOT base fee also increases annually by 2.5 percent.
$22,000 x 24 = $528,000/yr to the little town of Groton.
Spin Baby Spin!!
Rusty is offline
Old 11-10-2012, 07:33 PM   #114
NoBozo
I am a BIG fan of Vestas..the Biggest wind turbine company in the world: I was snooping around on the internet today and found this:
http://www.bloomberg.com/news/2012-1...-hardship.html NB
NoBozo is offline
Old 11-10-2012, 07:37 PM   #115
NoBozo
OH: BTW: Hey Less..those stinkin bobbin bananas are very distracting....Just Sayin.. NB
WAIT A Freakin Minute: I think Rusty ..embelished on Less's post.....YUP..
NoBozo is offline
Old 11-11-2012, 08:24 AM   #116
Pineedles
Pineedles's Avatar
You can stop any moving avatar by hitting the Esc key.
Pineedles is offline
The Following 2 Users Say Thank You to Pineedles For This Useful Post:
BroadHopper (11-19-2012), NoBozo (11-11-2012)
Old 11-12-2012, 04:13 PM   #117
three dancing bananas represents three wind turbines out of 24-total turning.....looking in the rear-view mirror, driving eastbound on Rt 25- Tenney Mt Hgwy, I could see three wind turbines turning earlier today....this morning! Believe they are located on up high along Fletcher Mountain ridgeline........ayuh........by golly......round & round & round & round they go......making electro-magnetic energy......aka electricity!
http://en.wikipedia.org/wiki/Electricity
"Wind power is of increasing importance in many countries." In the wikipedia article on electricity, "wind power" is a clickable link and there's a photo of a wind farm too.
http://en.wikipedia.org/wiki/Wind_power
Old 11-12-2012, 04:28 PM   #118
RANGER CANOE CO
RANGER CANOE CO's Avatar
Default Groton gets the cash
Plymouth get THE POLES. What a JIP I HATE THEM THINGS. (poles)
rangercanoe.com On Squam lake
RANGER CANOE CO is offline
Old 11-13-2012, 09:54 PM   #119
None of the ten or so wind turbines were turning today, but still a very impressive sight! Now that all the leaves have fallen off their trees, it has dramatically opened up the view from Rt 93, northbound, running the relatively short stretch between Exits 25-north to Exit 26, so now one gets about a 60-second look at the flat ridgeline atop Tenney Mountain while driving north, and the late afternoon sun clearly illuminates that ridgeline. Each one of the 300 (or 400?) foot high, all-white wind turbines has a reflective white surface, and easily catches and reflects the low angle, late afternoon sun; at least it does this time of year, so they really stand out against the blue sky beyond. Sometime soon, like in the next couple-three weeks I suspect, all the 24-turbines will be turning, and it will be some extraordinary sight to clearly and easily see about ten of them while driving north on Rt 93.
Who knows, maybe the state can rename that short stretch of Rt 93, between Exit 25 and Exit 26, to be the "WIND TURBINE MILE" and put up an informative and historic sign?
three dancing bananas represents three out of 24 turbines turning.
Old 12-20-2012, 06:24 AM   #120
Almost all of the 24 white wind turbines were turning with the winds yesterday morning......maybe 16 to 20 could be seen from the Tenney Mtn Hgwy as you get off at Rt 93-Exit 16....and their looks kind of grow on you.......they seem to look
a lot better when turning than when not turning. What the heck.....at least they are doing something and making somebody some money.....and as you probably already know......one cannot eat the view!
Each turbine costs maybe 5-million dollars because supposedly the whole project cost 120-million, and there's 24-wind turbines.
Anyone know how much electricity one turbine makes in a 24-hour day, and how does that translate into how much does Iberdrola get paid by N-Star for directing their wind power juice down to Boston? Unlike a car with a battery, all the power that goes into the grid must get used immediately because the electric grid has no storage reservoir for electric power similar to a car's battery.
Apparently, Groton must have a lot of year-round wind to make this very expensive project doable?
Who knows but as ski areas start to fade away what with the warmer winters, and more wind turbine towers get built, maybe New Hampshire will become known as the "Wind Turbine State." Looking at the ten or so wind turbines that are relatively close up to the Boulder Point-Plymouth medical center that is high up on a hill, it is very easy to see all the old and no longer used ski area trails of the now defunct Tenney Mountain Ski Area, and the neighboring wind mills high up the ridge. So's in this location, the mountain has gone from a ski area to a wind turbine area? Unlike a ski area, a wind farm is a business that runs every day and month of the year......just so long as the wind is moving.
Will refrain from posting all 24-dancing bananas here so just use your imagination! Could be that Iberdrola wanted to get all 24 turning by Christmas as their long term goal?
Old 12-20-2012, 08:25 AM   #121
Pineedles
Pineedles's Avatar
Just a helpful reminder that you can turn off FLL's dancing bananas by pressing the Esc key.
Old 12-20-2012, 10:35 AM   #122
NoBozo
Default Update
It was Six Months this week since our town owned !.5 MW Turbine (Portsmouth, RI.) has turned. Nothng happening to change that as far as I know. NB
PS: I guess we (Taxpayers) are still paying the mortgage though.
NoBozo is offline
Old 12-23-2012, 08:52 AM   #123
About 3-4 miles away, in Campton on Fairgrounds Rd, someone has a huge brown bull and two gurnsey cows that get pastured in a meadow that looks up to the Tenney Mt ridge that is now the new home for all the 24 wind turbines. On a day like today with some big wind blowing, it makes for an interesting picture with all the turbines spinning around big time....they seem to look much better when spinning than when stationary......and it is a bit of a shock to know that about five-million dollars was spent for each individual turbine....and that these will supposedly make a profit? ....the answer to that is blowing in the wind?
And, at least three of the towers are lit up at night with bright red, flashing, triple-light beacons presumably for airplane safety, so's all the homes lining along Lower Beech Hill Rd in Campton that used to have an uncluttered mountain view now get to look at red lights every night........oh well.......tough nuggies and too bad! Maybe it will take five years or so to see how and what these turbine towers and red lights do for the local residential property values. While the local town assessors tend to be a little optimistic with the numbers....the actual selling price is what it is.....as always!
Old 01-11-2013, 02:06 PM   #124
Default Wild Meadows and Spruce Ridge project
The Newfound area is facing the possibility of 90 industrial wind turbines between 400 to 500 feet tall. This number comes from the combined turbines of Groton Wind and the proposed Newfound area Wild Meadows and Groton's Spruce Ridge projects. We're being inundated with wind farms. It starts with an innocent meteorological tower approved by the local town. Once the met tower is in, the wind company can go straight to the SEC for application approval for a project if it is over 30 mw, without any say from the local town in which it will be built. The company and supporters of wind energy claim anyone can file intervener status to object to a project, but the SEC has never turned down a wind turbine project in NH. The SEC is using a ten year old energy policy that was formed by utility companies.
Old 01-15-2013, 01:04 PM   #125
CaptT820
Default Turbines & Northern Pass
Unfortunately the red lights are required by the FAA if a tower of any kind (wind, electric, commercial building, etc.) exceeds 200-ft from ground surface in height.
As for concerns with the Northern Pass project, there is a good chance that a "portion" of it will end up being placed underground. The "portion" is still yet to be determined, but right now it appears that around 40 miles of the project may end up underground. I know that at least 2 miles of it as of right now will definitely be underground. Unfortunately it would be nice to put all the lines underground, but as always it comes back to cost, where it is 1/5th the price in most cases to place the lines above ground surface.
CaptT820 is offline
Old 01-16-2013, 03:50 PM   #126
Default Awesome advice!
This is the best advice I heard in ages
Pineedles (01-21-2013)
Old 01-26-2013, 12:45 PM   #127
Scott's Yott
Birds are over rated anyway...Alls they do is POOP on my car
Scott's Yott is offline
Old 02-02-2013, 09:27 AM   #128
Default Lakes region Planning Commision
Looks like the Wind Farms are getting the local govts attention.
http://laconiadailysun.com/index.php...-lrpcwindfarms
Old 03-03-2013, 12:37 PM   #129
From the Feb 28 Plymouth Record Enterprise, Talk of the Towns column in the Groton section, it says that the Town of Groton is looking for suggestions on what to do with the recent ten thousand dollar payment it received from Iberdrola Wind which was payment for the facility testing period.
"Regarding the two seperate donations to the Town in the amount of $5,000 each from Groton Wind in payment for the facility testing period, the Board is asking for suggestions on what to spend the money on. It has been suggested that electric power be permanently installed in the Ball Park, another suggestion was for a new copier in the Selectmen's Office. Contact the selectmen's office with your thoughts 744-9190."
Jo O'Connor, grotonnews@yahoo.com
Old 04-15-2013, 11:57 AM   #130
NoBozo
Default Update
It will be TEN Months this week since our $3M Town Owned !.5 MW Turbine (Portsmouth, RI.) has turned. Broken $800K gearbox. Nothng happening to change that as far as I know. NB
PS: See post #101 and #102 for background.
NoBozo is offline
Old 04-15-2013, 08:01 PM   #131
Over on Belknap Point Rd, on the Winnipesaukee waterfront in Gilford, not too far up from the NH Marine Patrol Hdqtrs, there's a single family house that besides having a very nice looking tennis court, also has a pretty good sized electric-generating wind turbine atop a tall steel tower near their tennis court. Yesterday on Sunday, while bicycling in that area, I noticed it for the first time and was a little surprised that the local Gilford zoning would allow for such a big wind turbine in a shoreline residential area but then again whatdoIknowaboutit anyway?
Who knows but just maybe that wind turbine can get the electric meter for the house to go backwards or something? Seems like it might just be a great way to turn your windy waterfront location into a mini-Winni windfarm! At the time yesterday afternoon, the wind turbine was spinning & spinning & spinning & spinning & spinning ........ad infinitum! .....it was pretty danged windy yesterday! ....... so it must have been making and selling electricity back into the electric grid to the NH Electric Coop ...... wow......how about that! I think I want one just like that on my little lot so's I can go do the same thing....put those windy kilowatts to work selling electricity for me!
Is one of these not-so-small residential wind turbines that makes your electric meter go backwards an expensive and unattractive looking, money-losing contraption, or is it a money-saving machine whose appearance sort of grows on the owner every time he/she gets the monthly electric bill?
This is probably the answer to my point about a supposed Gilford zoning ordinance that prohibits wind turbines. A quick google search of "New Hampshire RSA wind turbines" found this http://www.nh.gov/oep/resourcelibrary/swes/ which has a link to HB310, a NH law passed in 2008 that says among other things that "collection of renewable energy shall not be unreasonably limited by use of municipal zoning powers or the unreasonable interpretation of such powers except where necessary to protect the public health, safety, and welfare."
Picture hereth yon reader .... a high quality photograph, taken on a bright sunny day, of said not-very-small wind turbine atop a tall steel tower nestled attractively next to yon tennis court on a luxurious Lake Winnipesaukee, Belknap Point, Gilford, waterfront residential lot that includes a very nice, single family, shoreline residence......spin-spin-spin!
It also has a link, Renewable Energy Incentives, for renewable energy incentives that includes property tax exemptions applied to tower and wind turbine from individual towns(?).
Like, money probably makes a huge big difference in how people think about having a wind turbine on their residential property; receiving electricity credit off your monthly electric bill by causing your electric meter to run backwards, being property tax exempt from local property tax, and getting federal tax credits as well are among the items to consider when thinking about installing a personal wind turbine tower on your property.
Is a residential wind turbine something you might consider, and is it a winner or a loser type of an item?
http://energy.gov/energysaver/articles/small-wind
Last edited by fatlazyless; 05-15-2013 at 06:33 PM. Reason: ..... HB-310, 2008: Small Wind Energy Systems
Old 07-05-2013, 06:50 PM   #132
NoBozo
The Democrat Town Council (Back Then) Voted to build a !.5 MegaWatt Town Owned wind turbine. SO the town built it. ($3M) The Republicans won the Next town council election. During the Republican tenure..the turbine Broke and because of this...The Republicans last November were replaced by Democrats... (Go Figure).
The wind turbine has been Dormant for Over a year now and the Democrat Town Council seems to be IMPOTENT. They don't know nothin about no stinkin turbine. You can't make this stuff up. NB
EDIT: You probably have to back up a few posts to Get It.
NoBozo is offline
Old 07-06-2013, 10:14 AM   #133
Default Newfound lake Watch
I heard thru the internet, that someone is going around damaging, defacing signs set up by the opposition to wind mills. Someone took a number of these signs and clogged up the storm drain in front of a number of the local police stations. That's a pretty bold move!
Old 07-06-2013, 06:49 PM   #134
NoBozo
Default Just A Recount Of The Events.
I'm not sure what BH was inferring ..about people against windmills. I Voted against the windmill in the beginning. Being a fiscal conservative I didn't think borowing $3M during a recession was justified.
The town voted to Build It anyway. Once the turbine started going up I started to Like It. i became a supporter as long as it RAN and produced power. Then it broke. And then the guy from Seattle came out and looked at it. He prounounced it a "Dead Horse"..every which way you massaged the numbers...... It was a "Dead Horse".
So the Dead Turbine sits there in plain view of every tourist that comes over the bridge to the island from the North and those that exit the island heading north.
OH WAIT: There is a NEW (TOLL) bridge that tourists will have to cross to get to our little island of Aquidneck from the north..which you will have to use to get to NEWPORT. Our economy IS Tourism..just like the Lakes. The OLD bridge was free since it was built in 1956.
Don't have a RI EZPass...?? No problem. It will cost out of staters $10 round trip. NO toll collecters. A Scanner above the road will record your licence plate and send you a bill if you don't have the "Correct" transponder. Welcome to Our State. NB
PS: Rhode Island has been Democrat for the past 70 years. (95%)
NoBozo is offline
Old 07-07-2013, 08:40 PM   #135
Default Keep this in mind,
according to wind turbine association AEE. Spanish manufacturers are rapidly laying off workers. Investors in wind turbines no longer look attractive. The heart of the problem are the subsidies needed to cover the gap between the cost of producing electricity and the price charged to consumers. The German wind program is imploding, Germany is now facing up to the hard realities of maintenance costs, and backup power. As stated in the Heartland Institute science director Jay Lehr's June 17 Wall Street Journal commentary predicting wind developers lack of funds for the dismantling of their turbines will lead to a scene from a scifi movie with the earth covered with rusting hulks all over the land scape.
Old 07-10-2013, 05:51 PM   #136
songkrai
Spin Baby Spin!!
The bottom line is.
Move to Groton. Where property taxes are real cheap.
songkrai is offline
Old 01-28-2016, 07:44 PM   #137
NoBozo
I haven't posted in some time. I thought this might interest some of you who are interested in Wind Turbines. The Portsmouth, RI.. 1.5 MW wind turbine Owned by the town has been inactive for going on 4 years due to a failed gearbox. This turbine was the first such installation .. in RI and much celebrated.
Today, (1/28/16) the turbine came "down to the ground". It will be replaced by a NEW 1.5 MW "Direct Drive" turbine in the next few days. Direct Drive means NO GEARBOX. NB
http://www.providencejournal.com/art...NEWS/311059970
EDIT: Here are some pictures of our Late turbine.
http://www.eastbayri.com/news/govern...g-down-photos/
NoBozo is offline
Old 01-28-2016, 08:10 PM   #138
wifi
wifi's Avatar
When it "worked", did it generate any revenue ? Any guarantee the new company will last long enough for support? Is this just another liberal, global warming faux pas to save face ?
wifi is offline
Old 01-29-2016, 06:51 PM   #139
NoBozo
There was a book written by Jack London in the very early 20th Century called "The Cruise Of the Snark". Most of his books were novels. The Snark was a real life description of his quest to have a Yacht built to his specifications.
When things didn't go as he would have liked..(he was being scammed by the builders)..He and his wife would say....Just think of that "Beautiful Bow".
When my wife and I would drive by the Portsmouth Wind Turbine...WE would say....."Look at that wonderful Wind Turbine". NB
EDIT; According to the article in a previous post, the turbine made $340,000 over the three years it ran. The problem was...IT DIED before it could pay off it's bills.
NoBozo is offline
Old 02-01-2016, 06:45 PM   #140
NoBozo
Default Update
The OLD Wind Turbine has been totally removed. The skyline is EMPTY as you drive on to the island. OMG. The BIG Crane was removed this morning. Seven years ago this crane cost $10K/day plus $10k Setup fee. It is a BIG Crane.
NOW: The NEW word is the NEW turbine will NOT be installed...until maybe in June.
My thoughts as an engineer, Maybe the NEW Turbine needs a NEW Foundation...That take's time.....The "Story" changes .............AS Required (Sarc) NB
NoBozo is offline
Old 02-12-2016, 07:24 PM   #141
Cobalt 25
Thanks for the updates, NoBozo.
wifi, a quote from you, "Is this just another liberal, global warming faux pas to save face ?"
It would appear you do not believe in the concept of global warming, in spite of the findings of over 97% of the world's climate scientists. Fine, nothing that I could possibly say could convince you otherwise.
But for the rest of the folks interested in learning more about wind generators, I hoping my personal experience with them will be of value.
I recently moved from our home which was situated maybe a quarter mile from the largest array of wind generators in MA. Our home was one of the closest to these structures.
Noise- maybe 5% of the time I was out of doors (which was a lot, we heated with wood and I harvested the fuel from our property plus I love being outside) I could hear a soft whooshing noise. I could never hear it from inside the house, even in the summer with the windows open.
Effects on property values- I sold our house myself and in interviewing maybe 50 parties all together I did not hear ONE person bring up the wind generators in a negative manner. Several had positive responses, most never even mentioned them.
Percentage of time on line- of the 19 structures, 10 were highly visible to me. I observed that those 10 generators usually had all 10 working at once, occasionally one would be down.
Economics- a solid business model is to sell your product to the highest bidder, regardless of location. The towns of Florida and Monroe derive property tax income from this project, for a total of $257,000 per annum. They can provide power for 10,000 homes. I do not know the profit margin of the company, but I hope they are doing well.
I believe we need to explore all possibilities when it comes to trying to minimize the very real impact of global warming. Wind power for electrical use is really in it's infancy. The Model T didn't have GPS, and wind generators will get better if we support their development in spite of early complications.
Here is a website with more info: https://en.wikipedia.org/wiki/Hoosac_Wind_Power_Project
I hope this adds to the discussion...
Peter
Cobalt 25 is offline
Old 02-25-2016, 06:49 PM   #142
NoBozo
Default Update
The Portsmouth Wind Turbine site: They are digging a big hole on the site. It seems they are going to plant a new foundation for the new turbine. I monitor the site with binoculars.....I can't get inside the fence without getting arrested... and probably beaten. NB
NoBozo is offline
Old 06-12-2016, 06:08 PM   #143
NoBozo
Default Activity on Site
As of yesterday things are getting moving. There are now three BIG "Tubes" lying horizontal in the high school parking lot that will comprise the tower.
A BIG crane is also on site but has not yet been erected. This kind of crane arrives on site with multiple flat bed trucks in attendance and needs to be assembled on site...booms, outriggers, EDIT (19 flatbed trucks) (6-15-16 )etc..
Other big turbine component parts are further up the hill....maybe a turbine hub..and other stuff. No turbine blades yet.
This turbine will be Direct Drive..No gear box. This type of turbine is generally taller and the fan disc is greater in diameter, EDIT: I was Wrong: compared to a Step UP geared turbine of the same output. (1.5 MW) These blades are 114' in length..compared to the old geared turbine with 123' blades. NB
NoBozo is offline
Old 06-15-2016, 06:41 PM   #144
NoBozo
Default Update
The weather has been fantastic. These guys are not standing still. (Bay Crane Inc) As of this afternoon (Wednesday, 15th..@1545) All three "tubes" are erected and the nacelle is on top. These guys work from dawn to dusk...didn't see anyone even stopping for lunch. Nacelle is 250 feet above ground. The old turbine was 212 feet above ground. NB
Note: The blades are not only on site..as of 1530, they were moving them up to the dirt lot where the tower is.
NoBozo is offline
Old 06-16-2016, 02:07 PM   #145
NoBozo
Default All Done
Noon Thursday everything was done. The crane is being disassembled by a small crew. The only thing left is to throw the big switch connected to the Grid.
The new turbine is now privately owned, leasing the land it sits on from the town. The turbine owners will charge the Town 15.5 cents per KWh for the power it makes for the next 25 years. The rest of us pay 10 cents. NB
NoBozo is offline
Old 08-06-2016, 06:50 PM   #146
NoBozo
The NEW Portsmouth, RI (now privately owned) wind turbine started running on Tuesday. This direct drive turbine is supposed to be 1.5 MW. The fan disc is distinctly smaller than the original 1.5 MW geared turbine. I'm thinking this new turbine may be "Downrated" ...maybe to 1.0 MW. Let the SCAM continue
The best part...every minute the turbine runs...The town will pay 15.5 cents/Kw for the power......going into the Grid...weather the town needs the power or not. Local rates are about 10 cents/Kw. NB
NoBozo is offline
Old 08-06-2016, 07:07 PM   #147
NoBozo
SHORTLY: Rhode Island will have the Block Island offshore wind farm up and running. This fall. FIVE 6.0 MW turbines on pedestals in the sea. 30 MW total. That's BIG. I can't be sure..I think the electric rate will be 23 cents/Kw..or something. It's just hard to comprehend how this is happening. NB
NoBozo is offline
This page was generated in 0.61192 seconds
