#1 | |
I had a 25' Cobalt and now have a 28' Formula Bow rider with twin 260 hp's which I would have no problem spending the dough on for a performance prop. The Four Winns bow rider is a $4500 starter boat for my 2 older sons (20 and 22) and I think will be a perfect boat for them if I can get this porpoising sorted out. I would love to go with a stainless 4 blade but I'd be afraid after a day with their friends out on the Winni, the prop might come back as a 3 blade if you know what I mean. (I remember when I was learning to drive a boat). I'm definitely looking forward to trying the 14.5x21. If I recall that's exactly what I had on one of my first boats which was a 21' Sea ray br with a 4.3. Bottom line is I'm thrilled that the Sea Doo's are gone and the kids have a safe boat to use instead. Thanks again for all the valuable info and we'll see you on the water. |
dipassan -
Based on your earlier decription of where you'll be out "Test Driving" is it a fair conclusion to presume that you might be in at WAM ? If so, I would certainly think John would let you demo/test various pitch props
#3 | |
Thanks again |
I would think a 15 x 17 would let the engine rev a bit too fast at WOT and would also have a negative affect on the top speed. Kind of like having 4:11s in the rear end of a car.
We have a 19' Horizon with a Stringray Hydrofoil Stabilizer and it makes a big difference on triming the boat. |
I am familiar with 4Winns as I had a classic Liberator for my first performance boat. I experince 'chine walking' at speed. I usually trim the drive down, as I increase speed, I will trim up until the boat starts to porpoise and trim down. I used the trim.
The factory prop should be your starting point. If you experience 'blow outs' during tubing or hard turnings, going down a pitch helps but you will find switching to a 4 blade will be even better! Some props like the Mercury Lazer creates bow lift, some props like the Mirage is good for heavier boats. Please look at the Mercruiser prop selection guide and you will see what each brand of props do to handling. I know you have an OMC, but I am just giving you an idea what changing props can do to a boat. Winnisquam Marine gives excellent advise for your boat and I would take their word for it. Please give them a call, you won't be disappointed. Have a wonderful summer with your purchase. See you on the lake!
I have a 1992 FourWinns Horizon 190, OMC 5.0. Everything (but a $1200 gearset) is 100% stock. I have been running a 3 blade 14.5 x 19 since, well, since 1992. Most recent prop is a "Michigan", I think from Overtons. Never had a problem. I top out right at about 50 +/- based on water, fuel level, etc. Sounds like you just have the wrong prop on there.
#7 | |
I have installed a 14.5x19 but haven't had a chance to try it out yet. I'm confident that will solve the problem. Thanks
#8 | |
"better to have a short life that is full of what you like doing, then a long life spent in a miserable way.." ![]() |
#9 | |
Ps. The tabs have a piston that extends the tab down until water pressure builds to compress the piston and push the tab up. |
#10 | |
My son took the Power Squadron safety class last fall and received his certificate. Saturday was the first day that my old boat left the beach without an adult on it! He is a good boater so I only worry a little less ![]() |
#11 | |
I absoutely love the Formula 280 Bow Rider. It does so many things so well. Carries lots of people (yacht certification, so from what I've read there's no limit to # of passengers) I've had 18 people on it with plenty of room and cruising at 30mph. With the twin engines it maneuvers unbelievable (which I'm still getting used to), and gets on plane effortlessly even with a full load. It's very heavy so it rides like a dream, it never "slams", is incredibly quiet, almost no engine noise, great floor plan, ton's of storage and a very high quality overall feel to it. I appreciate it more every time I take it out. I had a 25' Cobalt BR before that which I loved also but needed more passenger space. I would highly recommend a formula 260, 280 or 310 bow rider to anyone. The 310 was the largest bow rider made until this year when Formula revealed a new 35' CBR crossover bow rider. Pretty cool. It just keeps getting better!!!! Have a great summer and we'll see ya on the Lake!!
