Old 04-17-2012, 03:24 PM   #1
AB_Monterey
AB_Monterey's Avatar
Default How do you get 80 ft of mast under a 65 ft bridge?
http://www.wimp.com/mastbridge/
BEAUTIFUL boat.
The Following 3 Users Say Thank You to AB_Monterey For This Useful Post:
bclaker (04-18-2012), Electric man (04-17-2012), Lakegeezer (04-17-2012)
Old 04-17-2012, 05:02 PM   #2
Thats unbelievable and very creative.Wow!
Old 04-17-2012, 06:24 PM   #3
NoBozo
This is how you do it. The BAGS have water in them. Once you go under the bridges..you dump the water and the boat goes upright again. BRILLIANT. NB
Old 04-17-2012, 08:26 PM   #4
Winnipesaukee Divers
Winnipesaukee Divers's Avatar
Where is the 65' bridge on Winnipesaukee? How does this apply to the lake?
Winnipesaukee Divers is offline   Reply With Quote
Old 04-18-2012, 08:42 AM   #5
Pretty cool.......might work on some of our bridges.
Old 04-18-2012, 08:58 AM   #6
lawn psycho
Nice! That's one of the times you don't get a do over if your geometry is off
Old 04-18-2012, 09:32 AM   #7
camp guy
camp guy's Avatar
Default 80 ft mast under a 65 ft bridge...
Seeing is believing (I guess), but let's remember that bridge clearances are given at high water, and mast lengths are measured end to end. This having been said, the mast sets into the boat maybe about 6 ft below the deck (leaving 74 feet over the deck, and, if the boat passed under the 65 ft bridge at low tide (say, maybe 5 ft tide), then the clearance would be 70 ft, so the boat and mast would have to make it under with 74 ft over the water. Still, a very clever bit of boatmanship.
Maybe some of the math whizzes can calculate the angle of healing necessarty to clear the bridge.
Old 04-18-2012, 10:06 AM   #8
brk-lnt
brk-lnt's Avatar
Assuming the bridge clearance really is 65ft, and the mast is 80ft end to end, with the base being roughly at water level (since it goes through the top of the boat and down into the hull) you'd need a list angle approximately 35.7 degrees.
[insert witty phrase here]
Old 04-18-2012, 11:24 AM   #9
pm203
Who would have figured.
pm203 is offline   Reply With Quote
Old 04-18-2012, 12:48 PM   #10
Grant
Grant's Avatar
Troublemaker.
Old 04-18-2012, 01:35 PM   #11
AB_Monterey
http://www.youtube.com/watch?v=C6cxNR9ML8k
The Following 2 Users Say Thank You to AB_Monterey For This Useful Post:
BroadHopper (04-18-2012), NoBozo (04-18-2012)
Old 04-18-2012, 05:06 PM   #12
no-engine
There are other threads and posts that really don't fully apply to lake. !!!
The other side of coin is: been in that situation during a transit of Inland Waterway. Quite interesting!
Does not matter if boat designer measures mast end to end, as long as proper calculations are made at water level, and I've seen on many specs for a mast height above water!
no-engine is offline   Reply With Quote
Old 04-18-2012, 06:57 PM   #13
RailroadJoe
What is the clearance for the Rt 3 bridge at the Weirs? Can a sailboat get through there with no trouble?
RailroadJoe is offline   Reply With Quote
Old 04-18-2012, 07:12 PM   #14
NoBozo
An obscure note on the Bizer chart says the clearence is 21 feet. NB
Old 04-18-2012, 07:21 PM   #15
NoBozo
Default Just From My Own Experience
Those skippers that "Do The Waterway" with sailboats know Exactly how high their masts are from the Waterline. The key is waterline to top of mast.....including masthead instruments.. (Wind speed and relative wind direction... radio antenas...etc) NB
Old 04-18-2012, 08:57 PM   #16
no-engine
For sure, as I was crew, we knew well that measurement!
I think I had read somewhere of clearance 20-25'. Thanks
Some sailboats have an easy method to hinge the mast at deck fitting, in order to get under obstructions.
Old 04-21-2012, 03:27 PM   #17
I can't imagine that suspending that much weight off the mast is a terribly good idea. Imagine that boat hitting a good sized wake while in a balancing like that?
Old 04-21-2012, 08:14 PM   #18
NoBozo
Not a problem at all. Sailboats sail day after day..week after week ....At Sea.."heeled"... (NOT Keeled) over like that under the Press of SAIL. The masts are "Stayed"..held up by their shrouds ..steel cables designed to spread the load on the mast.
Fore and aft "pitching" of the boat in seas, (waves) combined with lateral heeling under wind load from the sails is much more stressful to the MAST than going under a bridge with ballast bags over the side.
BTW: Looking at the waterway charts there are various bridges and obstacles that skippers will become aware of. Bigger boats usually "Go Outside" for sections of the waterway that have ...ISSUES. The other ISSUE for bigger boats in the waterway is "Draft" of the boat. The waterway is not all that deep in places...deeper draft...another reason to "Go Outside".
It all depends on how fast you need to get there..(Fla). OUTSIDE is the fastest way...for those inclined.....and experienced with offshore... NB
no-engine (04-21-2012)
Old 04-24-2012, 02:46 PM   #19
AB_Monterey
Default Fun day at the boat launch
Rather than start a new topic.
Adventures at the launch....
Sometimes, bad ideas are contagious.
http://www.bitoffun.com/video_vault/boat-launch-fun.htm
The Following User Says Thank You to AB_Monterey For This Useful Post:
Lakegeezer (04-25-2012)
Old 04-25-2012, 12:46 PM   #20
Steveo
Too funny!!!
Old 04-25-2012, 06:37 PM   #21
AB_Monterey
I kept saying, "No, they're not..." and they just kept on coming.
Old 04-26-2012, 07:36 AM   #22
Default Wait there's another way...
A few years back, I was at the Selectmen's meeting in Wolfeboro. I was there on WCYC business, but they were discussing the upcoming Smith River bridge renovations. Someone poised the question about raising the bridge to make better use of Back Bay. After a brief discussion one of the Selectmen said, "We don't need to raise the bridge, we'll just dig the channel deeper". To which the state engineer responded, "Why didn't we think of that..." and the audience clapped with approval of such a simple solution to the problem.
I rolled my eyes back in my head and thought "if this is what I have to work with... I might as well go home now.
Old 04-26-2012, 08:36 AM   #23
Pineedles
Pineedles's Avatar
That is too funny!
Old 04-26-2012, 08:46 AM   #24
RailroadJoe
Sure, the deeper the channel the bigger the submarine.
Old 05-05-2012, 12:27 PM   #25
no-engine
Seriously? State engineer's answer joking or truly serious?
I know we all have minimal confidence in many State Officials.
Old 05-05-2012, 02:42 PM   #26
RailroadJoe
Who is the smartest? The state engineer or the audience for clapping with approval.
Old 05-05-2012, 03:18 PM   #27
no-engine
Well, the answer should be neither. All should leave.
If one has traveled to FL, we observe bridges over canals; the approach roads are built up and then down, just to allow clearance for certain boats.
The roads are often only a little above the water level. Forget the rise an fall of tides!
How about Tappan Zee Bridge over Hudson River, or Annapolis Bay Bridge, which rises to allow ocean going vessels under and then returns to ground level.
There's a few covered bridges here in NH which are designed with approaches and bridge higher then surrounding lands.
This page was generated in 0.16212 seconds
