I've mailed out almost 100 MM decals to date. We have MM Enthusiasts in the following states, MA,RI,CT,NH,VT,NY,CO,TN,FL,MD,CA,NJ one decal headed to France. I'd like to hear from someone in Canada and Mexico to display the MM decal.
The Mini Mount covering structure construction is proceeding well. As of 11:00 AM it is looking good.
The Following User Says Thank You to BkrEtc For This Useful Post: | ||
eillac@dow (12-01-2011) |
With some wonderfull help, the Little Mini Mount is in her nest ! Hard work done by Dave's Boat and Watermark and Matt-thank you all so very much-the shelter should prevent further damage. THANK YOU ALL for your help and support.
The Following User Says Thank You to posas For This Useful Post: | ||
riverat (12-01-2011) |
I also would like to thank all those that did the manual labor to erect the new home. I know it isn't the easiest thing to do as I did one, but a lot smaller before I lost my leg. I sure would have loved to have been able to help, but age and handicap would not allow me to be there and if I was, all I would have done would have been in the way.
![]() Again thanks to all and ![]()
That was a project! I'll try posting a few photos of the process if I can figure out how to do it.
Here's Dave from Dave's Motorboat Shoppe, Matt form Supreme Marine on the ladder and Josh, Dave and Matt from Watermark in the background.
Terrific! This is the finished product, on time and on budget.
The Following 13 Users Say Thank You to Fargo For This Useful Post: | ||
billy (12-02-2011), DRH (12-02-2011), eillac@dow (12-01-2011), Just Sold (12-01-2011), NoBozo (12-02-2011), RailroadJoe (12-01-2011), Redwing (12-02-2011), riverat (12-01-2011), Senter Cove Guy (12-01-2011), SteveA (12-09-2011), Sue Doe-Nym (12-03-2011), trfour (12-02-2011), webmaster (12-02-2011) |
There's Katie from Dave's MB Shoppe too!
MarieM |
Everyone that helped construct the new home for the "Mini Mount" should be very very proud!
The Following User Says Thank You to Greene's Basin Girl For This Useful Post: | ||
BkrEtc (12-01-2011) |
![]() Putting the Mini Mount to Bed for the Winter December 1, 2011 Last edited by bclaker; 12-02-2011 at 04:17 PM. |
The Following 11 Users Say Thank You to bclaker For This Useful Post: | ||
billy (12-02-2011), BkrEtc (12-03-2011), DRH (12-02-2011), Just Sold (12-02-2011), Lakepilot (12-02-2011), Laurie1999 (06-24-2012), Pineedles (12-02-2011), RailroadJoe (12-02-2011), Rattlesnake Gal (12-02-2011), riverat (12-02-2011), Senter Cove Guy (12-02-2011) |
Location: New Haven, Connecticut and summer resident of Moultonborough, NH since 1952
...as we were all able to view "history in the making" of the Mini Mount. Congratulations and kudos to all!
pretty cool
Capt. of the "No Worries" |
Bclaker, thanks so much for braving the cold to record the day!
#17 |
Its good to see she is in a protective enclosure..... Now the question becomes, what is on the list of items to be done come spring to start getting back in Shape.
I don't ask because I am noisy... but because if there is something I can help with I am more the willing to volunteer a bit of time.
The crew of the Mini Mount will be on leave for the winter-come spring and warmer days we will hopefully come up with a plan for the restoration and advise at that time of plans. MM will need some trim work replaced, scraping-sanding, painting etc. I'm sure we will repost the plan, thank you !
#19 |
#20 |
Here's a riddle. How do you get 1000 gallons of water out of the Mini Mount? One cup at a time! Had to use the old fashion way today to bail the old girl out. Used the clorox bottle scoup method. Just no easy access around the frame members. Thatsalottascoups!
#21 |
Time to make a modification to the frames. It's called "Limber Holes". These holes would be located on either side of the keel in each frame. It allows water to flow (Fore or aft) to a low point in the hull so that the water can be pumped out from a central location.
![]() PS: It's not unreasonable to Drill a HOLE in the bottom of the boat to let it drain out to the ground. Put a threaded plug in the hole in the spring. Still need "Limber Holes" though. |
