Old 08-04-2011, 07:59 PM   #1
soxfan
Default engine tbl
I have a 2003 four winns 270 hp volvo that will not start after a couple of hrs use unless i wait 10 mins. it will not crank. marina cant find problem any suggestions would be appreciated.. thanks
soxfan is offline   Reply With Quote
Old 08-04-2011, 09:05 PM   #2
bkgoodman
When you say "it won't crank" - what do you mean?
When you turn the key, nothing happens? Any noise at all? Even any clicking or anything from the starter?
bkgoodman is offline   Reply With Quote
Old 08-04-2011, 09:17 PM   #3
Woodsy
I would look at the starter solenoid.... common chevy problem is heat soak. The ten minute time seems about right for the starter to cool down
Woodsy
The Following 2 Users Say Thank You to Woodsy For This Useful Post:
soxfan (08-05-2011), VitaBene (08-04-2011)
Old 08-05-2011, 06:49 AM   #4
Woodsy
Also the slave solenoid, if it has one. It'll be the device between the battery+ terminal and the low current+ lead on the starter solenoid. Not sure if VP uses them or not, I know Mercruiser does and that they fail.
Old 08-05-2011, 09:31 AM   #5
soxfan
no cranking... no clicking.. nothing at all
Old 08-05-2011, 11:55 AM   #6
robmac
robmac's Avatar
You'll need to start with a meter,check the main feed ( as Dave R suggested )and check when key is in the start position. Sounds from what I've read like a heat soak issue because after cooling for a short period she cranks again.
The Following User Says Thank You to robmac For This Useful Post:
soxfan (08-05-2011)
Old 08-05-2011, 05:02 PM   #7
NoBozo
Let's look at the battery connections first..ON the Battery. Remove the cable lugs, clean the terminal posts on the battery and connector lugs. Re-connect and try again. Simple is as simple does. AND... it's totally cheap and doesn't require someone who is mechanically inclined.. NB
PS: You can clean the terminal posts and connector lugs with a pocket knife...just scrape the contact areas clean.
soxfan (08-05-2011)
Old 08-06-2011, 12:38 PM   #8
Cal
Cal's Avatar
Make sure you are getting 12 volts out of the "start" lug of the ignition switch when in the start position. I've heard of this problem a few times recently and it seemed to be heat related also. You can used a meter or just a test light.
The Following User Says Thank You to Cal For This Useful Post:
soxfan (08-06-2011)
Old 08-10-2011, 01:48 PM   #9
soxfan
Thanks for the input turned out to be starter solenoid
This page was generated in 0.15683 seconds
