Old 08-01-2010, 10:19 PM   #1
Default Fiberglass Repair Shops?
Can folks recommend a repair shop which does 'fiberglass' repairs.
Have a small job, to fix. Only about 2"x4" to repair.
Don't want to DIY, but leave to a professional with the right tools and materials. Have searched the Forum for 'Fiberglass Repair' category,
but only came up with one hit 'Unique Boat Restoration in Moultonborough'.
Can folks suggest other shops in the Gilford, Laconia, Alton, Meredith area.
Thanks,
BD
Old 08-02-2010, 08:58 PM   #2
Default Fiberglass Repair - Need Referral
Reposting.....
Thanks,
BD
Old 08-05-2010, 07:46 AM   #3
MarkinNH
Originally Posted by bigdog View Post
Reposting.....
Thanks,
BD
I have no suggestions for places to check other then call a few auto body shops and explain your situation. They may well be able to steer you in the right direction.
However, my personal experience with the above business was terrible at best. He looked at the job, started the job, promised to finish the job several times after Many phone calls to him and a few scheduled appointments that he never showed up for. One time he even got nasty on the phone. He then eventually told the owner that he had no intentions of finishing the job. In fairness, he never did charge for an of the initial work he started. But this is not a professional manor in which to do business and therefore this is not a man or a business that I could Ever recommend to anybody.
Be Cautious !!
MarkinNH is offline   Reply With Quote
Old 08-05-2010, 08:57 AM   #4
Irrigation Guy
Try John at Diamiond Shine in Gilford. He has many satisfied customers.
Diamond Shine
34 Meadowbrook Lane
Gilford, NH 03249
(603) 293-0378
Old 08-05-2010, 11:12 AM   #5
pats fan
Default Perfect glass work!
Try Miles Marine on Lily Pond Rd in Laconia. They did some work for us last fall and did a gret job. 603-527-1887.
pats fan is offline   Reply With Quote
Old 08-05-2010, 11:57 AM   #6
Seeker
Seeker's Avatar
I think you should repost this under boat repairs and maintenance. Might get better answers.
Old 08-06-2010, 06:47 AM   #7
Guiness
Default Whitemountion Fiberglass
I used Whitemountain Fiberglass in Rumney. Easy to work with and great work.
Your project sounds small and can likely be handled by most marinas.
Guiness is offline   Reply With Quote
Old 08-07-2010, 08:21 AM   #8
Ron's Fiberglassing USA
Default Repair Shop
Give Ron's Fiberglassing USA a Call 603-528-3217
His been repairing boats since 1985 and only 55.00 per hr
Ron's Fiberglassing USA is offline   Reply With Quote
Old 08-09-2010, 04:46 AM   #9
Wink Go Sailing NOW...
If this repair is to your "new" Sunfish, is it damage that will require cutting out the damaged section?
For a proper repair, any perforation of the hull or cracks leading away from the immediate area would require cutting out the affected hull section—however small. This could actually be to some advantage, if the Sunfish needs the typical "drying-out".
(Usually done on hulls weighing over 134 pounds, and best accomplished during the long months of Winter).
But the next five weeks will be the best weeks for Winnipesaukee sailing! (Especially for learning to sail).
With only a few weeks left to summer—and the arrival of prolonged days of high winds and cooler waters—a duct-taped repair should get you through to October.
(Even taped below the waterline—I'm serious!)
Old 08-09-2010, 05:41 PM   #10
MRAB2
Default Fiberglass and Gelcoat repair
Complete Marine Care does Gelcoat repair and is very reasonable with thier prices - might be worth giving a call 651-9727
MRAB2 is offline   Reply With Quote
This page was generated in 0.39507 seconds
