Old 05-25-2010, 03:42 PM   #1
XCR-700
XCR-700's Avatar
Default Marine GSP
Looking for feedback on Garmin Marine GPS models.
I dont need any fishfinder functions, just looking for a quality GPS to use on Winnipesaukee.
I was planning to use the Bizer data as I like their charts, unless others can recommend better.
Thanks for you advice in advance!
Old 05-25-2010, 03:47 PM   #2
hancoveguy
hancoveguy's Avatar
Default Standard Horizon Cp180I
I just bought my second Cp180I with a Bizer Winni C-Max chip. I love it. I don't use alot of the features but now that I have used it I am not sure I would be on the lake w/out it.
Retails for $500 GPS and $175 Chip at a Marina. If you call Jeppeson Marine in Mashpee Mass (# is on Bizers website) you can get both shipped for $550 ish.
Good luck, I am sure there will be many more ideas posted here soon and they are all good.
Old 05-25-2010, 04:59 PM   #3
OCDACTIVE
OCDACTIVE's Avatar
I just installed the Garmin 4208
It has every function you want. Full network ready.
I will be out and about this weekend. Let me know if you want to hook up to check it out. I only am using it currently as a GPS and speedo. Plan on hooking up the dash speedo and a depth finder to it. It can do full network, sonar, fish finder, photos of bays, blue chip hook up, everything.. Amazing..
Old 05-26-2010, 09:10 AM   #4
Woodsy
My vote is for the Garmin Nuvi 500! $299 and for $10 bucks you get the Winni map! Waterproof and portable!
I love it!
Woodsy
PS: I also have a older Standard Horizon CP160 that works just fine with the C-Map chip of Winni.
Old 05-26-2010, 10:18 AM   #5
NoBozo
Mine also monitors and controls the temperature in my refrigerated cup holders. NB
Old 05-26-2010, 10:38 AM   #6
OCDACTIVE
OCDACTIVE's Avatar
I will look into that this weekend to install that option.
Old 05-26-2010, 03:30 PM   #7
townsde
townsde's Avatar
Default Nuvi 550
I use the Garmin Nuvi 550 with the Garmin Winni map. It works well and does not cost a lot of $$$.
The only issue I have with it is that it does show tracks on the screen but these can not be saved to your home computer and then reloaded at a later date.
Once the memory fills up it deletes the oldest track.
townsde is offline   Reply With Quote
Old 05-26-2010, 05:23 PM   #8
Gatto Nero
Gatto Nero's Avatar
I use the Nuvi 500, which is essentially the same unit as the 550 with the exception on some of the maps included, I think. It by no means would have the same functionality as a marine unit but it works fine for my purposes. I do know you can save a route on the unit and call it up at anytime. I don't know of any reason why you couldn't then upload that to your PC using MapSource, but I've never tried it so couldn't say for sure. For that matter I can't say I can think of a reason why I would.
Old 05-27-2010, 01:34 PM   #9
Grady223
Grady223's Avatar
Anyone using the Standard Horizon CP300 or CP500? I am considering one of them for my boat. Also, any experience with internal antenna vs external? Is there a noticeable difference between the two?
Old 05-27-2010, 02:30 PM   #10
XCR-700
XCR-700's Avatar
Many Thanks for the feedback and the very generous offer, I only wish I was going to be up there this weekend.
Have a spectacular time this weekend and I will check in with you when I’m ready to splash the little Carlson (next couple of weeks)
GH
Old 07-13-2010, 07:23 AM   #11
townsde
townsde's Avatar
I just installed the Garmin 536 with the Bizer Chart software this past weekend and I love it. This unit also has network capability but I too am just using the GPS portion of it now.
Prior to this I had been using a Garmin Nuvi with the Garmin software chart of the Lake. I find the Bizer software to be much better.
OCDACTIVE: have you added any of the network capabilities yet and if so what components did you use?
Old 07-13-2010, 07:28 AM   #12
Default SD card ?
Can you save the track(s) to an SD card in the unit?
Old 07-13-2010, 10:43 AM   #13
townsde
townsde's Avatar
With the Garmin 536 you can save tracks and waypoints to the SD card then transfer them to your computer via Mapsource. I have also been successful in uploading previous tracks captured with a different GPS onto the SD card then onto the Garmin 536
This is not possible with the NUVI 500
Old 07-14-2010, 12:01 PM   #14
VtSteve
One of my best investments has been a $10 Navionics app for the iPhone. It should be available for others as well. I see it is available for iPad and Andriod as well.
http://www.navionics.com/NavionicsMobile.asp
I have a Garmin 440S with the 3D chip, but the screen and view of the Navionics app is so much better, I find myself using it more and more. Much better visual than the Garmin, more like seeing your boat on a paper chart.
This page was generated in 0.09189 seconds
