Old 10-28-2009, 09:34 AM   #1
Grady223
Grady223's Avatar
Default Floor Insulation
Our island home is built on piers and the underside of the 1st floor is exposed. The floor was originally insulated with fiberglass insulation. We eventually tore it down as the critters were living in it and taking chunks away for their nests - a real mess.
Question for you all is - how do you recommend I replace it? Some suggestions I've gotten are fiberglass and plywood over it to protect it from the critters and cut and insert foam board insulation then insert it between the joists. Since it is an island home and only used May thru October - deep cold temperatures of Jan, Feb, etc. do not have to be considered.
Old 10-28-2009, 10:16 AM   #2
TomC
TomC's Avatar
Default Close in the bottom?
I closed in the bottom of my cabin with PT plywood on studwalls and insuated that. Whether you can do this easily/inexpensively or not depends on the grade and how high up on piers the house is built.A side benefit is that any pipes in this space are also kept warmer. Depending upon the moisture content of your soil, you may need to put down plastic as a vapor barrier, as well.
With a lockable hatch - it makes great storage space for tools and toys, too.
The Following User Says Thank You to TomC For This Useful Post:
Rattlesnake Guy (10-28-2009)
Old 10-28-2009, 10:21 AM   #3
At home in Mass I had a sun room added on a few years ago, it is off the ground by about 3 feet. It's got Fiberglas insulation, then a layer of plastic sheeting buttoned up by plywood.
Old 10-28-2009, 12:54 PM   #4
I just did this to my camp and we used 1/4" luan and screwed strapping over every seam. We then used a urethane based caulking and caulked the strapping to the luan to ensure even the smallest critter could not get in. So far it has worked well.
Good Luck!
Old 10-29-2009, 10:49 PM   #5
Bear Island South
Bear Island South's Avatar
Default Tiger Foam
I am looking into this: http://www.tigerfoam.com/
I will let you know how it turns out.
The Following 3 Users Say Thank You to Bear Island South For This Useful Post:
Grady223 (10-30-2009), Rattlesnake Guy (10-31-2009), upthesaukee (10-30-2009)
Old 10-30-2009, 06:36 AM   #6
Default Read the FAQ's
Interesting reading. Note the FAQ's. Should be applied at temps around 70 or so, can be done down to around 55, below that it will not spray.
This has my attention for the crawl space under my house, but will have to wait until spring. May check to see if any dealers in the area use this.
Old 10-30-2009, 10:36 AM   #7
RLW
RLW's Avatar
May I ask why would you want to insulate it for those months only. I had a cottage that we used from first of April through into first of November and just used a wood stove to heat it on cold nights/mornings. Just don't walk around in your bare feet and wear a sweater.
Old 10-30-2009, 02:01 PM   #8
Talking Wear a Poly-Fleece Cap...
Originally Posted by RLW View Post
"...May I ask why would you want to insulate it for those months only. I had a cottage that we used from first of April through into first of November and just used a wood stove to heat it on cold nights/mornings..."
To an island home, that's a lot of trekking of wood; however, you do have a valid point. What would be the pay-off point of insulating, then paying to protect the insulation? Also, I think a red squirrel would be able to chew through luan—PT plywood, not so easily.
"...Just don't walk around in your bare feet and wear a sweater..."
That's true, too—you'd be very cold from the waist down.
Old 10-31-2009, 07:28 AM   #9
Bear Island South
Default spring project
Thanks for pointing out the temps, looks like I am also waiting until spring.
Old 10-31-2009, 01:46 PM   #10
I can tell you that after we insulated our floor (walls and ceiling were already done) we noticed a huge difference in the dampness of the camp. Before the floors were insulated, everything such as bedding, clothes in closet, etc, etc, always had a damp feeling to it. Once we insulated and closed off the floor we no longer have this issue. I definitely think it's worth doing.
Old 10-31-2009, 02:27 PM   #11
RLW
RLW's Avatar
Are you saying that the insulation is collecting the moisture/dampness. If that is the case then something in wrong. A vapor barrier is suppose to do that. Insulation is to stop air flow from below and/or outside not to stop dampness. Insulation is not suppose to get wet as that causes many other problems. Just my little ole 2¢ worth.
Old 10-31-2009, 03:37 PM   #12
No, what I am saying is that by sealing off the bottom of the floors with luan and fully sealing all seams after insulating , it certainly seems to have stopped the flow of the damp ground air into the house. It also stopped ants and other pesky critters from entering the house through the floor. Could this have been accomplished without the insulation...I suppose, but insulation is cheap and easy to carry out to the island so why not have warm floors as well?
All I can say is we are extremely happy we did it. Your mileage may vary...
This page was generated in 0.09348 seconds
