Go Back   Winnipesaukee Forum > Lake Issues > Boating Issues > Speed Limits
View Poll Results: How Fast Is Your Fastest Boat Capable Of
Depends on the wind or the paddling speed 8 3.20%
0 to 20mph 3 1.20%
21 to 30mph 8 3.20%
31 to 40mph 60 24.00%
41 to 50mph 62 24.80%
51 to 60mph 57 22.80%
61 to 70mph 24 9.60%
71 to 80mph 9 3.60%
81 to 100mph 11 4.40%
Over 100 8 3.20%
Voters: 250. You may not vote on this poll
Old 08-30-2009, 05:06 PM   #1
Rattlesnake Guy
Rattlesnake Guy's Avatar
Default Poll: How Fast Does Your Boat Go
OK,
Someone suggested this poll.
To address those with multiple boats, lets say the fastest boat.
Rattlesnake Guy is offline
Old 08-30-2009, 06:12 PM   #2
brk-lnt
brk-lnt's Avatar
OK, but what will this prove?
[insert witty phrase here]
brk-lnt is offline
Old 08-30-2009, 06:55 PM   #3
ronc4424
ronc4424's Avatar
(1) 25 miles per hour during the period from 1/2 hour after sunset to 1/2 hour before sunrise; and
(2) 45 miles per hour at any other time.
ronc4424 is offline
Old 08-30-2009, 07:05 PM   #4
NoBozo
This will prove that GFBLs (Pronounced Giffibles) will go faster than Kayaks. NB
NoBozo is offline
Old 08-30-2009, 07:28 PM   #5
I need clarification... On its own or on the trailer?
Kamper is offline
Old 08-31-2009, 05:24 AM   #6
Question May I Vote?
I need clarification too: My fastest boat is located 1600 miles away.
Is it
"Common Sense" isn't.
ApS is offline
Old 08-31-2009, 03:15 PM   #7
Bear Islander
Bear Islander's Avatar
It looks like 100% of the power boats are capable of violating the nighttime speed limit. And 82% of the power boats are capable of violating the daytime speed limit.
Bear Islander is offline
Old 08-31-2009, 04:46 PM   #8
brk-lnt
brk-lnt's Avatar
More like 50% for the daytime speed limit. 50% of the responses fell in the 1-50MPH category. There is no way you can try to be taken seriously and claim a boat with a top speed (that speed being the best-case speed) of 50MPH is EVER going to run a risk of being pulled over and cited for a daytime speed limit violation.
And of course, this is all based on the self-selecting people who responded to the poll. I have seen several small boats (little Whalers and the like) will small outboards that couldn't top 15MPH on flat water. Your statement about 100% of power boats is simply trolling.
brk-lnt is offline
Old 08-31-2009, 05:41 PM   #9
hazelnut
hazelnut's Avatar
You're just joking right BI? That was said tongue in cheek I am sure.
hazelnut is offline
Old 08-31-2009, 09:35 PM   #10
pm203
I hope she was.
pm203 is offline
Old 09-09-2009, 10:11 AM   #11
Default 65 mph?
Looks like this will be a reasonable compromise to the day limit? Majority of the boaters taking this pole should be OK with that?
BroadHopper is offline
VtSteve (09-09-2009)
Old 09-09-2009, 10:40 AM   #12
VtSteve
I'm happy with it, but probably because I'll never go that fast anyway. My THANKS counts as agreement nowadays here).
VtSteve is offline
Old 09-09-2009, 07:59 PM   #13
Cal
Cal's Avatar
A picture's worth a thousand words
Cal is offline
The Following User Says Thank You to Cal For This Useful Post:
OCDACTIVE (09-09-2009)
Old 09-09-2009, 08:20 PM   #14
OCDACTIVE
OCDACTIVE's Avatar
VERY NICE!! what are you running in there?? 525's?
OCDACTIVE is offline
Old 09-09-2009, 10:13 PM   #15
VtSteve
My boat hit 54.6 this weekend after an hour of cleaning the bottom
Still down about 4 mph after doing all this work and buying a new prop though
At any rate, most of the time you'll find me cruising between 25 and 35, just a comfortable range for this boat. Anyone want to buy a cream puff?
VtSteve is offline
Old 09-10-2009, 08:13 AM   #16
Default New prop
Normally I can hit 50 on a good day.
I change the prop from 25', 3 blade to a 24 pitch, 4 blade. Last weekend I open it up to check the speed. I am alone and I have a full tank of gas. I am spinning 4400 rpm. Same as the old wheel. Using the VDO speedomenter it was registering 55 mph. Fastest I have ever been on this boat. Looks like I decrease the slippage going to a 4 blade. I always check the gph of my boat by writing done the hours on the hour meter every time I gas up. I'm surprise last weekend I am using less gas. A liitle less than a gallon per hour than average. This is only one weekend.
Old 09-10-2009, 11:36 AM   #17
Cal
Cal's Avatar
540's One dyned 660 hp and the other 661hp. My deep X dimension and non stepped hull are holding it back and 2" Imco shorties are just not in the budget right now
Btw , nice meeting you at Jammin' on the James. Quite an enlightening conversation.
Cal is offline
Old 09-10-2009, 11:50 AM   #18
Cal
Cal's Avatar
It has been my experience the 4 blades do not ALWAYS increase top speed but almost always increase cruising speed at the same RPM or you can decrease RPMs and still maintain the original speed. In either case it improves efficiency and MPG
Cal is offline
Old 09-10-2009, 12:34 PM   #19
OCDACTIVE
OCDACTIVE's Avatar
OH so that was you... honestly, after the "dock sinking party" I was pretty reved up.. Great evening!!!!!!
Old 09-10-2009, 02:37 PM   #20
OCDACTIVE
OCDACTIVE's Avatar
Just a heads up (as well for any other GFB enthusiasts) they just set the date for next years Jammin on the James, July 10th.. I hope they don't plan the easter seals poker run the same day this time...
Best run I have ever been on. I am sure Cal can attest to that. Anyone need details let me know!
Just a few examples.. Can you imagine the $$$ that would flood into the lakes region if we could hold a run like this? Just a thought!
Old 09-10-2009, 05:10 PM   #21
Cal
Cal's Avatar
I guess that accounts for the slurred speach
It was a great run but 86 miles on a little puddle like Winni would require a few laps around the lake.
Cal is offline
Old 09-10-2009, 05:43 PM   #22
brk-lnt
brk-lnt's Avatar
Exactly, Winnipesaukee is not an ideal environment for those kinds of runs. They are tons of fun, but belong on big water.
brk-lnt is offline
Old 09-10-2009, 05:45 PM   #23
OCDACTIVE
OCDACTIVE's Avatar
Very true.. but I am sure we can figure out something.. Hell they used to do races there..
And as for the speech impediment... Totally not my fault... I was fed strawberries hollowed out with some type of rum inside with whip cream on top.... After that everything got a bit fuzzy.. But was actually coming around by dinner time.. LOL....
I still think it was ironic that out of 500 people I sit next to the only other guy on winni.com
Crazy!!! next year we will have to plan to meet up at the captains meeting... I can also give you some inside scoops on where to stay for pre and after partys.
Take care.
This page was generated in 0.35716 seconds
