I have a 2003 Rinker w/ a Merc motor and Bravo3 drive
While navigating in rough water, the alarm occasionally sounds Engine Temp, Oil pressure and Gear Lube levels are all acceptable Very un-nerving Any ideas as to cause and solution would be appreciated |
#2 | |
...in any one of the 3 systems. I'm not sure how its designed and wired, but if is set up so a ground at the sensor sets off the alarm, you could have a chafed wire grounding on the block...
#4 | |
This is exactly what I was thinking, and I was thinking it's most likely the gear oil in the reservoir. |
Also, if the water pickup on the drive gets out of water, even momentarily, an alarm will usually go off.
Disconnect the alarm wires(tan with blue tracer) on the drive oil bottle and try it again. That's my bet
I have also had an alarm go off in rough water. It was my high water bilge pump. The float would be jarred and set off the alarm. Check the floats as well as the other engine fluids like the previous posters....
Thanks for all the good advise
The drive lube resevoir was my suspect as well, never thought of the bilge pump or chafed wire I will give these a try over the upcoming weekend |
I have a Bravo III on my boat -- similar problem a few years back. Turned out the float was faulty in the gear lube resevoir.
Rinkleyguy,
I have a few ideas of what it could be.............I'll need your boat for a weekend.....with a full tank of fuel.......... a place to stay.................food........ And I'll let you know what I find on Monday. CZ But really, I think it is one of the above listed items. Good luck. |
I have an '04 Rinker with a Bravo III as well. We had to have the drive replaced in '05 (to the new design thankfully) due to a defect. Our first outing with the new drive was met by an alarm almost immediately. The drive lube was about 2 ounces shy of full due to an air bubble in the system. Just goes to show how sensitive the newer stuff is.
Education is hanging around 'til you've caught on - Frost |
