-   -   Alarm Sounds in Rough Water (https://www.winnipesaukee.com/forums/showthread.php?t=5084)
Rinkerguy 08-28-2007 03:45 PM
I have a 2003 Rinker w/ a Merc motor and Bravo3 drive
While navigating in rough water, the alarm occasionally sounds
Engine Temp, Oil pressure and Gear Lube levels are all acceptable
Very un-nerving:confused:
Any ideas as to cause and solution would be appreciated
NightWing 08-28-2007 04:00 PM
I would bet your drive oil is a bit low and sloshing around, setting off the alarm. I had a boat do the same thing. Drove me nuts and it was only a little low.
TomC 08-28-2007 04:37 PM
or a loose connection...
...in any one of the 3 systems. I'm not sure how its designed and wired, but if is set up so a ground at the sensor sets off the alarm, you could have a chafed wire grounding on the block...
Steve 08-28-2007 04:56 PM
This is exactly what I was thinking, and I was thinking it's most likely the gear oil in the reservoir.
Paugus Bay Resident 08-28-2007 06:59 PM
Also, if the water pickup on the drive gets out of water, even momentarily, an alarm will usually go off.
Cal 08-28-2007 09:19 PM
Disconnect the alarm wires(tan with blue tracer) on the drive oil bottle and try it again. That's my bet;)
NoRegrets 08-28-2007 10:21 PM
Bilge pump float...
I have also had an alarm go off in rough water. It was my high water bilge pump. The float would be jarred and set off the alarm. Check the floats as well as the other engine fluids like the previous posters....
Rinkerguy 08-29-2007 08:06 AM
Thanks for all the good advise
The drive lube resevoir was my suspect as well, never thought of the bilge pump or chafed wire
I will give these a try over the upcoming weekend
Mink Islander 08-29-2007 08:13 AM
Gear Lube Resevoir
I have a Bravo III on my boat -- similar problem a few years back. Turned out the float was faulty in the gear lube resevoir.
Captain Zipper 08-29-2007 10:37 PM
Rinkleyguy,
I have a few ideas of what it could be.............I'll need your boat for a weekend.....with a full tank of fuel.......... a place to stay.................food........
And I'll let you know what I find on Monday. :laugh:
CZ
But really, I think it is one of the above listed items. Good luck.
Rinkerfam 08-29-2007 10:57 PM
I have an '04 Rinker with a Bravo III as well. We had to have the drive replaced in '05 (to the new design thankfully) due to a defect. Our first outing with the new drive was met by an alarm almost immediately. The drive lube was about 2 ounces shy of full due to an air bubble in the system. Just goes to show how sensitive the newer stuff is.
